Install NX-OS software and RCFs on Cisco Nexus 3132Q-V cluster switches
The Cisco NX-OS software and reference configuration files (RCFs) must be installed on Cisco Nexus 3132Q-V cluster switches.
The following conditions must exist before you install the NX-OS software and Reference Configurations Files (RCFs) on the cluster switch:
The cluster must be fully functioning (there should be no errors in the logs or similar issues).
You must have checked or set your desired boot configuration in the RCF to reflect the desired boot images if you are installing only NX-OS and keeping your current RCF version.
If you need to change the boot configuration to reflect the current boot images, you must do so before reapplying the RCF so that the correct version is instantiated on future reboots.
You must have a console connection to the switch, required when installing the RCF.
You must have consulted the switch compatibility table on the Cisco Ethernet switch page for the supported ONTAP, NX-OS, and RCF versions.
There can be command dependencies between the command syntax in the RCF and that found in versions of NX-OS.
You must have referred to the appropriate software and upgrade guides available on the Cisco web site for complete documentation on the Cisco switch upgrade and downgrade procedures on Cisco Nexus 3000 Series Switches.
You must have the current RCF.
The examples in this procedure use two nodes. These nodes use two 10GbE cluster interconnect ports e0a
and e0b
See the Hardware Universe to verify the correct cluster ports on your platforms.
The command outputs might vary depending on different releases of ONTAP. |
The examples in this procedure use the following switch and node nomenclature:
The names of the two Cisco switches are
cs1
andcs2
The node names are
cluster1-01
andcluster1-02
The cluster LIF names are
cluster1-01_clus1
andcluster1-01_clus2
for cluster1-01 andcluster1-02_clus1
andcluster1-02_clus2
for cluster1-02. -
The
cluster1::*>
prompt indicates the name of the cluster.
The procedure requires the use of both ONTAP commands and Cisco Nexus 3000 Series Switches commands; ONTAP commands are used unless otherwise indicated. |
If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message:
system node autosupport invoke -node * -type all -message MAINT=x h
where x is the duration of the maintenance window in hours.
The AutoSupport message notifies technical support of this maintenance task so that automatic case creation is suppressed during the maintenance window. -
Change the privilege level to advanced, entering y when prompted to continue:
set -privilege advanced
The advanced prompt (
) appears. -
Display how many cluster interconnect interfaces are configured in each node for each cluster interconnect switch:
network device-discovery show -protocol cdp
cluster1::*> network device-discovery show -protocol cdp Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform ----------- ------ ------------------------- ----------------- -------- cluster1-02/cdp e0a cs1 Eth1/2 N3K-C3132Q-V e0b cs2 Eth1/2 N3K-C3132Q-V cluster1-01/cdp e0a cs1 Eth1/1 N3K-C3132Q-V e0b cs2 Eth1/1 N3K-C3132Q-V 4 entries were displayed.
Check the administrative or operational status of each cluster interface.
Display the network port attributes:
network port show –ipspace Cluster
cluster1::*> network port show -ipspace Cluster Node: cluster1-02 Speed(Mbps) Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status --------- ------------ ---------------- ---- ---- ----------- ------ e0a Cluster Cluster up 9000 auto/10000 healthy e0b Cluster Cluster up 9000 auto/10000 healthy Node: cluster1-01 Speed(Mbps) Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status --------- ------------ ---------------- ---- ---- ----------- ------ e0a Cluster Cluster up 9000 auto/10000 healthy e0b Cluster Cluster up 9000 auto/10000 healthy 4 entries were displayed.
Display information about the LIFs:
network interface show -vserver Cluster
cluster1::*> network interface show -vserver Cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ------------------ ---------- ------------------ ------------- ------- ---- Cluster cluster1-01_clus1 up/up 169.254.209.69/16 cluster1-01 e0a true cluster1-01_clus2 up/up 169.254.49.125/16 cluster1-01 e0b true cluster1-02_clus1 up/up 169.254.47.194/16 cluster1-02 e0a true cluster1-02_clus2 up/up 169.254.19.183/16 cluster1-02 e0b true 4 entries were displayed.
