Create an NFS datastore for VMware with System Manager - ONTAP 9.7 and earlier
You can use the Create NFS Datastore for VMware wizard in ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to create an NFS datastore for VMware. You can create a volume for the NFS datastore and specify the ESX servers that can access the NFS datastore.
Before you begin
The NFS service must be licensed.
Steps
Click Storage > Volumes.
From the drop-down menu in the SVM field, select All SVMs.
Select the volume, and then click More Actions > Provision Storage for VMware.
In the Create NFS Datastore for VMware wizard, type or select information as required.
Confirm the details, and then click Finish to complete the wizard.
