Add Microsoft SQL Server over SAN to System Manager - ONTAP 9.7 and earlier
You can use the Enhanced tab to add an instance of Microsoft SQL Server over SAN to ONTAP System Manager classic (available in ONTAP 9.7 and earlier).
The following procedure describes how to add a Microsoft SQL Server instance over SAN to System Manager. You can choose SMB as the export protocol only if the cluster is licensed for CIFS, which must be configured on the storage virtual machine (SVM).
Click Applications & Tiers > Applications
In the Enhanced tab, click Add
Select Microsoft SQL Server instance from the menu.
The dropdown list includes a list of all available application types and template types.
The Add Microsoft SQL Server Instance window is displayed.
Specify the following details:
Database name
Database size and the required ONTAP service level
Number of server cores
Log size and the required ONTAP service level
Provision for Tempdb
Specify if the server should be provisioned for Tempdb.
Export Protocol (SMB or SAN)
Specify SAN
Host operating system
LUN format
Host mapping
Click Add Application
The Microsoft SQL Server instance over SAN is added to System Manager.
