Edit the Reference Configuration File (RCF)
Contributors netapp-pcarriga netapp-martyh netapp-yvonneo
In order to activate newly licensed ports, you need to edit the latest version of the RCF and uncomment the applicable port details. The default license activates ports 0/1 to 0/16 and 0/55 to 0/56 while the newly licensed ports will be between ports 0/17 to 0/54 depending on the type and number of licenses available.
Note If you try to edit a previously installed RCF, the process might fail because there is an existing configuration for other areas in the RCF, see Edit a previously installed RCF file.
For details of the available license types for use on the BES-53248 cluster switch, see Installing licenses for BES-53248 cluster switches.
For example to activate the SW-BES54248-40-100G-LIC license, you must uncomment the following section in the RCF:
! 2-port or 6-port 40/100GbE node port license block
interface 0/49
no shutdown
description "40/100GbE Node Port"
!speed 100G full-duplex
speed 40G full-duplex
service-policy in WRED_100G
spanning-tree edgeport
mtu 9216
switchport mode trunk
datacenter-bridging
priority-flow-control mode on
priority-flow-control priority 5 no-drop
exit
exit
interface 0/50
no shutdown
mtu 9216
datacenter-bridging
exit
exit
interface 0/51
no shutdown
!speed 40G full-duplex
mtu 9216
datacenter-bridging
exit
exit
interface 0/52
no shutdown
mtu 9216
datacenter-bridging
exit
exit
interface 0/53
no shutdown
mtu 9216
datacenter-bridging
exit
exit
interface 0/54
no shutdown
mtu 9216
datacenter-bridging
exit
exit
Note For high-speed ports between 0/49 to 0/54 inclusive, uncomment each port but only uncomment one speed line in the RCF for each of these ports, either:
  • speed 100G full-duplex
  • speed 40G full-duplex
as shown in the example.
For low-speed ports between 0/17 to 0/48 inclusive, uncomment the entire 8-port section when an appropriate license has been activated.
After you edit a previously installed RCF file and run the script apply command, you might get the following error message:
(CS1)# script apply BES-53248_RCF_v1.6-Cluster-HA.scr
Are you sure you want to apply the configuration script? (y/n) y
After you select y, you get the following error message:
config
 match cos 5
 Unrecognized command : match cos 5
 Error! in configuration script file at line number 40.
 CLI Command :: match cos 5.
 Aborting script.
To avoid or resolve this issue, you can choose one of the following options:
