Migrate to a switched NetApp cluster environment using Broadcom-supported BES-53248 cluster switches
Contributors netapp-yvonneo netapp-martyh
If you have an existing two-node switchless cluster environment, you can migrate to a two-node switched cluster environment using Broadcom-supported BES-53248 cluster switches to enable you to scale beyond two nodes in the cluster.
What you’ll need
Two-node switchless configuration:
  • The two-node switchless configuration must be properly set up and functioning.
  • The nodes must be running ONTAP 9.5P8 and later. Support for 40/100 GbE cluster ports starts with EFOS firmware version 3.4.4.6 and later.
  • All cluster ports must be in the up state.
  • All cluster logical interfaces (LIFs) must be in the up state and on their home ports.
Broadcom-supported BES-53248 cluster switch configuration:
  • The BES-53248 cluster switch must be fully functional on both switches.
  • Both switches must have management network connectivity.
  • There must be console access to the cluster switches.
  • BES-53248 node-to-node switch and switch-to-switch connections must use Twinax or fiber cables.
    The NetApp Hardware Universe contains information about ONTAP compatibility, supported EFOS firmware, and cabling to BES-53248 switches.
  • Inter-Switch Link (ISL) cables must be connected to ports 0/55 and 0/56 on both BES-53248 switches.
  • Initial customization of both the BES-53248 switches must be completed. So that the:
    • BES-53248 switches are running the latest version of software
    • BES-53248 switches have optional port licenses installed, if purchased
    • Reference Configuration Files (RCFs) have been applied to the switches
      Any site customization, such as SMTP, SNMP, and SSH must be configured on the new switches.
About this task
The examples in this procedure use the following cluster switch and node nomenclature:
  • The names of the BES-53248 switches are cs1 and cs2.
  • The names of the cluster SVMs are node1 and node2.
  • The names of the LIFs are node1_clus1 and node1_clus2 on node 1, and node2_clus1 and node2_clus2 on node 2 respectively.
  • The cluster1::*> prompt indicates the name of the cluster.
  • The cluster ports used in this procedure are e0a and e0b.
    The NetApp Hardware Universe contains the latest information about the actual cluster ports for your platforms.
Steps
  1. If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message:
    system node autosupport invoke -node * -type all -message MAINT=xh
    where x is the duration of the maintenance window in hours.
    Note The AutoSupport message notifies technical support of this maintenance task so that automatic case creation is suppressed during the maintenance window.
    The following command suppresses automatic case creation for two hours:
    cluster1::*> system node autosupport invoke -node \* -type all -message MAINT=2h
  2. Change the privilege level to advanced, entering y when prompted to continue:
    set -privilege advanced
    The advanced prompt (*>) appears.
  3. Disable all activated node-facing ports (not ISL ports) on both the new cluster switches cs1 and cs2.
    Note You must not disable the ISL ports.
    The following example shows that node-facing ports 1 through 16 are disabled on switch cs1:
    (cs1)# configure
    (cs1)(Config)# interface 0/1-0/16
    (cs1)(Interface 0/1-0/16)# shutdown
    (cs1)(Interface 0/1-0/16)# exit
    (cs1)(Config)# exit
  4. Verify that the ISL and the physical ports on the ISL between the two BES-53248 switches cs1 and cs2 are up:
    show port-channel
    The following example shows that the ISL ports are up on switch cs1:
    (cs1)# show port-channel 1/1
    Local Interface................................ 1/1
    Channel Name................................... Cluster-ISL
    Link State..................................... Up
    Admin Mode..................................... Enabled
    Type........................................... Dynamic
    Port channel Min-links......................... 1
    Load Balance Option............................ 7
    (Enhanced hashing mode)
    Mbr    Device/       Port       Port
    Ports  Timeout       Speed      Active
    0/55   actor/long    100G Full  True
           partner/long
    0/56   actor/long    100G Full  True
           partner/long
    (cs1) #
    The following example shows that the ISL ports are up on switch cs2 :
    (cs2)# show port-channel 1/1
           partner/long
           partner/long
  5. Display the list of neighboring devices:
    show isdp neighbors
    This command provides information about the devices that are connected to the system.
