Migrate a CN1610 switch to a Cisco Nexus 3232C cluster switch
Contributors netapp-martyh
You must be aware of certain configuration information, port connections, and cabling requirements when you replace CN1610 cluster switches with Cisco Nexus 3232C cluster switches.
The cluster switches support the following node connections:
  • NetApp CN1610: ports 0/1 through 0/12 (10 GbE)
  • Cisco Nexus 3232C: ports e1/1-30 (40 or 100 or 4x10GbE)
The cluster switches use the following inter-switch link (ISL) ports.
  • NetApp CN1610: ports 0/13 through 0/16 (10 GbE)
  • Cisco Nexus 3232C: ports 1/31-32 (100GbE)
Note
You must use 4x10G breakout cables on the Cisco Nexus 3232C cluster switch.
The following table shows the cabling connections that are required at each stage as you make the transition from NetApp CN1610 switches to Cisco Nexus 3232C cluster switches:
Stage Description Required cables
Initial
CN1610 to CN1610 (SFP+ to SFP+)
4 SFP+ optical fiber or copper direct-attach cables
Transition
CN1610 to 3232C (QSFP to SFP+)
1 QSFP and 4 SFP+ optical fiber or copper breakout cables
Final
3232C to 3232C (QSFP to QSFP)
2 QSFP optical fiber or copper direct-attach cables
You must have downloaded the applicable reference configuration files (RCFs). The number of 10 GbE and 40/100 GbE ports are defined in the RCFs available on the Cisco® Cluster Network Switch Reference Configuration File Download page.
The ONTAP and NX-OS versions that are supported in this procedure are listed on the Cisco Ethernet Switches page.
The ONTAP and FASTPATH versions that are supported in this procedure are listed on the NetApp CN1601 and CN1610 Switches page.
