Complete the Cisco Nexus 3132Q-V cabling worksheet
Complete the cabling worksheet for Cisco Nexus 3132Q-V cluster switches to document port connections and supported platform configurations.
The sample cabling worksheet provides examples of recommended port assignments from the switches to the controllers. The blank worksheet provides a template that you can use in setting up your cluster.
Each switch can be configured as a single 40GbE port or 4 x 10GbE ports.
Sample cabling worksheet
The sample port definition on each pair of switches is as follows:
| Cluster switch A | Cluster switch B | ||
Switch port |
Node and port usage |
Switch port |
1 |
4x10G/40G node |
1 |
4x10G/40G node |
2 |
4x10G/40G node |
2 |
4x10G/40G node |
3 |
4x10G/40G node |
3 |
4x10G/40G node |
4 |
4x10G/40G node |
4 |
4x10G/40G node |
5 |
4x10G/40G node |
5 |
4x10G/40G node |
6 |
4x10G/40G node |
6 |
4x10G/40G node |
7 |
4x10G/40G node |
7 |
4x10G/40G node |
8 |
4x10G/40G node |
8 |
4x10G/40G node |
9 |
4x10G/40G node |
9 |
4x10G/40G node |
10 |
4x10G/40G node |
10 |
4x10G/40G node |
11 |
4x10G/40G node |
11 |
4x10G/40G node |
12 |
4x10G/40G node |
12 |
4x10G/40G node |
13 |
4x10G/40G node |
13 |
4x10G/40G node |
14 |
4x10G/40G node |
14 |
4x10G/40G node |
15 |
4x10G/40G node |
15 |
4x10G/40G node |
16 |
4x10G/40G node |
16 |
4x10G/40G node |
17 |
4x10G/40G node |
17 |
4x10G/40G node |
18 |
4x10G/40G node |
18 |
4x10G/40G node |
19 |
40G node 19 |
19 |
40G node 19 |
20 |
40G node 20 |
20 |
40G node 20 |
21 |
40G node 21 |
21 |
40G node 21 |
22 |
40G node 22 |
22 |
40G node 22 |
23 |
40G node 23 |
23 |
40G node 23 |
24 |
40G node 24 |
24 |
40G node 24 |
25 through 30 |
Reserved |
25 through 30 |
Reserved |
31 |
40G ISL to switch B port 31 |
31 |
40G ISL to switch A port 31 |
32 |
40G ISL to switch B port 32 |
32 |
40G ISL to switch A port 32 |
Blank cabling worksheet
You can use the blank cabling worksheet to document the platforms that are supported as nodes in a cluster. The Supported Cluster Connections section of the Hardware Universe defines the cluster ports used by the platform.
Switch port |
Node/port usage |
Switch port |
Node/port usage |
1 |
1 |
2 |
2 |
3 |
3 |
4 |
4 |
5 |
5 |
6 |
6 |
7 |
7 |
8 |
8 |
9 |
9 |
10 |
10 |
11 |
11 |
12 |
12 |
13 |
13 |
14 |
14 |
15 |
15 |
16 |
16 |
17 |
17 |
18 |
18 |
19 |
19 |
20 |
20 |
21 |
21 |
22 |
22 |
23 |
23 |
24 |
24 |
25 through 30 |
Reserved |
25 through 30 |
Reserved |
31 |
31 |
32 |
32 |
After you've completed your cabling worksheets, you install the switch.
