BES-53248 cluster switch configuration requirements
Contributors netapp-martyh netapp-yvonneo
To configure your cluster, you need the appropriate number and type of cables and cable connectors for your cluster switches. Depending on the type of cluster switch you are initially configuring, you need to connect to the switch console port with the included console cable and you need specific network information.
BES-53248 cluster switch port assignments
You can use the Broadcom-supported BES-53248 cluster switch port assignments table as a guide to configuring your cluster.
Switch ports Ports usage
01-16
10/25GbE cluster port nodes, base configuration
17-48
10/25GbE cluster port nodes, with licenses
49-54
100GbE cluster port nodes, with licenses, added right to left
55-56
100GbE cluster Inter-Switch Link (ISL) ports, base configuration
Port group speed constraint
On BES-53248 cluster switches, the 48 10/25GbE (SFP28/SFP+) ports are combined into 12 x 4-port groups as follows:
  • Ports 1-4, 5-8, 9-12, 13-16, 17-20, 21-24, 25-28, 29-32, 33-36, 37-40, 41-44, and 45-48.
The SFP28/SFP+ port speed must be the same (10GbE or 25GbE) across all ports in the 4-port group.
