Configure a new Cisco Nexus 92300YC switch
Contributors netapp-yvonneo netapp-martyh
You can configure a new Nexus 92300YC switch by completing the steps detailed in this chapter.
Installing the Nexus 92300YC switch on systems running ONTAP 9.6 and later, starts with setting up an IP address and configuration to allow the switch to communicate through the management interface. You can then install the NX-OS software and reference configuration file (RCF). This procedure is intended for preparing the Nexus 92300YC switch before controllers are added.
The examples in this procedure use the following switch and node nomenclature:
  • The Nexus 92300YC switch names are cs1 and cs2.
  • The example used in this procedure starts the upgrade on the second switch, *cs2*.
  • The cluster LIF names are node1_clus1 and node1_clus2 for node1, and node2_clus1 and node2_clus2 for node2.
  • The IPspace name is Cluster.
  • The cluster1::*> prompt indicates the name of the cluster.
  • The cluster ports on each node are named e0a and e0b.
    See the Hardware Universe for the actual cluster ports supported on your platform.
  • The Inter-Switch Links (ISLs) supported for the Nexus 92300YC switches are ports 1/65 and 1/66.
  • The node connections supported for the Nexus 92300YC switches are ports 1/1 through 1/66.
  • The examples in this procedure use two nodes, but you can have up to 24 nodes in a cluster.
