Restore a volume in a mirror and vault relationship with System Manager - ONTAP 9.7 and earlier
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to restore Snapshot copies to a source volume or to other volumes if the source data is corrupted and is no longer usable. You can replace the original data with the Snapshot copies in the destination volume.
The SnapMirror license and SnapVault license must be enabled on both the source cluster and the destination cluster or on the nodes that contain the source volume and destination volume.
The source cluster and destination cluster must be in a healthy peer relationship.
The source aggregate or any other aggregate that you select for the restore operation must be a 64-bit aggregate.
If you are connecting from a cluster running ONTAP 9.2 or earlier to a remote cluster on which SAML authentication is enabled, password-based authentication must also be enabled on the remote cluster.
You cannot restore a volume that is in a mirror and vault relationship between a source storage virtual machine (SVM) and a destination SVM in a MetroCluster configuration.
You can restore a mirror and vault relationship for the following configurations:
Between sync-source SVMs in a MetroCluster configuration
From a volume on a sync-source SVM to a default SVM
From a volume on a default SVM to a DP volume on a sync-source SVM
Click Protection > Volume Relationships.
Select the mirror and vault relationship that you want to restore, and then click Operations > Restore.
In the Restore dialog box, restore the data to the source volume in the relationship or select any other volume:
If you want to restore the data to… Do this… The source volume
Select Source volume.
Any other volume
Select Other volume, and then select the cluster and the SVM.
Restore the data to a new volume or to an existing volume:
If you want to restore the data to… Do this… A new volume
If you want to change the default name, displayed in the format “destination_SVM_name_destination_volume_name_restore”, specify a new name, and then select the containing aggregate for the volume.
An existing volume
Select the Select Volume option.
You must select a volume other than the source volume, or a read/write volume with some data in it and with a common Snapshot copy.
Only those volumes with the same language attribute as the source volume are listed.
Select either the latest Snapshot copy or the specific Snapshot copy that you want to restore.
Select the confirmation check box to restore the volume from the Snapshot copy.
Optional: Select the Enable Network Compression check box to compress the data that is being transferred during the restore operation.
Click Restore.
