Edit the Reference Configuration File (RCF)
Contributors netapp-martyh netapp-yvonneo
In order to activate newly licensed ports, you need to edit the latest version of the RCF and uncomment the applicable port details. The default license activates ports 0/1 to 0/16 and 0/55 to 0/56 while the newly licensed ports will be between ports 0/17 to 0/54 depending on the type and number of licenses available.
For details of the available license types for use on the BES-53248 cluster switch, see Installing licenses for BES-53248 cluster switches.
For example to activate the SW-BES54248-40-100G-LIC license, you must uncomment the following section in the RCF:
! 2-port or 6-port 40/100GbE node port license block
interface 0/49
no shutdown
description "40/100GbE Node Port"
!speed 100G full-duplex
speed 40G full-duplex
service-policy in WRED_100G
spanning-tree edgeport
mtu 9216
switchport mode trunk
datacenter-bridging
priority-flow-control mode on
priority-flow-control priority 5 no-drop
exit
exit
interface 0/50
no shutdown
mtu 9216
datacenter-bridging
exit
exit
interface 0/51
no shutdown
!speed 40G full-duplex
mtu 9216
datacenter-bridging
exit
exit
interface 0/52
no shutdown
mtu 9216
datacenter-bridging
exit
exit
interface 0/53
no shutdown
mtu 9216
datacenter-bridging
exit
exit
interface 0/54
no shutdown
mtu 9216
datacenter-bridging
exit
exit
Note For high-speed ports between 0/49 to 0/54 inclusive, uncomment each port but only uncomment one speed line in the RCF for each of these ports, either:
  • speed 100G full-duplex
  • speed 40G full-duplex
as shown in the example.
For low-speed ports between 0/17 to 0/48 inclusive, uncomment the entire 8-port section when an appropriate license has been activated.
