The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Delete FlexGroup volumes with System Manager - ONTAP 9.7 and earlier
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
Your file is ready
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to delete a FlexGroup volume when you no longer require the FlexGroup volume.
Before you begin
The junction path of the FlexGroup volume must be unmounted.
The FlexGroup volume must be offline.
About this task
System Manager does not support constituent level of management for FlexGroup volumes.
Steps
Click Storage > Volumes.
From the drop-down menu in the SVM field, select All SVMs.
Select the FlexGroup volume that you want to delete, and then click Delete.
Select the confirmation check box, and then click OK.
Related information
