Overview of Broadcom-supported BES-53248 cluster switches
Contributors netapp-martyh netapp-yvonneo
Broadcom-supported BES-53248 cluster switches are designed to work in clusters ranging in size from two to 24 nodes in ONTAP 9.5P8 and later. Support for 40/100 GbE cluster ports starts with EFOS firmware version 3.4.4.6 and later.
BES-53248 is a switch running on a Broadcom-embedded OS known as Ethernet Fabric OS (EFOS).
The following table lists the part number and description for the BES-53248 cluster switch, rack mount rail kit, fans, and power supplies:
Part number Description
X190005
BES-53248, CLSW, 16Pt10/25GB, PTSX, BRDCM SUPP (PTSX = Port Side Exhaust)
X190005R
BES-53248, CLSW, 16Pt10/25GB, PSIN, BRDCM SUPP (PSIN = Port Side Intake)
X-RAIL-4POST-190005
Rack mount rail kit Ozeki 4 post 19"
X-FAN-190005-R
Fan, port side intake X190005
X-FAN-190005-F
Fan, port side exhaust X190005
X-PSU-190005-R
Power supply, port side intake X190005
X-PSU-190005-F
Power supply, port side exhaust X190005
Overview of airflow based on the two models offered:
  • Port-side exhaust airflow (standard air): Cool air enters the chassis through the fan and power supply modules in the cold aisle and exhausts through the port end of the chassis in the hot aisle. Blue coloring indicates port-side exhaust airflow. This is the most common option.
  • Port-side intake airflow (reverse air): Cool air enters the chassis through the port end in the cold aisle and exhausts through the fan and power supply modules in the hot aisle.
For information on the relevant connectors and cable options to use along with their part numbers, see the NetApp Hardware Universe.
For more information, see the Cluster Network and Management Network Compatibility Matrix available from the BES-53248 switch download site Broadcom cluster switches.
