Manage portsets with System Manager - ONTAP 9.7 and earlier
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to create, delete and edit portsets.
Create portsets
You can use ONTAP System Manager classic to create portsets to limit access to your LUNs.
Click Storage > LUNs.
In the Portsets tab, click Create.
In the Create Portset dialog box, select the type of protocol.
Choose the network interface that you want to associate with the portset.
Click Create.
Delete portsets
You can use System Manager to delete a portset when it is no longer required.
In the Portsets tab, select one or more portsets and click Delete.
Confirm the deletion by clicking Delete.
Edit portsets
You can use the Portsets tab in System Manager to edit settings related to portsets.
In the Portsets tab, select the portset you want to edit and click Edit.
In the Edit Portset dialog box, make the necessary changes.
Click Save and Close.
Related information
