Manage volumes with System Manager - ONTAP 9.7 and earlier
You can use ONTAP System Manager classic (available in 9.7 and earlier) to create, edit, and delete volumes.
You can access all the volumes in the cluster by using the Volumes tab or you can access the volumes specific to an SVM by using SVMs > Volumes.
The Volumes tab is displayed only if you have enabled the CIFS and NFS licenses. |
Related information