Ping the remote cluster LIFs:
cluster ping-cluster -node node-name
cluster1::*> cluster ping-cluster -node cluster1-02 Host is cluster1-02 Getting addresses from network interface table... Cluster cluster1-01_clus1 169.254.209.69 cluster1-01 e0a Cluster cluster1-01_clus2 169.254.49.125 cluster1-01 e0b Cluster cluster1-02_clus1 169.254.47.194 cluster1-02 e0a Cluster cluster1-02_clus2 169.254.19.183 cluster1-02 e0b Local = 169.254.47.194 169.254.19.183 Remote = 169.254.209.69 169.254.49.125 Cluster Vserver Id = 4294967293 Ping status: .... Basic connectivity succeeds on 4 path(s) Basic connectivity fails on 0 path(s) ................ Detected 9000 byte MTU on 4 path(s): Local 169.254.19.183 to Remote 169.254.209.69 Local 169.254.19.183 to Remote 169.254.49.125 Local 169.254.47.194 to Remote 169.254.209.69 Local 169.254.47.194 to Remote 169.254.49.125 Larger than PMTU communication succeeds on 4 path(s) RPC status: 2 paths up, 0 paths down (tcp check) 2 paths up, 0 paths down (udp check)
Verify that the
auto-revert
command is enabled on all cluster LIFs:network interface show -vserver Cluster -fields auto-revert
cluster1::*> network interface show -vserver Cluster -fields auto-revert Logical Vserver Interface Auto-revert --------- ––––––-------------- ------------ Cluster cluster1-01_clus1 true cluster1-01_clus2 true cluster1-02_clus1 true cluster1-02_clus2 true 4 entries were displayed.
For ONTAP 9.8 and later, enable the Ethernet switch health monitor log collection feature for collecting switch-related log files by using the commands:
system switch ethernet log setup-password
system switch ethernet log enable-collection
cluster1::*> system switch ethernet log setup-password Enter the switch name: <return> The switch name entered is not recognized. Choose from the following list: cs1 cs2 cluster1::*> system switch ethernet log setup-password Enter the switch name: cs1 RSA key fingerprint is e5:8b:c6:dc:e2:18:18:09:36:63:d9:63:dd:03:d9:cc Do you want to continue? {y|n}::[n] y Enter the password: <enter switch password> Enter the password again: <enter switch password> cluster1::*> system switch ethernet log setup-password Enter the switch name: cs2 RSA key fingerprint is 57:49:86:a1:b9:80:6a:61:9a:86:8e:3c:e3:b7:1f:b1 Do you want to continue? {y|n}:: [n] y Enter the password: <enter switch password> Enter the password again: <enter switch password> cluster1::*> system switch ethernet log enable-collection Do you want to enable cluster log collection for all nodes in the cluster? {y|n}: [n] y Enabling cluster switch log collection. cluster1::*>
If any of these commands return an error, contact NetApp support. -
For ONTAP releases 9.5P16, 9.6P12, and 9.7P10 and later patch releases, enable the Ethernet switch health monitor log collection feature for collecting switch-related log files by using the commands:
system cluster-switch log setup-password
system cluster-switch log enable-collection
cluster1::*> system cluster-switch log setup-password Enter the switch name: <return> The switch name entered is not recognized. Choose from the following list: cs1 cs2 cluster1::*> system cluster-switch log setup-password Enter the switch name: cs1 RSA key fingerprint is e5:8b:c6:dc:e2:18:18:09:36:63:d9:63:dd:03:d9:cc Do you want to continue? {y|n}::[n] y Enter the password: <enter switch password> Enter the password again: <enter switch password> cluster1::*> system cluster-switch log setup-password Enter the switch name: cs2 RSA key fingerprint is 57:49:86:a1:b9:80:6a:61:9a:86:8e:3c:e3:b7:1f:b1 Do you want to continue? {y|n}:: [n] y Enter the password: <enter switch password> Enter the password again: <enter switch password> cluster1::*> system cluster-switch log enable-collection Do you want to enable cluster log collection for all nodes in the cluster? {y|n}: [n] y Enabling cluster switch log collection. cluster1::*>
