Install and maintain
Install NX-OS on the Cisco Nexus 9332D-GX2B switch
Contributors netapp-lisa netapp-camdenc netapp-jsnyder
Install NX-OS on Cisco Nexus 9332D-GX2B switches for new AFX 1K or AFX 2K system installations, switch replacements, or when resetting a switch to factory default settings.
Before you begin
  • The switch(es) must be powered on and you must have completed the Complete initial switch setup procedure.
  • If you are installing the NX-OS on switch(es) as part of a new AFX system installation or switch replacement, verify that the version of NX-OS on your switch(es) is the current NetApp-supported version.
    • If your switch(es) have the current NetApp-supported version, you do not need to install the NX-OS. You need to install the RCF. Start with the Install or upgrade the RCF overview.
    • If your switch(es) do not have the current NetApp-supported version, continue with this procedure to install the NX-OS.
  • If you are installing the NX-OS on a switch as part of a switch replacement or a switch reset to factory default settings, verify that your cluster is fully functional, meaning that there are no errors in the logs or similar issues.
Note If you are installing the NX-OS as part of a new AFX system installation, you can skip this requirement because the controllers in your AFX system are not powered on at this point in your AFX system installation and setup.
About this task
  • The version of ONTAP running on your AFX system determines the supported versions of NX-OS for your switches.
    • For switches in an AFX 1K system, running any supported version of ONTAP, NX-OS 10.4.2 and later is supported.
    • For switches in an AFX 2K system, running ONTAP 9.19.1GA or later, NX-OS 10.6 and later is supported.
      For the current list of supported NX-OS versions, see the NetApp Cisco Ethernet Switches page.
  • This procedure only requires the use of Cisco Nexus 9000 Series Switches commands.
  • The examples in this procedure refer to the first switch as cs1 and the second switch as cs2.
  • If you have installed switches as part of a new AFX 1K or AFX 2K system installation, this procedure has you install the NX-OS on the first switch (cs1) and then has you repeat the steps for the second switch (cs2).
  • The examples shown in this procedure are for AFX 1K systems with switches running RCF 10.0. If you have an AFX 2K system, the input and output can vary.
Step 1: Prepare to install the NX-OS
Prepare to install the NX-OS on the switch(es) by making sure you have access to a server with the supported NX-OS version, downloading the NX-OS, connecting to the management network for the file transfer, and then verifying connectivity to the server.
Steps
  1. You must have access to an HTTP, FTP, or TFTP server. Access to one of these servers allows you to download a supported version of the NX-OS.
  2. Download the correct version of NX-OS and EPLD image to the switch(es) from the Cisco software download page.
  3. Connect the switch to the management network (for the file transfer).
  4. Verify connectivity to the server hosting the NX-OS using the ping command.
    ping <IP address>
    Show example
    This example verifies that the switch can reach the server at IP address 172.19.2.1:
    cs1# ping 172.19.2.1
    Pinging 172.19.2.1 with 0 bytes of data:
    Reply From 172.19.2.1: icmp_seq = 0. time= 5910 usec.
Step 2: Install the NX-OS and EPLD image
You install and verify the NX-OS and EPLD image on the first switch (cs1), and then repeat these steps on the second switch (cs2) if you are installing the NX-OS as part of a new AFX system installation.
  1. Install the NX-OS and EPLD image.
    Choose the tab that applies to your situation:
    • Install 10.4(2)F
    • Install 10.6(3)F or a later version
Install 10.4(2)F
You use the switch CLI to enter the commands for the following steps.
