Install and maintain
Install the RCF on Cisco Nexus 3232C storage switches
Contributors netapp-yvonneo netapp-jsnyder
Install the reference configuration file (RCF) on Cisco Nexus 3232C storage switches after initial setup. The RCF defines port assignments and network settings required for storage network operation.
Before you begin
Verify the following installations and connections:
  • A current backup of the switch configuration.
  • A fully functioning cluster (no errors in the logs or similar issues).
  • The current RCF.
  • A console connection to the switch, this is required when installing the RCF.
About this task
The procedure requires the use of both ONTAP commands and Cisco Nexus 3000 Series Switches commands; ONTAP commands are used unless otherwise indicated.
Complete the procedure in Prepare to install NX-OS and RCF, and then follow the steps below.
Step 1: Install the RCF on the switches
  1. Login to switch s2 using SSH or by using a serial console.
  2. Copy the RCF to the bootflash of switch s2 using one of the following transfer protocols: FTP, TFTP, SFTP, or SCP. For more information on Cisco commands, see the appropriate guide in the Cisco Nexus 3000 Series NX-OS Command Reference.
    Show example
    This example shows TFTP being used to copy an RCF to the bootflash on switch s2:
    s2# copy tftp: bootflash: vrf management
    Enter source filename: NX3232C-RCF-v1.13-1-Storage.txt
    Enter hostname for the tftp server: 172.22.201.50
    Trying to connect to tftp server......Connection to Server Established.
    TFTP get operation was successful
    Copy complete, now saving to disk (please wait)...
  3. Apply the RCF previously downloaded to the bootflash.
    Show example
    This example shows the RCF file NX9336C-FX2-RCF-v1.13-1-Storage.txt being installed on switch s2:
    s2# copy NX9336C-FX2-RCF-v1.13-1-Storage.txt running-config echo-commands
    Note
    Make sure to read thoroughly the Installation notes, Important Notes, and banner sections of your RCF. You must read and follow these instructions to verify the proper configuration and operation of the switch.
  4. Examine the banner output from the show banner motd command. You must read and follow the instructions under Important Notes to make sure the proper configuration and operation of the switch.
  5. Verify that the RCF is the correct newer version:
    show running-config
    When you check the output to verify you have the correct RCF, make sure that the following information is correct:
    • The RCF banner
    • The node and port settings
    • Customizations
      The output varies according to your site configuration. Check the port settings and refer to the release notes for any changes specific to the RCF that you have installed.
  6. Reapply any previous customizations to the switch configuration.
  7. After you verify that the RCF versions and switch settings are correct, copy the running-config file to the startup-config file.
    s2# copy running-config startup-config [] 100% Copy complete
  8. Reboot switch s2:
    s2# reload
    This command will reboot the system. (y/n)? [n] y
  9. Repeat Steps 1 to 8 on switch s1.
  10. Connect the node storage ports and storage shelf ports of all nodes in the ONTAP cluster to switches s1 and s2.
Step 2: Verify the switch connections
  1. Verify that the switch ports are up.
    show interface brief
  2. Verify that the node storage ports and storage shelf ports are in their correct VLANs using the following commands:
    show vlan brief
    show interface trunk
Step 3: Set up your ONTAP cluster
NetApp recommends that you use System Manager to set up new clusters.
System Manager provides a simple and easy workflow for cluster set up and configuration including assigning a node management IP address, initializing the cluster, creating a local tier, configuring protocols, and provisioning initial storage.
Refer to Configure ONTAP on a new cluster with System Manager for setup instructions.
What's next?
After you've installed the RCF, you can verify the SSH configuration.
