Install licenses for BES-53248 cluster switches
Contributors netapp-yvonneo netapp-martyh
The BES-53248 cluster switch base model is licensed for 16 10GbE or 25GbE ports and two 100GbE ports. New ports can be added by purchasing more licenses.
The following licenses are available for use on the BES-53248 cluster switch:
License type License details
Supported firmware version
SW-BES-53248A1-G1-8P-LIC
Broadcom 8P 10-25,2P40-100 License Key, X190005/R
EFOS 3.4.3.3 and later
SW-BES-53248A1-G1-16P-LIC
Broadcom 16P 10-25,4P40-100 License Key, X190005/R
SW-BES-53248A1-G1-24P-LIC
Broadcom 24P 10-25,6P40-100 License Key, X190005/R
SW-BES54248-40-100G-LIC
Broadcom 6Port 40G100G License Key, X190005/R
EFOS 3.4.4.6 and later
SW-BES53248-8P-10G25G-LIC
Broadcom 8Port 10G25G License Key, X190005/R
SW-BES53248-16P-1025G-LIC
Broadcom 16Port 10G25G License Key, X190005/R
SW-BES53248-24P-1025G-LIC
Broadcom 24Port 10G25G License Key, X190005/R
Steps
  1. Connect the cluster switch to the management network.
  2. Use the ping command to verify connectivity to the server hosting EFOS, licenses, and the RCF file.
    This example verifies that the switch is connected to the server at IP address 172.19.2.1:
    (cs2)# ping 172.19.2.1
    Pinging 172.19.2.1 with 0 bytes of data:
    Reply From 172.19.2.1: icmp_seq = 0. time= 5910 usec.
  3. Check the current license usage on switch cs2:
    show license
    (cs2)# show license
    Reboot needed.................................. No
    Number of active licenses...................... 0
    License Index  License Type     Status
    No license file found.
  4. Install the license file. The following example uses SFTP to copy a license file to a key index 1.
    Repeat this step to load more licenses and to use different key index numbers.
    (cs2)# copy sftp://root@172.19.2.1/var/lib/tftpboot/license.dat nvram:license-key 1
    Remote Password:**
    Mode........................................... SFTP
    Set Server IP.................................. 172.19.2.1
    Path........................................... /var/lib/tftpboot/
    Filename....................................... license.dat
    Data Type...................................... license
    Management access will be blocked for the duration of the transfer
    Are you sure you want to start? (y/n) y
    File transfer in progress. Management access will be blocked for the duration of the transfer. Please wait...
    License Key transfer operation completed successfully. System reboot is required.
  5. Display all current license information and note the license status before switch cs2 is rebooted:
    show license
    (cs2)# show license
    Reboot needed.................................. Yes
    1              Port              License valid but not applied
  6. Display all licensed ports:
    show port all | exclude Detach
    The ports from the additional license files are not displayed until after the switch is rebooted.
    (cs2)# show port all \| exclude Detach
                     Admin     Physical   Physical   Link   Link    LACP   Actor
    Intf      Type   Mode      Mode       Status     Status Trap    Mode   Timeout
    0/1              Disable   Auto                  Down   Enable  Enable long
    0/2              Disable   Auto                  Down   Enable  Enable long
    0/3              Disable   Auto                  Down   Enable  Enable long
    0/4              Disable   Auto                  Down   Enable  Enable long
    0/5              Disable   Auto                  Down   Enable  Enable long
    0/6              Disable   Auto                  Down   Enable  Enable long
    0/7              Disable   Auto                  Down   Enable  Enable long
    0/8              Disable   Auto                  Down   Enable  Enable long
    0/9              Disable   Auto                  Down   Enable  Enable long
    0/10             Disable   Auto                  Down   Enable  Enable long
    0/11             Disable   Auto                  Down   Enable  Enable long
    0/12             Disable   Auto                  Down   Enable  Enable long
    0/13             Disable   Auto                  Down   Enable  Enable long
    0/14             Disable   Auto                  Down   Enable  Enable long
    0/15             Disable   Auto                  Down   Enable  Enable long
    0/16             Disable   Auto                  Down   Enable  Enable long
    0/55             Disable   Auto                  Down   Enable  Enable long
    0/56             Disable   Auto                  Down   Enable  Enable long
  7. Reboot the switch:
    reload
    (cs2)# reload
    The system has unsaved changes.
    Would you like to save them now? (y/n) y
    Config file 'startup-config' created successfully .
    Configuration Saved!
    Are you sure you would like to reset the system? (y/n) y
  8. Check that the new license is active and note that the license has been applied:
    show license
    (cs2)# show license
    Number of installed licenses................... 1
    Total Downlink Ports enabled................... 16
    Total Uplink Ports enabled..................... 8
    1              Port                      License applied
  9. Check that all new ports are available:
    0/49             Disable   100G Full             Down   Enable  Enable long
    0/50             Disable   100G Full             Down   Enable  Enable long
    0/51             Disable   100G Full             Down   Enable  Enable long
    0/52             Disable   100G Full             Down   Enable  Enable long
    0/53             Disable   100G Full             Down   Enable  Enable long
    0/54             Disable   100G Full             Down   Enable  Enable long
    0/55             Disable   100G Full             Down   Enable  Enable long
    0/56             Disable   100G Full             Down   Enable  Enable long
Caution When installing additional licenses, you must configure the new interfaces manually. Re-applying an RCF to an existing working production switch is not advisable.
