Manage LDAP configurations with System Manager - ONTAP 9.7 and earlier
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to manage LDAP configurations.
Edit active LDAP clients
You can use System Manager to associate an active LDAP client with a storage virtual machine (SVM), which enables you to use LDAP as a name service or for name mapping.
Click Storage > SVMs.
Select the SVM, and then click SVM Settings.
In the Services pane, click LDAP Configuration.
In the LDAP Configuration window, click Edit.
In the Active LDAP Client dialog box, select the LDAP client that you want to edit, and perform the following actions:
Modify the Active Directory domain servers.
Modify the preferred Active Directory servers.
Click OK.
Verify that the changes that you made are updated in the LDAP Configuration window.
Delete active LDAP clients
You can use System Manager to delete an active LDAP client when you do not want a storage virtual machine (SVM) to be associated with it.
Click the SVM Settings tab.
Click Delete.
Select the confirmation check box, and then click Delete.
You can use the LDAP Configuration window to edit or delete active LDAP clients at the storage virtual machine (SVM) level.
Command buttons
Edit
Opens the Active LDAP Client dialog box, which enables you to edit the properties of the active LDAP client, such as Active Directory domain servers and preferred Active Directory servers.
Delete
Opens the Delete Active LDAP Client dialog box, which enables you to delete the active LDAP client.
Refresh
Updates the information in the window.
LDAP Configuration area
Displays the details about the active LDAP client.
LDAP client name
Displays the name of the active LDAP client.
Active Directory Domain Servers
Displays the Active Directory domain for the active LDAP client.
Preferred Active Directory Servers
Displays the preferred Active Directory server for the active LDAP client.
