Complete the Cisco Nexus 92300YC cabling worksheet
Complete the cabling worksheet for Cisco Nexus 92300YC cluster switches to document port connections and supported platform configurations.
The sample cabling worksheet provides examples of recommended port assignments from the switches to the controllers. The blank worksheet provides a template that you can use in setting up your cluster.
Sample cabling worksheet
The sample port definition on each pair of switches is as follows:
| Cluster switch A | Cluster switch B | ||
Switch port |
Node and port usage |
Switch port |
1 |
10/25 GbE node |
1 |
10/25 GbE node |
2 |
10/25 GbE node |
2 |
10/25 GbE node |
3 |
10/25 GbE node |
3 |
10/25 GbE node |
4 |
10/25 GbE node |
4 |
10/25 GbE node |
5 |
10/25 GbE node |
5 |
10/25 GbE node |
6 |
10/25 GbE node |
6 |
10/25 GbE node |
7 |
10/25 GbE node |
7 |
10/25 GbE node |
8 |
10/25 GbE node |
8 |
10/25 GbE node |
9 |
10/25 GbE node |
9 |
10/25 GbE node |
10 |
10/25 GbE node |
10 |
10/25 GbE node |
11 |
10/25 GbE node |
11 |
10/25 GbE node |
12 |
10/25 GbE node |
12 |
10/25 GbE node |
13 |
10/25 GbE node |
13 |
10/25 GbE node |
14 |
10/25 GbE node |
14 |
10/25 GbE node |
15 |
10/25 GbE node |
15 |
10/25 GbE node |
16 |
10/25 GbE node |
16 |
10/25 GbE node |
17 |
10/25 GbE node |
17 |
10/25 GbE node |
18 |
10/25 GbE node |
18 |
10/25 GbE node |
19 |
10/25 GbE node |
19 |
10/25 GbE node |
20 |
10/25 GbE node |
20 |
10/25 GbE node |
21 |
10/25 GbE node |
21 |
10/25 GbE node |
22 |
10/25 GbE node |
22 |
10/25 GbE node |
23 |
10/25 GbE node |
23 |
10/25 GbE node |
24 |
10/25 GbE node |
24 |
10/25 GbE node |
25 |
10/25 GbE node |
25 |
10/25 GbE node |
26 |
10/25 GbE node |
26 |
10/25 GbE node |
27 |
10/25 GbE node |
27 |
10/25 GbE node |
28 |
10/25 GbE node |
28 |
10/25 GbE node |
29 |
10/25 GbE node |
29 |
10/25 GbE node |
30 |
10/25 GbE node |
30 |
10/25 GbE node |
31 |
10/25 GbE node |
31 |
10/25 GbE node |
32 |
10/25 GbE node |
32 |
10/25 GbE node |
33 |
10/25 GbE node |
33 |
10/25 GbE node |
34 |
10/25 GbE node |
34 |
10/25 GbE node |
35 |
10/25 GbE node |
35 |
10/25 GbE node |
36 |
10/25 GbE node |
36 |
10/25 GbE node |
37 |
10/25 GbE node |
37 |
10/25 GbE node |
38 |
10/25 GbE node |
38 |
10/25 GbE node |
39 |
10/25 GbE node |
39 |
10/25 GbE node |
40 |
10/25 GbE node |
40 |
10/25 GbE node |
41 |
10/25 GbE node |
41 |
10/25 GbE node |
42 |
10/25 GbE node |
42 |
10/25 GbE node |
43 |
10/25 GbE node |
43 |
10/25 GbE node |
44 |
10/25 GbE node |
44 |
10/25 GbE node |
45 |
10/25 GbE node |
45 |
10/25 GbE node |
46 |
10/25 GbE node |
46 |
10/25 GbE node |
47 |
10/25 GbE node |
47 |
10/25 GbE node |
48 |
10/25 GbE node |
48 |
10/25 GbE node |
49 |
40/100 GbE node |
49 |
40/100 GbE node |
50 |
40/100 GbE node |
50 |
40/100 GbE node |
51 |
40/100 GbE node |
51 |
40/100 GbE node |
52 |
40/100 GbE node |
52 |
40/100 GbE node |
53 |
40/100 GbE node |
53 |
40/100 GbE node |
54 |
40/100 GbE node |
54 |
40/100 GbE node |
55 |
40/100 GbE node |
55 |
40/100 GbE node |
56 |
40/100 GbE node |
56 |
40/100 GbE node |
57 |
40/100 GbE node |
57 |
40/100 GbE node |
58 |
40/100 GbE node |
58 |
40/100 GbE node |
59 |
40/100 GbE node |
59 |
40/100 GbE node |
60 |
40/100 GbE node |
60 |
40/100 GbE node |
61 |
40/100 GbE node |
61 |
40/100 GbE node |
62 |
40/100 GbE node |
62 |
40/100 GbE node |
63 |
40/100 GbE node |
63 |
40/100 GbE node |
64 |
40/100 GbE node |
64 |
40/100 GbE node |
65 |
100 GbE ISL to switch B port 65 |
65 |
100 GbE ISL to switch A port 65 |
66 |
100 GbE ISL to switch B port 66 |
66 |
Blank cabling worksheet
You can use the blank cabling worksheet to document the platforms that are supported as nodes in a cluster. The Supported Cluster Connections section of the Hardware Universe defines the cluster ports used by the platform.
Switch port |
Node/port usage |
Switch port |
Node/port usage |
1 |
1 |
2 |
2 |
3 |
3 |
4 |
4 |
5 |
5 |
6 |
6 |
7 |
7 |
8 |
8 |
9 |
9 |
10 |
10 |
11 |
11 |
12 |
12 |
13 |
13 |
14 |
14 |
15 |
15 |
16 |
16 |
17 |
17 |
18 |
18 |
19 |
19 |
20 |
20 |
21 |
21 |
22 |
22 |
23 |
23 |
24 |
24 |
25 |
25 |
26 |
26 |
27 |
27 |
28 |
28 |
29 |
29 |
30 |
30 |
31 |
31 |
32 |
32 |
33 |
33 |
34 |
34 |
35 |
35 |
36 |
36 |
37 |
37 |
38 |
38 |
39 |
39 |
40 |
40 |
41 |
41 |
42 |
42 |
43 |
43 |
44 |
44 |
45 |
45 |
46 |
46 |
47 |
47 |
48 |
48 |
49 |
49 |
50 |
50 |
51 |
51 |
52 |
52 |
53 |
53 |
54 |
54 |
55 |
55 |
56 |
56 |
57 |
57 |
58 |
58 |
59 |
59 |
60 |
60 |
61 |
61 |
62 |
62 |
63 |
63 |
64 |
64 |
65 |
65 |
66 |
66 |
ISL to switch A port 66 |
After you've completed your cabling worksheets, you can install the switch.
