Volume move workflow
You can move a volume by using the ONTAP System Manager classic interface with ONTAP 9.7 or earlier.
Before moving a volume, you should select a method for the volume move operation and plan the timing of the operation. After the move, you might have to update the NDMP backup configuration.
Other ways to do this in ONTAP
To complete this workflow using… |
Refer to… |
The redesigned System Manager (available with ONTAP 9.7 and later) |
The ONTAP command-line interface |