  1. Copy NX-OS and EPLD images to the first switch.
    You use this command two times: the first time is to copy the NX-OS version and the second time is to copy the EPLD version.
    copy <protocol>: bootflash: vrf management
    Show example
    The example uses sftp.
    cs1# copy sftp: bootflash: vrf management
    Enter source filename: /code/nxos.10.4.2.bin
    Enter hostname for the sftp server: 172.19.2.1
    Enter username: root
    Outbound-ReKey for 172.19.2.1:22
    Inbound-ReKey for 172.19.2.1:22
    root@172.19.2.1's password:
    sftp> progress
    Progress meter enabled
    sftp> get   /code/nxos.10.4.2.bin  /bootflash/nxos.10.4.2.bin
    /code/nxos.10.4.2.bin  100% 1261MB   9.3MB/s   02:15
    sftp> exit
    Copy complete, now saving to disk (please wait)...
    Copy complete.
    Enter source filename: /code/n9000-epld.10.4.2.F.img
    Enter username: user1
    user1@172.19.2.1's password:
    sftp> progress
    sftp> get   /code/n9000-epld.10.4.2.F.img  /bootflash/n9000-epld.10.4.2.F.img
    /code/n9000-epld.10.4.2.F.img  100%  161MB   9.5MB/s   00:16
    sftp> exit
    Copy complete.
  2. Verify the running version of NX-OS:
    show version
    Show example
    cs1# show version
    Cisco Nexus Operating System (NX-OS) Software
    Software
      BIOS: version 01.14
      NXOS: version 10.4(1) [Feature Release]
      Host NXOS: version 10.4(1)
      BIOS compile time:  11/25/2024
      NXOS image file is: bootflash:///nxos64-cs.10.4.1.F.bin
      NXOS compile time:  11/30/2023 12:00:00 [12/14/2023 05:25:50]
      NXOS boot mode: LXC
    Hardware
      cisco Nexus9000 C9332D-GX2B Chassis
      Intel(R) Xeon(R) CPU D-1633N @ 2.50GHz with 32802156 kB of memory.
      Processor Board ID FLMXXXXXXXX
      Device name: cs2
      bootflash:  115802886 kB
    Kernel uptime is 5 day(s), 2 hour(s), 13 minute(s), 21 second(s)
    Last reset at 3580 usecs after Thu Jun  5 15:55:08 2025
      Reason: Reset Requested by CLI command reload
      System version: 10.4(1)
      Service:
    plugin
      Core Plugin, Ethernet Plugin
    Active Package(s):
    cs1#
  3. Install the NX-OS image.
    Installing the image file causes it to be loaded every time the switch reboots.
    install all nxos bootflash:nxos.<version number>.bin
    Show example
    The example uses NX-OS version 10.4.2.
    cs1# install all nxos bootflash:nxos.10.4.2.bin
    Installer will perform compatibility check first. Please wait.
    Installer is forced disruptive
    Verifying image bootflash:/nxos.10.4.2.bin for boot variable "nxos".
    [] 100% -- SUCCESS
    Verifying image type.
    [] 100% -- SUCCESS
    Preparing "nxos" version info using image bootflash:/nxos.10.4.2.bin.
    [] 100% -- SUCCESS
    Preparing "bios" version info using image bootflash:/nxos.10.4.2.bin.
    [] 100% -- SUCCESS
    Performing module support checks.
    [] 100% -- SUCCESS
    Notifying services about system upgrade.
    [] 100% -- SUCCESS
    Compatibility check is done:
    Module  Bootable  Impact          Install-type  Reason
      1     yes       Disruptive      Reset         Default upgrade is not hitless
    Images will be upgraded according to following table:
    Module   Image    Running-Version(pri:alt)                 New-Version         Upg-Required
      1      nxos     10.4(1)                                  10.4(2)             Yes
      1      bios     xx.xx.:xx.xx                             xxx                 No
    Switch will be reloaded for disruptive upgrade.
    Do you want to continue with the installation (y/n)? [n] y
    Install is in progress, please wait.
    Performing runtime checks.
    [] 100% -- SUCCESS
    Setting boot variables.
    [] 100% -- SUCCESS
    Performing configuration copy.
    [] 100% -- SUCCESS
    Module 1: Refreshing compact flash and upgrading bios/loader/bootrom.
