System Manager Classic
Manage IPspaces with System Manager - ONTAP 9.7 and earlier
Contributors netapp-mwallis
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to create and manage IPspaces.
Edit IPspaces
You can use System Manager to rename an existing IPspace.
About this task
  • All IPspace names must be unique within a cluster and must not consist of names that are reserved by the system, such as local or localhost.
  • The system-defined “Default” IPspace and “Cluster” IPspace cannot be modified.
Steps
  1. Click Network > IPspaces.
  2. Select the IPspace that you want to modify, and then click Edit.
  3. In the Edit IPspace dialog box, specify a new name for the IPspace.
  4. Click Rename.
Delete IPspaces
You can use System Manager to delete an IPspace when you no longer require the IPspace.
Before you begin
The IPspace that you want to delete must not be associated with any broadcast domains, network interfaces, peer relationships, or storage virtual machines (SVMs).
About this task
The system-defined “Default” IPspace and “Cluster” IPspace cannot be deleted.
Steps
  2. Select the IPspace that you want to delete, and then click Delete.
  3. Select the confirmation check box, and then click Yes.
Related information
Looking for answers?
Try Doc, our Gen AI Assistant.
