Reset the Broadcom BES-53248 cluster switch to factory defaults
Reset the Broadcom BES-53248 cluster switch to factory defaults by erasing the current switch configuration and restoring the switch to its original settings.
About this task
You must be connected to the switch using the serial console.
This task resets the configuration of the management network.
Steps
Change to the elevated command prompt.
(cs2)> enable (cs2)#
Erase the startup configuration.
erase startup-config(cs2)# erase startup-config Are you sure you want to clear the configuration? (y/n) y
Reboot the switch.
(cs2)# reload Are you sure you would like to reset the system? (y/n) y
If the system asks whether to save the unsaved or changed configuration before reloading the switch, select No. |