    Warning: please do not remove or power off the module at this time.
    [] 100% -- SUCCESS
    Finishing the upgrade, switch will reboot in 10 seconds.
  4. Verify the new version of NX-OS after the switch reboots:
    show version
    Show example
    cs1# show version
    Software
      BIOS: version 01.14
      NXOS: version 10.4(2) [Feature Release]
      Host NXOS: version 10.4(2)
      NXOS image file is: bootflash:///nxos64-cs.10.4.2.F.bin
      NXOS boot mode: LXC
    Hardware
      Device name: cs1
      System version: 10.4(2)
      Service:
    plugin
    Active Package(s):
    cs1#
  5. Upgrade the EPLD image using the following commands:
    show version module 1 epld
    install epld bootflash:n9000-epld.<version>.img module all
    After the last command is executed, the switch reboots.
    Show example
    The example uses EPLD version 10.4(2)F
    cs1# show version module 1 epld
    EPLD Device                     Version
    MI   FPGA                        0x7
    IO   FPGA                        0x17
    MI   FPGA2                       0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    cs1# install epld bootflash:n9000-epld.10.4.2.F.img module all
    Compatibility check:
    Module        Type         Upgradable        Impact    Reason
         1         SUP         Yes       disruptive  Module Upgradable
    Retrieving EPLD versions.... Please wait.
    Module  Type   EPLD              Running-Version   New-Version  Upg-Required
         1  SUP    MI FPGA           0x07              0x07         No
         1  SUP    IO FPGA           0x17              0x19         Yes
         1  SUP    MI FPGA2          0x02              0x02         No
    The above modules require upgrade.
    The switch will be reloaded at the end of the upgrade
    Do you want to continue (y/n) ?  [n] y
    Proceeding to upgrade Modules.
    Starting Module 1 EPLD Upgrade
    Module 1 : IO FPGA [Programming] : 100.00% (     64 of      64 sectors)
    Module 1 EPLD upgrade is successful.
    Module   Type  Upgrade-Result
         1   SUP   Success
    EPLDs upgraded.
  6. After the switch reboots, log in and verify that the new version of EPLD loaded successfully:
    Show example
    EPLD Device                     Version
    MI   FPGA                        0x7
    IO   FPGA                        0x19
    MI   FPGA2                       0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
  1. Copy the combined NX-OS and EPLD image to the first switch:
    Example
    Enter source filename: /code/nxos.10.6.3.F.bin
    sftp> progress
    sftp> get /code/nxos.10.6.3.F.bin /bootflash/nxos.10.6.3.F.bin
    /code/nxos.10.6.3.F.bin  100% 1261MB   9.3MB/s   02:15
    sftp> exit
    Copy complete.
  2. Verify the running version of the NX-OS:
    show version
    Example
    cs1# show version
    Software
      BIOS: version 08.38
      NXOS: version 10.4(2)F
      BIOS compile time:  05/29/2020
      NXOS image file is: bootflash:///nxos.10.6.3.F.bin
      NXOS compile time:  4/28/2020 21:00:00 [04/29/2020 02:28:31]
    Hardware
      cisco Nexus9000 C9336C-FX2 Chassis
      Intel(R) Xeon(R) CPU E5-2403 v2 @ 1.80GHz with 8154432 kB of memory.
      Processor Board ID FOC20291J6K
      Device name: cs1
      bootflash:   53298520 kB
    Kernel uptime is 0 day(s), 0 hour(s), 3 minute(s), 42 second(s)
    Last reset at 157524 usecs after Mon Nov  2 18:32:06 2020
      System version: 9.3(4)
      Service:
    plugin
    Active Package(s):
    cs1#
  3. Install the NX-OS and EPLD images.
    Note
    The EPLD image is not automatically updated when you upgrade to NX-OS 10.6(3)F and later. After your upgrade completes and the switch reboots, you must run the same upgrade install all command again.
