The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Delete aggregates with System Manager - ONTAP 9.7 and earlier
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
Your file is ready
You can use ONTAP System Manager classic (avaiable in ONTAP 9.7 and earlier) to delete aggregates when you no longer require the data in the aggregates. However, you cannot delete the root aggregate because it contains the root volume, which contains the system configuration information.
Before you begin
All the FlexVol volumes and the associated storage virtual machines (SVMs) contained by the aggregate must be deleted.
The aggregate must be offline.
Steps
Choose one of the following methods:
Click Applications & Tiers > Storage Tiers.
Click Storage > Aggregates & Disks > Aggregates.
Select one or more aggregates that you want to delete, and then click Delete.
Select the confirmation check box, and then click Delete.
Related information
