Install and maintain
Installation and setup workflow for Cisco Nexus 3232C cluster switches
Contributors netapp-yvonneo netapp-jolieg netapp-jsnyder
Follow this workflow to install and configure Cisco Nexus 3232C cluster switches in an ONTAP environment. The 3232C supports ONTAP clusters with more than two nodes.
Follow these workflow steps to install and setup your to Cisco Nexus 3232C switch.
Review the configuration requirements for the 3232C cluster switch.
Review specific switch and controller documentation to set up your 3232C switches and the ONTAP cluster.
Review the requirements for the Cisco Smart Call Home feature, used to monitor the hardware and software components on your network.
Install the switch hardware.
Configure the switch software.
Configure switch health monitoring.