    • The second upgrade pass verifies, but skips the NX-OS upgrade; only the EPLD image is updated.
    • When you have already upgraded to NX-OS 10.6(3)F and later, both images are updated at the same time.
    Installing the image file causes it to be loaded every time the switch is rebooted.
    The following example shows an upgrade from NX-OS 10.4(2)F to 10.6(3)F. The first pass performs the NX-OS upgrade and the second pass performs the EPLD image upgrade.
    The following step shows the first install pass to upgrade from NX-OS 10.4(2)F to 10.6(3)F.
    install all nxos bootflash:<nxos_image.bin>
    Example
    cs2# install all nxos bootflash:nxos.10.6.3.F.bin   <---- 1st pass updates NX-OS only
    Verifying image bootflash:/nxos.10.6.3.F.bin for boot variable "nxos".
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    Preparing "nxos" version info using image bootflash:/nxos.10.6.3.F.bin.
    [] 100% -- SUCCESS
    Preparing "bios" version info using image bootflash:/nxos.10.6.3.F.bin.
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    1        nxos     10.4(2)F                   10.6(3)F          yes
    1        bios     v05.47(04/28/2022):v05.47(04/28/2022)    v05.53(01/22/2025)     yes
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    The following step shows the second installation pass to update the EPLD image.
    Example
    cs2# install all nxos bootflash:nxos.10.6.3.F.bin   <---- 2nd pass updates EPLD image only
    [] 100% -- SUCCESS
    Verifying EPLD/FPGA image //bootflash/nxos.10.6.3.F.bin.
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    Module  bootable  Impact          Install-type  Reason
    1       yes       disruptive      reset         default upgrade is not hitless
    27      yes       disruptive      none          default upgrade is not hitless
    27        nxos                   10.6(3)(F)                            10.6(3)(F)             no
    27        bios                   v05.53(01/22/2025):v05.47(04/28/2022) v05.53(01/22/2025)    no
    FPGA microcode will be upgraded according to following table:
    Module  Type  EPLD               Running-Version  Flashed-Version*   New-Version  Upg-Required
    27      SUP   MI FPGA            0x5              0x5                0x5          No
    27      SUP   IO FPGA            0x17             0x17               0x18         Yes
    If Running-Version and Flashed-Version are different it implies that the system has not yet been reloaded for the new version to take effect.
    EPLD Upgrade may result in multiple modules going offline.
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    [] 100% -- SUCCESS
    Module 27: Refreshing compact flash and upgrading bios/loader/bootrom.
    [] 100% -- SUCCESS
    EPLD/FPGA upgrade can take up to 4 mins.
    Performing EPLD/FPGA upgrade.
    [] 100% -- SUCCESS
    Install has been successful.
  4. Verify the new version of NX-OS after the switch has rebooted:
    show version
    Example
    cs1# show version
    Software
      BIOS: version 05.33
      NXOS: version 10.6.3.F
      BIOS compile time:  09/08/2018
      NXOS compile time:  11/4/2018 21:00:00 [11/05/2018 06:11:06]
    Hardware
      cisco Nexus9000 C9332C-GX2B Chassis
      Device name: cs1
    Last reset at 277524 usecs after Mon Nov  2 22:45:12 2020
      Reason: Reset due to upgrade
      Service:
    plugin
    Active Package(s):
  5. After the switch reboot, log in again and verify that the new version of EPLD loaded successfully:
    Example
    cs2# show version module 1 epld
    EPLD Device                     Version
    MI   FPGA                        0x7
    IO   FPGA                        0x19
    MI   FPGA2                       0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
  1. If you are installing the NX-OS as part of a new AFX system installation, repeat these steps to install the NX-OS and EPLD images on switch cs2.
What's next?
After you've installed the NX-OS on your switch(es), you install RCF starting with the Install or upgrade the RCF overview.
