Configure the cluster switch log collection feature
Contributors netapp-yvonneo netapp-martyh
The cluster switch health monitor log collection feature is used to collect switch-related log files in ONTAP. You must make sure that you have set up your environment using the BES-53248 cluster switch CLI as detailed here.
Steps
  1. Generate the SSH keys:
    crypto key generate
    (switch)# show ip ssh
    SSH Configuration
    Administrative Mode: .......................... Disabled
    SSH Port: ..................................... 22
    Protocol Level: ............................... Version 2
    SSH Sessions Currently Active: ................ 0
    Max SSH Sessions Allowed: ..................... 5
    SSH Timeout (mins): ........................... 5
    Keys Present: ................................. DSA(1024) RSA(1024) ECDSA(521)
    Key Generation In Progress: ................... None
    SCP server Administrative Mode: ............... Disabled
    (switch)# config
    (switch) (Config)# crypto key generate rsa
    Do you want to overwrite the existing RSA keys? (y/n): y
    (switch) (Config)# crypto key generate dsa
    Do you want to overwrite the existing DSA keys? (y/n): y
    (switch) (Config)# crypto key generate ecdsa 521
    Do you want to overwrite the existing ECDSA keys? (y/n): y
    (switch) (Config)# aaa authorization commands "noCmdAuthList" none
    (switch) (Config)# exit
    (switch)# ip ssh server enable
    (switch)# ip ssh pubkey-auth
    (switch)# ip scp server enable
    (switch)# write memory
    This operation may take a few minutes.
    Management interfaces will not be available during this time.
    Are you sure you want to save? (y/n) y
    Config file 'startup-config' created successfully.
    Configuration Saved!
  2. Verify that SSH is enabled:
    show ip ssh
    SSH Configuration
    Administrative Mode: .......................... Enabled
  3. For ONTAP 9.8 and later, enable the cluster switch health monitor log collection feature for collecting switch-related log files, using the commands:
    system switch ethernet log setup-password and system switch ethernet log enable-collection
    Enter: system switch ethernet log setup-password
    cluster1::*> system switch ethernet log setup-password
    Enter the switch name: <return>
    The switch name entered is not recognized.
    Choose from the following list:
    cs1
    cs2
    Enter the switch name: cs1
    RSA key fingerprint is e5:8b:c6:dc:e2:18:18:09:36:63:d9:63:dd:03:d9:cc
    Do you want to continue? {y|n}::[n] y
    Enter the password: <enter switch password>
    Enter the password again: <enter switch password>
    Enter the switch name: cs2
    RSA key fingerprint is 57:49:86:a1:b9:80:6a:61:9a:86:8e:3c:e3:b7:1f:b1
    Do you want to continue? {y|n}:: [n] y
    Followed by: system switch ethernet log enable-collection
    cluster1::*> system switch ethernet log enable-collection
    Do you want to enable cluster log collection for all nodes in the cluster?
    {y|n}: [n] y
    Enabling cluster switch log collection.
    cluster1::*>
  4. For ONTAP 9.5P15, 9.6P11, 9.7P8 and later patch releases, enable the cluster switch health monitor log collection feature for collecting switch-related log files, using the commands:
    system cluster-switch log setup-password and system cluster-switch log enable-collection
    Enter: system cluster-switch log setup-password
    cluster1::*> system cluster-switch log setup-password
    cs1
    cs2
    Followed by: system cluster-switch log enable-collection
    cluster1::*> system cluster-switch log enable-collection
    {y|n}: [n] y
    Note The log collect command is not available at this time. See Bug 1225042 for further details.
    Caution If any of these commands return an error, contact NetApp support.
