Reset the Cisco Nexus 3232C storage switch to factory defaults
Reset the Cisco Nexus 3232C storage switch to factory defaults by erasing the current switch configuration and restoring the switch to its original settings.
About this task
You must be connected to the switch using the serial console.
This task resets the configuration of the management network.
Steps
Erase the existing configuration:
write erase(s2)# write erase Warning: This command will erase the startup-configuration. Do you wish to proceed anyway? (y/n) [n] y
Reload the switch software:
reload(s2)# reload This command will reboot the system. (y/n)? [n] y
The system reboots and enters the configuration wizard. During the boot, if you receive the prompt “Abort Auto Provisioning and continue with normal setup? (yes/no)[n]”, you should respond yes to proceed.
What's next
After resetting the switch, you can reconfigure it according to your requirements.
