Configure the ESXi host best practice settings
You must ensure that the ESXi host best practice settings are correct so that the ESXi host can correctly manage the loss of an NFS connection or a storage.
Steps
From the VMware vSphere Web Client Home page, click vCenter > Hosts.
Right-click the host, and then select Actions > NetApp VSC > Set Recommended Values.
In the NetApp Recommended Settings dialog box, ensure that all of the options are selected, and then click OK.
MPIO Settings do not apply to NFS. However, if you use other protocols, you should ensure that all options are selected.
The vCenter Web Client displays the task progress.
