Clone an NVMe namespace with System Manager - ONTAP 9.7 and earlier
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to quickly create another namespace of the same configuration by choosing to clone a namespace. You can map the newly cloned namespace to another host NQN.
You must have a FlexClone license to clone a namespace.
You can clone a namespace with the selected host mapping and associate it with another subsystem.
Click NVMe > NVMe namespaces.
In the NVMe namespaces window, select the namespace you want to clone.
You can rename the cloned namespace if you need a specific name but it is not required.
The dialog provides a default name of the namespace to-be-cloned.
Modify the subsystem mapping for the cloned namespace.
Click OK.
The online, mapped namespace is cloned inside the same SVM with a different name. Host mapping will not be cloned.
