Install the Reference Configuration File (RCF)
Contributors netapp-yvonneo netapp-martyh
You can install the RCF after setting up the Nexus 92300YC switch for the first time.
Steps
  1. Connect the cluster switch to the management network.
  2. Use the ping command to verify connectivity to the server hosting the RCF.
    This example verifies that the switch can reach the server at IP address 172.19.2.1:
    cs2# ping 172.19.2.1
    Pinging 172.19.2.1 with 0 bytes of data:
    Reply From 172.19.2.1: icmp_seq = 0. time= 5910 usec.
  3. Copy the RCF to the Nexus 92300YC switch:
    cs2# copy sftp: bootflash: vrf management
    Enter source filename: /code/Nexus_92300YC_RCF_v1.0.2.txt
    Enter hostname for the sftp server: 172.19.2.1
    Enter username: user1
    Outbound-ReKey for 172.19.2.1:22
    Inbound-ReKey for 172.19.2.1:22
    user1@172.19.2.1's password:
    sftp> progress
    Progress meter enabled
    sftp> get   /code/Nexus_92300YC_RCF_v1.0.2.txt  /bootflash/nxos.9.2.2.bin
    /code/Nexus_92300YC_R  100% 9687   530.2KB/s   00:00
    sftp> exit
    Copy complete, now saving to disk (please wait)...
    Copy complete.
  4. Merge the RCF with the running-config of the switch:
    cs2# copy bootflash:Nexus_92300YC_RCF_v1.0.2.txt running-config
    Disabling ssh: as its enabled right now:
     generating ecdsa key(521 bits)......
    generated ecdsa key
    Enabling ssh: as it has been disabled
     this command enables edge port type (portfast) by default on all interfaces. You
     should now disable edge port type (portfast) explicitly on switched ports leading to hubs,
     switches and bridges as they may create temporary bridging loops.
    Edge port type (portfast) should only be enabled on ports connected to a single
     host. Connecting hubs, concentrators, switches, bridges, etc...  to this
     interface when edge port type (portfast) is enabled, can cause temporary bridging loops.
     Use with CAUTION
    Edge Port Type (Portfast) has been configured on Ethernet1/1 but will only
     have effect when the interface is in a non-trunking mode.
    Copy complete.
  5. Verify on the switch that the RCF has been merged successfully:
    show running-config
    cs2# show running-config
    !Command: show running-config
    !Running configuration last done at: Wed Apr 10 06:32:27 2019
    !Time: Wed Apr 10 06:36:00 2019
    version 9.2(2) Bios:version 05.33
    switchname cs2
    vdc cs2 id 1
      limit-resource vlan minimum 16 maximum 4094
      limit-resource vrf minimum 2 maximum 4096
      limit-resource port-channel minimum 0 maximum 511
      limit-resource u4route-mem minimum 248 maximum 248
      limit-resource u6route-mem minimum 96 maximum 96
      limit-resource m4route-mem minimum 58 maximum 58
      limit-resource m6route-mem minimum 8 maximum 8
    feature lacp
    no password strength-check
    username admin password 5 $5$HY9Kk3F9$YdCZ8iQJ1RtoiEFa0sKP5IO/LNG1k9C4lSJfi5kesl
    6  role network-admin
    ssh key ecdsa 521
    banner motd #
    *  Nexus 92300YC Reference Configuration File (RCF) v1.0.2 (10-19-2018)        *
    *  Ports 1/1  - 1/48: 10GbE Intra-Cluster Node Ports                           *
    *  Ports 1/49 - 1/64: 40/100GbE Intra-Cluster Node Ports                       *
    *  Ports 1/65 - 1/66: 40/100GbE Intra-Cluster ISL Ports                        *
  6. Save the running configuration so that it becomes the startup configuration when you reboot the switch:
    cs2# *copy running-config startup-config*
    [########################################] 100%
    Copy complete.
  7. For ONTAP 9.6P8 and later, enable the CSHM ASUP log collection feature for collecting switch-related log files: system cluster-switch log setup-password and system cluster-switch log enable-collection
    cs2# system cluster-switch log setup-password
     Output example required here
    cs2# system cluster-switch log enable-collection
     Output example required here too
  8. Reboot the switch and verify that the running configuration is correct:
    reload
    cs2# reload
    This command will reboot the system. (y/n)?  [n] y
