Cisco Nexus 3232C switches
You can use Cisco Nexus 3232C switches as cluster switches in your AFF or FAS cluster.
You can install the switch, migrate from an existing switch, replace a switch, and update the RCF files on the switch.
You can install NX-OS and reference configuration files (RCF’s) on the Cisco Nexus 3232C cluster switch.
You can migrate from a two-node switchless cluster to a cluster with Cisco Nexus 3232C cluster switches.
You can replace a Cisco Nexus 3232C cluster or storage switch.
You can install the Cisco Nexus 3232C switch (X190100) NetApp system cabinet with the custom brackets that come with the switch, or you can install it in a rack with the standard brackets that are also included with the switch.
The following table lists the documentation available for the Cisco Nexus 3232C switches.
Title |
Description |
Describes how to install the pass-through panel in system cabinets where power connectors are at the front of the chassis and power distribution units are located in the rear of the chassis. |
Describes how to setup and configure your Cisco Nexus 3232C cluster switches. |
Describes how to install NX-OS and reference configuration files (RCFs) on Nexus 3232C cluster switch. |
Describes how to migrate from environments that use older Cisco switches to environments that use Cisco 3232C switches. |
Describes the procedure to replace a CN1610 switch with a Cisco Nexus 3232C cluster switch. |
Describes how to migrate from a two-node switchless cluster environment to a two-node switched environment using Cisco Nexus 3232C cluster switches. |
Describes the procedure to replace a defective Cisco Nexus 3232C switch in a cluster and download the switch operating system and reference configuration file. |
Describes the procedure to replace a defective Cisco Nexus 3232C storage switch and download the switch operating system and reference configuration file. |
