Install NX-OS software on Cisco Nexus 92300YC cluster switches
Install the NX-OS software on Cisco Nexus 92300YC cluster switches to prepare them for cluster operation. NX-OS must be installed before you can configure the switch or install the RCF.
NX-OS is a network operating system for the Nexus series of Ethernet switches and MDS series of Fibre Channel (FC) storage area network switches provided by Cisco Systems.
Review requirements
The Inter-Switch Links (ISLs) supported for the Nexus 92300YC switches are ports 1/65 and 1/66.
The node connections supported for the Nexus 92300YC switches are ports 1/1 through 1/66.
Make sure you have the following:
Applicable NetApp Cisco NX-OS software for your switches from the NetApp Support Site, available from mysupport.netapp.com
A fully functioning cluster (no errors in the logs or similar issues).
Cisco Ethernet switch page. Consult the switch compatibility table for the supported ONTAP and NX-OS versions.
Install the software
The examples in this procedure use two nodes, but you can have up to 24 nodes in a cluster.
The examples in this procedure use the following switch and node nomenclature:
The Nexus 92300YC switch names are
cs1andcs2. -
The example used in this procedure starts the upgrade on the second switch, *cs2*.
The cluster LIF names are
node1_clus1andnode1_clus2for node1, andnode2_clus1andnode2_clus2for node2. -
The IPspace name is
Cluster. -
The
cluster1::*>prompt indicates the name of the cluster. -
The cluster ports on each node are named
e0aande0b.Refer to the Hardware Universe for the actual cluster ports supported on your platform. Refer to What additional information do I need to install my equipment that is not in HWU? for more information about switch installation requirements.
Connect the cluster switch to the management network.
Use the
pingcommand to verify connectivity to the server hosting the NX-OS software and the RCF.Show example
This example verifies that the switch can reach the server at IP address 172.19.2.1:
cs2# ping 172.19.2.1 Pinging 172.19.2.1 with 0 bytes of data: Reply From 172.19.2.1: icmp_seq = 0. time= 5910 usec.
Copy the NX-OS software and EPLD images to the Nexus 92300YC switch.
Show example
cs2# copy sftp: bootflash: vrf management Enter source filename: /code/nxos.9.2.2.bin Enter hostname for the sftp server: 172.19.2.1 Enter username: user1 Outbound-ReKey for 172.19.2.1:22 Inbound-ReKey for 172.19.2.1:22 user1@172.19.2.1's password: sftp> progress Progress meter enabled sftp> get /code/nxos.9.2.2.bin /bootflash/nxos.9.2.2.bin /code/nxos.9.2.2.bin 100% 1261MB 9.3MB/s 02:15 sftp> exit Copy complete, now saving to disk (please wait)... Copy complete. cs2# copy sftp: bootflash: vrf management Enter source filename: /code/n9000-epld.9.2.2.img Enter hostname for the sftp server: 172.19.2.1 Enter username: user1 Outbound-ReKey for 172.19.2.1:22 Inbound-ReKey for 172.19.2.1:22 user1@172.19.2.1's password: sftp> progress Progress meter enabled sftp> get /code/n9000-epld.9.2.2.img /bootflash/n9000-epld.9.2.2.img /code/n9000-epld.9.2.2.img 100% 161MB 9.5MB/s 00:16 sftp> exit Copy complete, now saving to disk (please wait)... Copy complete.
Verify the running version of the NX-OS software:
show versionShow example
cs2# show version Cisco Nexus Operating System (NX-OS) Software TAC support: http://www.cisco.com/tac Copyright (C) 2002-2018, Cisco and/or its affiliates. All rights reserved. The copyrights to certain works contained in this software are owned by other third parties and used and distributed under their own licenses, such as open source. This software is provided "as is," and unless otherwise stated, there is no warranty, express or implied, including but not limited to warranties of merchantability and fitness for a particular purpose. Certain components of this software are licensed under the GNU General Public License (GPL) version 2.0 or GNU General Public License (GPL) version 3.0 or the GNU Lesser General Public License (LGPL) Version 2.1 or Lesser General Public License (LGPL) Version 2.0. A copy of each such license is available at http://www.opensource.org/licenses/gpl-2.0.php and http://opensource.org/licenses/gpl-3.0.html and http://www.opensource.org/licenses/lgpl-2.1.php and http://www.gnu.org/licenses/old-licenses/library.txt. Software BIOS: version 05.31 NXOS: version 9.2(1) BIOS compile time: 05/17/2018 NXOS image file is: bootflash:///nxos.9.2.1.bin NXOS compile time: 7/17/2018 16:00:00 [07/18/2018 00:21:19] Hardware cisco Nexus9000 C92300YC Chassis Intel(R) Xeon(R) CPU D-1526 @ 1.80GHz with 16337884 kB of memory. Processor Board ID FDO220329V5 Device name: cs2 bootflash: 115805356 kB Kernel uptime is 0 day(s), 4 hour(s), 23 minute(s), 11 second(s) Last reset at 271444 usecs after Wed Apr 10 00:25:32 2019 Reason: Reset Requested by CLI command reload System version: 9.2(1) Service: plugin Core Plugin, Ethernet Plugin Active Package(s): cs2#
Install the NX-OS image.
Installing the image file causes it to be loaded every time the switch is rebooted.
