The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Change the status of a FlexGroup volume with System Manager - ONTAP 9.7 and earlier
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
Your file is ready
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to change the status of a FlexGroup volume when you want to take a FlexGroup volume offline, bring a FlexGroup volume back online, or restrict access to a FlexGroup volume.
About this task
System Manager does not support constituent-level management for FlexGroup volumes.
Steps
Click Storage > Volumes.
From the drop-down menu in the SVM field, select All SVMs.
Select the FlexGroup volume for which you want to modify the status.
Click More Actions > Change status to, and then update the FlexGroup volume status by selecting the required status.
Related information
