BES-53248 cluster switch required documentation
Contributors netapp-martyh netapp-yvonneo
You need specific switch and controller documentation to set up your Cluster-Mode configuration.
Required documentation for BES-53248 cluster switches
To set up the BES-53248 cluster switch, you need the following documents available from the Broadcom Support Site: Broadcom Ethernet Switch Product Line
Document title Description
EFOS Administrator’s Guide v3.4.3
Provides examples of how to use the BES-53248 switch in a typical network.
EFOS CLI Command Reference v3.4.3
Describes the command-line interface (CLI) commands you use to view and configure the BES-53248 software.
EFOS Getting Started Guide v3.4.3
Provides detailed information about for the BES-53248 switch.
EFOS SNMP Reference Guide v3.4.3
EFOS Scaling Parameters and Values v3.4.3
Describes the default scaling parameters with which EFOS software is delivered and validated on the supported platforms.
EFOS Functional Specifications v3.4.3
Describes the specifications for the EFOS software on the supported platforms.
EFOS Release Notes v3.4.3
Provides release-specific information about BES-53248 software.
Required documentation for supported ONTAP systems
To set up an ONTAP system, you need the following documents from the NetApp Support Site at mysupport.netapp.com
Name Description
Describes the power and site requirements for all NetApp hardware, including system cabinets.
Controller-specific Installation and Setup Instructions
Describes how to install NetApp hardware.
ONTAP 9
Provides detailed information about all aspects of the ONTAP 9 release.