    The following example lists the neighboring devices on switch cs1:
    (cs1)# show isdp neighbors
    Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge,
                      S - Switch, H - Host, I - IGMP, r - Repeater
    Device ID      Intf     Holdtime  Capability   Platform    Port ID
    cs2            0/55     176       R            BES-53248   0/55
    cs2            0/56     176       R            BES-53248   0/56
    The following example lists the neighboring devices on switch cs2:
    (cs2)# show isdp neighbors
  6. Verify that all cluster ports are up:
    network port show -ipspace Cluster
    Each port should display up for Link and healthy for Health Status.
    cluster1::*> network port show -ipspace Cluster
    Node: node1
                                                      Speed(Mbps) Health
    Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status
    e0a       Cluster      Cluster          up   9000  auto/10000 healthy
    e0b       Cluster      Cluster          up   9000  auto/10000 healthy
    Node: node2
                                                      Speed(Mbps) Health
  7. Verify that all cluster LIFs are up and operational: network interface show -vserver Cluster
    Each cluster LIF should display true for Is Home and have a Status Admin/Oper of up/up
    cluster1::*> network interface show -vserver Cluster
                Logical    Status     Network            Current       Current Is
    Vserver     Interface  Admin/Oper Address/Mask       Node          Port    Home
    Cluster
                node1_clus1  up/up    169.254.209.69/16  node1         e0a     true
                node1_clus2  up/up    169.254.49.125/16  node1         e0b     true
                node2_clus1  up/up    169.254.47.194/16  node2         e0a     true
                node2_clus2  up/up    169.254.19.183/16  node2         e0b     true
  8. Verify that auto-revert is enabled on all cluster LIFs: network interface show -vserver Cluster -fields auto-revert
    cluster1::*> network interface show -vserver Cluster -fields auto-revert
              Logical
    Vserver   Interface     Auto-revert
    Cluster
              node1_clus1   true
              node1_clus2   true
              node2_clus1   true
              node2_clus2   true
  9. Disconnect the cable from cluster port e0a on node1, and then connect e0a to port 1 on cluster switch cs1, using the appropriate cabling supported by the BES-53248 switches.
    The NetApp Hardware Universe contains more information about cabling.
  10. Disconnect the cable from cluster port e0a on node2, and then connect e0a to port 2 on cluster switch cs1, using the appropriate cabling supported by the BES-53248 switches.
  11. Enable all node-facing ports on cluster switch cs1.
    The following example shows that ports 1 through 16 are enabled on switch cs1:
    (cs1)# configure
    (cs1)(Interface 0/1-0/16)# no shutdown
    (cs1)(Config)# exit
  12. Verify that all cluster LIFs are up, operational, and display as true for Is Home:
    The following example shows that all of the LIFs are up on node1 and node2 and that Is Home results are true:
    Cluster
  13. Display information about the status of the nodes in the cluster:
    cluster show
    The following example displays information about the health and eligibility of the nodes in the cluster:
    cluster1::*> cluster show
    Node                 Health  Eligibility   Epsilon
    node1                true    true          false
    node2                true    true          false
  14. Disconnect the cable from cluster port e0b on node1, and then connect e0b to port 1 on cluster switch cs2, using the appropriate cabling supported by the BES-53248 switches.
  15. Disconnect the cable from cluster port e0b on node2, and then connect e0b to port 2 on cluster switch cs2, using the appropriate cabling supported by the BES-53248 switches.