Show example
cs2# install all nxos bootflash:nxos.9.2.2.bin Installer will perform compatibility check first. Please wait. Installer is forced disruptive Verifying image bootflash:/nxos.9.2.2.bin for boot variable "nxos". [] 100% -- SUCCESS Verifying image type. [] 100% -- SUCCESS Preparing "nxos" version info using image bootflash:/nxos.9.2.2.bin. [] 100% -- SUCCESS Preparing "bios" version info using image bootflash:/nxos.9.2.2.bin. [] 100% -- SUCCESS Performing module support checks. [] 100% -- SUCCESS Notifying services about system upgrade. [] 100% -- SUCCESS Compatibility check is done: Module bootable Impact Install-type Reason ------ -------- --------------- ------------ ------ 1 yes disruptive reset default upgrade is not hitless Images will be upgraded according to following table: Module Image Running-Version(pri:alt New-Version Upg-Required ------ -------- -------------------------------------- ------------------ ------------ 1 nxos 9.2(1) 9.2(2) yes 1 bios v05.31(05/17/2018):v05.28(01/18/2018) v05.33(09/08/2018) yes Switch will be reloaded for disruptive upgrade. Do you want to continue with the installation (y/n)? [n] y Install is in progress, please wait. Performing runtime checks. [] 100% -- SUCCESS Setting boot variables. [] 100% -- SUCCESS Performing configuration copy. [] 100% -- SUCCESS Module 1: Refreshing compact flash and upgrading bios/loader/bootrom. Warning: please do not remove or power off the module at this time. [] 100% -- SUCCESS 2019 Apr 10 04:59:35 cs2 %$ VDC-1 %$ %VMAN-2-ACTIVATION_STATE: Successfully deactivated virtual service 'guestshell+' Finishing the upgrade, switch will reboot in 10 seconds.
Verify the new version of NX-OS software after the switch has rebooted:
cs2# show version Cisco Nexus Operating System (NX-OS) Software TAC support: http://www.cisco.com/tac Copyright (C) 2002-2018, Cisco and/or its affiliates. All rights reserved. The copyrights to certain works contained in this software are owned by other third parties and used and distributed under their own licenses, such as open source. This software is provided "as is," and unless otherwise stated, there is no warranty, express or implied, including but not limited to warranties of merchantability and fitness for a particular purpose. Certain components of this software are licensed under the GNU General Public License (GPL) version 2.0 or GNU General Public License (GPL) version 3.0 or the GNU Lesser General Public License (LGPL) Version 2.1 or Lesser General Public License (LGPL) Version 2.0. A copy of each such license is available at http://www.opensource.org/licenses/gpl-2.0.php and http://opensource.org/licenses/gpl-3.0.html and http://www.opensource.org/licenses/lgpl-2.1.php and http://www.gnu.org/licenses/old-licenses/library.txt. Software BIOS: version 05.33 NXOS: version 9.2(2) BIOS compile time: 09/08/2018 NXOS image file is: bootflash:///nxos.9.2.2.bin NXOS compile time: 11/4/2018 21:00:00 [11/05/2018 06:11:06] Hardware cisco Nexus9000 C92300YC Chassis Intel(R) Xeon(R) CPU D-1526 @ 1.80GHz with 16337884 kB of memory. Processor Board ID FDO220329V5 Device name: cs2 bootflash: 115805356 kB Kernel uptime is 0 day(s), 0 hour(s), 3 minute(s), 52 second(s) Last reset at 182004 usecs after Wed Apr 10 04:59:48 2019 Reason: Reset due to upgrade System version: 9.2(1) Service: plugin Core Plugin, Ethernet Plugin Active Package(s):
Upgrade the EPLD image and reboot the switch.
Show example
cs2# show version module 1 epld EPLD Device Version --------------------------------------- MI FPGA 0x7 IO FPGA 0x17 MI FPGA2 0x2 GEM FPGA 0x2 GEM FPGA 0x2 GEM FPGA 0x2 GEM FPGA 0x2 cs2# install epld bootflash:n9000-epld.9.2.2.img module 1 Compatibility check: Module Type Upgradable Impact Reason ------ ----------------- ---------- ---------- ------ 1 SUP Yes disruptive Module Upgradable Retrieving EPLD versions.... Please wait. Images will be upgraded according to following table: Module Type EPLD Running-Version New-Version Upg-Required ------ ---- ------------- --------------- ----------- ------------ 1 SUP MI FPGA 0x07 0x07 No 1 SUP IO FPGA 0x17 0x19 Yes 1 SUP MI FPGA2 0x02 0x02 No The above modules require upgrade. The switch will be reloaded at the end of the upgrade Do you want to continue (y/n) ? [n] y Proceeding to upgrade Modules. Starting Module 1 EPLD Upgrade Module 1 : IO FPGA [Programming] : 100.00% ( 64 of 64 sectors) Module 1 EPLD upgrade is successful. Module Type Upgrade-Result ------ ------------------ -------------- 1 SUP Success EPLDs upgraded. Module 1 EPLD upgrade is successful. -
After the switch reboot, log in again and verify that the new version of EPLD loaded successfully.
Show example
cs2# *show version module 1 epld* EPLD Device Version --------------------------------------- MI FPGA 0x7 IO FPGA 0x19 MI FPGA2 0x2 GEM FPGA 0x2 GEM FPGA 0x2 GEM FPGA 0x2 GEM FPGA 0x2
After you've installed the NX-OS software, you can install the RCF.
