Editing FlexCache volumes
Beginning with System Manager 9.6, you can edit the properties of an existing FlexCache volume.
Steps
Click Storage > Volumes.
From the drop-down menu in the SVM field, select All SVMs.
Select the FlexCache volume that you want to modify, and click Edit.
Optional: Enter a new name for the FlexCache volume in the Volume field under FlexCache Volume.
Optional: Enter a new size for the FlexCache volume in the Size field under FlexCache Volume, and select the measurement unit from the drop-down menu.
Optional: Enable or disable encryption.
Optional: Click
to modify the FlexCache volume advanced settings. Refer to Specifying advanced options for a FlexCache volume. -
Click Save to save the changes.
Related information
