Cisco Nexus 3132Q-V switches
Contributors netapp-aoife netapp-yvonneo netapp-martyh
You can use the Cisco Nexus 3132Q-V switches as cluster switches in your AFF or FAS cluster.
  • You can install NX-OS and reference configuration files (RCFs) on the Cisco Nexus 3132Q-V cluster switch.
  • You can migrate from a two-node switchless cluster environment to a two-node switched environment using Cisco Nexus 3132Q-V cluster switches.
  • You can replace a defective Cisco Nexus 3132Q-V switch in a cluster and download the switch operating system and reference configuration file.
  • You can replace Cisco Nexus 5596, Nexus 5020, or Nexus 5010 cluster switches with Cisco Nexus 3132Q-V switches.
  • You can replace NetApp CN1610 switches with Cisco Nexus 3132Q-V cluster switches.
Available documentation
The following table lists the documentation available for the Cisco Nexus 3132Q-V switches.
Title
Describes how to install the pass-through panel in system cabinets where power connectors are at the front of the chassis and power distribution units are located in the rear of the chassis.
Describes how to setup and configure your Cisco Nexus 3132Q-V cluster switches.
Describes how to install NX-OS and reference configuration files (RCFs) on Nexus 3132Q-V cluster switch.
Describes how to migrate from environments that use older Cisco switches to environments that use Cisco 3132Q-V switches.
Describes the procedure to replace a CN1610 switch with a Cisco Nexus 3132Q-V cluster switch.
Describes how to migrate from a two-node switchless cluster environment to a two-node switched environment using Cisco Nexus 3132Q-V cluster switches.
Describes the procedure to replace a defective Cisco Nexus 3132Q-V switch in a cluster and download the switch operating system and reference configuration file.
