Abort mirror and vault relationships with System Manager - ONTAP 9.7 and earlier
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to abort a volume replication operation if you want to stop the data transfer. You can abort a scheduled update, a manual update, or an initial data transfer.
Click Protection > Volume Relationships.
Select the mirror and vault relationship for which you want to stop the data transfer, and then click Operations > Abort.
Select the Yes, I want to abort the transfer check box to confirm the operation.
Optional: Select the Keep any partially transferred data check box to retain the data that is already transferred to the destination volume.
Click Abort.
The transfer status is displayed as “Aborting” until the operation is complete and displayed as “Idle” after the operation is complete.
