Delete SVMs with System Manager - ONTAP 9.7 and earlier
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to delete storage virtual machines (SVMs) that you no longer require from the storage system configuration.
You must have completed the following tasks:
Disabled the Snapshot copies, data protection (DP) mirrors, and load-sharing (LS) mirrors for all the volumes
You must use the command-line interface (CLI) to disable LS mirrors.
Deleted all the igroups that belong to the SVM manually if you are deleting SVMs
Deleted all the portsets
Deleted all the volumes in the SVM, including the root volume
Unmapped the LUNs, taken them offline, and deleted them
Deleted the CIFS server if you are deleting SVMs
Deleted any customized user accounts and roles that are associated with the SVM
Deleted any NVMe subsystems associated with the SVM using the CLI.
Stopped the SVM
When you delete SVMs, the following objects associated with the SVM are also deleted:
LIFs, LIF failover groups, and LIF routing groups
Export policies
Efficiency policies
If you delete SVMs that are configured to use Kerberos, or modify SVMs to use a different Service Principal Name (SPN), the original service principal of the SVM is not automatically deleted or disabled from the Kerberos realm. You must manually delete or disable the principal. You must have the Kerberos realm administrator's user name and password to delete or disable the principal.
If you want to move data from an SVM to another SVM before you delete the first SVM, you can use the SnapMirror technology to do so.
Click Storage > SVMs.
Select the SVM that you want to delete, and then click Delete.
Select the confirmation check box, and then click Delete.
