BES-53248 cluster switch port assignments - BES-53248 switches
Contributors netapp-martyh
You can use the BES-53248 cluster switch port assignment table as a guide to configure your cluster.
Switch ports Ports usage
01 - 16
10/25GbE cluster node ports, base configuration
17 - 48
10/25GbE cluster node ports, with licenses
49 - 54
40/100GbE cluster node ports, with licenses, added right to left
55 - 56
100GbE cluster Inter-Switch Link (ISL) ports, base configuration
Port group speed constraint
On BES-53248 cluster switches, the 48 10/25GbE (SFP28/SFP+) ports are combined into 12 x 4-port groups as follows:
  • Ports 1-4, 5-8, 9-12, 13-16, 17-20, 21-24, 25-28, 29-32, 33-36, 37-40, 41-44, and 45-48.
The SFP28/SFP+ port speed must be the same (10GbE or 25GbE) across all ports in the 4-port group.
