Enable SSH on BES-53248 cluster switches
Contributors netapp-martyh
SSH is a requirement when using the Cluster Switch Health Monitor (CSHM) and log collection features. To enable SSH on BES-53248 cluster switches, you generate the SSH keys first and then enable SSH.
Steps
  1. Generate the SSH keys:
    crypto key generate
    (switch) #**show ip ssh**
    SSH Configuration
    Administrative Mode: .......................... Disabled
    SSH Port: ..................................... 22
    Protocol Level: ............................... Version 2
    SSH Sessions Currently Active: ................ 0
    Max SSH Sessions Allowed: ..................... 5
    SSH Timeout (mins): ........................... 5
    Keys Present: ................................. DSA(1024) RSA(1024) ECDSA(521)
    Key Generation In Progress: ................... None
    SCP server Administrative Mode: ............... Disabled
    (switch) #**config**
    (switch) (Config)#**crypto key generate rsa**
    Do you want to overwrite the existing RSA keys? (y/n):**y**
    (switch) (Config)#**crypto key generate dsa**
    Do you want to overwrite the existing DSA keys? (y/n):**y**
    (switch) (Config)#**crypto key generate ecdsa 521**
    Do you want to overwrite the existing ECDSA keys? (y/n):**y**
    (switch) (Config)#**exit**
  2. Enable SSH:
    ip ssh server enable
    (switch) #**ip ssh server enable**
    SSH Configuration
    Administrative Mode: .......................... Enabled
    (switch) #