  16. Enable all node-facing ports on cluster switch cs2.
    The following example shows that ports 1 through 16 are enabled on switch cs2:
    (cs2)# configure
    (cs2)(Config)# interface 0/1-0/16
    (cs2)(Interface 0/1-0/16)# no shutdown
    (cs2)(Interface 0/1-0/16)# exit
    (cs2)(Config)# exit
  17. Verify that all cluster ports are up:
    The following example shows that all of the cluster ports are up on node1 and node2:
    Node: node1
        Ignore
                                                      Speed(Mbps) Health   Health
    Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status   Status
    e0a       Cluster      Cluster          up   9000  auto/10000 healthy  false
    e0b       Cluster      Cluster          up   9000  auto/10000 healthy  false
    Node: node2
        Ignore
  18. Verify that all interfaces display true for Is Home:
    Note This might take several minutes to complete.
    The following example shows that all LIFs are up on node1 and node2 and that Is Home results are true:
    Cluster
  19. Verify that both nodes each have one connection to each switch:
    show isdp neighbors
    The following example shows the appropriate results for both switches:
    Device ID      Intf         Holdtime  Capability   Platform -- Port ID
    node1          0/1          175       H            FAS2750     e0a
    node2          0/2          157       H            FAS2750     e0a
    cs2            0/55         178       R            BES-53248   0/55
    cs2            0/56         178       R            BES-53248   0/56
    node1          0/1          137       H            FAS2750     e0b
    node2          0/2          179       H            FAS2750     e0b
    cs1            0/55         175       R            BES-53248   0/55
    cs1            0/56         175       R            BES-53248   0/56
  20. Display information about the discovered network devices in your cluster:
    network device-discovery show -protocol cdp
    cluster1::*> network device-discovery show -protocol cdp
    Node/       Local  Discovered
    Protocol    Port   Device (LLDP: ChassisID)  Interface         Platform
    node2      /cdp
                e0a    cs1                       0/2               BES-53248
                e0b    cs2                       0/2               BES-53248
    node1      /cdp
                e0a    cs1                       0/1               BES-53248
                e0b    cs2                       0/1               BES-53248
  21. Verify that the settings are disabled:
    network options switchless-cluster show
    Note It might take several minutes for the command to complete. Wait for the '3 minute lifetime to expire' announcement.
    The false output in the following example shows that the configuration settings are disabled:
    cluster1::*> network options switchless-cluster show
    Enable Switchless Cluster: false
  22. Verify the status of the node members in the cluster:
    cluster show
    The following example shows information about the health and eligibility of the nodes in the cluster:
  23. Ensure that the cluster network has full connectivity using the command:
    cluster ping-cluster -node node-name
    cluster1::*> cluster ping-cluster -node local
    Host is node2
    Getting addresses from network interface table...
    Cluster node1_clus1 192.168.168.26 node1 e0a
    Cluster node1_clus2 192.168.168.27 node1 e0b
    Cluster node2_clus1 192.168.168.28 node2 e0a
    Cluster node2_clus2 192.168.168.29 node2 e0b
    Local = 192.168.168.28 192.168.168.29
    Remote = 192.168.168.26 192.168.168.27
    Cluster Vserver Id = 4294967293
    Ping status:
    Basic connectivity succeeds on 4 path(s)
    Basic connectivity fails on 0 path(s)
    Detected 1500 byte MTU on 4 path(s):
        Local 192.168.168.28 to Remote 192.168.168.26
        Local 192.168.168.28 to Remote 192.168.168.27
        Local 192.168.168.29 to Remote 192.168.168.26
        Local 192.168.168.29 to Remote 192.168.168.27
    Larger than PMTU communication succeeds on 4 path(s)
    RPC status:
    2 paths up, 0 paths down (tcp check)
    2 paths up, 0 paths down (udp check)
  24. Change the privilege level back to admin:
    set -privilege admin
  25. If you suppressed automatic case creation, reenable it by invoking an AutoSupport message:
    cluster1::*> system node autosupport invoke -node \* -type all -message MAINT=END
After you finish
See Install the Cluster Switch Health Monitor (CSHM) configuration file and Configure the cluster switch log collection feature for the steps required to enable cluster health switch log collection used for collecting switch-related log files.
Related information
