Upgrade NX-OS on the Cisco Nexus 9332D-GX2B switch
Upgrade the NX-OS on Cisco Nexus 9332D-GX2B switches to support new hardware or a new ONTAP version on AFX 1K or AFX 2K systems.
NetApp recommends that you complete any ONTAP software upgrade first, then perform the software upgrade for your switches. |
Make sure you have a current backup of the switch configuration.
Verify that your cluster is fully functional, meaning that there are no errors in the logs or similar issues.
If needed, you can refer to the Cisco Nexus 9000 Series NX-OS Software Upgrade and Downgrade Guide for more information.
If needed, you can refer to the Cisco Nexus 9000 and 3000 Upgrade and ISSU Matrix, which provides information on In-Service Software Upgrade (ISSU) for Cisco Nexus 9000 Series Switches based on your current and target releases.
On the page, select Disruptive Upgrade and select your current release and target release from the dropdown list.
The version of ONTAP running on your AFX system determines the supported versions of NX-OS for your switches.
For switches in an AFX 1K system, running any supported version of ONTAP, NX-OS 10.4.2 and later is supported.
For switches in an AFX 2K system, running ONTAP 9.19.1GA or later, NX-OS 10.6 and later is supported.
For the current list of supported NX-OS versions, see the NetApp Cisco Ethernet Switches page.
Do not upgrade or downgrade your NX-OS version to an unsupported version.
Because this procedure requires the use of ONTAP commands and Cisco Nexus 9000 Series Switches commands, the steps indicate which CLI you are using to enter commands.
The examples in this procedure use the following switch and node nomenclature:
The names of the two Cisco switches are cs1 and cs2.
The node names are node1-01, node1-02, node1-03, and node1-04.
The cluster LIF names are:
node1-01_clus1 and node1-01_clus2 for node1-01
node1-02_clus1 and node1-02_clus2 for node1-02
node1-03_clus1 and node1-03_clus2 for node1-03
node1-04_clus1 and node1-04_clus2 for node1-04
The
cluster1::*>prompt indicates the name of the cluster.
The examples shown in this procedure are for AFX 1K systems with switches running RCF 10.0. If you have an AFX 2K system, the input and output can vary.
Step 1: Prepare to upgrade the NX-OS
Prepare to upgrade the NX-OS by making sure you have a management network connection to each switch, downloading the NX-OS version, checking port status on the cluster, and disabling auto-revert on the cluster LIFs.
Connect each switch to the management network.
Using the switch CLI, verify connectivity to the server hosting the NX-OS.
ping <IP address>Show example
This example verifies that the switch can reach the server at IP address 172.19.2.1:
cs1# ping 172.19.2.1 Pinging 172.19.2.1 with 0 bytes of data: Reply From 172.19.2.1: icmp_seq = 0. time= 5910 usec.
Download the correct version of NX-OS to the switches from the Cisco software download page.
Using the ONTAP CLI, display the cluster ports on each node that are connected to the cluster switches:
network device-discovery showShow example
cluster1::*> network device-discovery show Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform ----------- ------ ------------------------ ---------------- ---------------- node1-01/cdp e10a cs1(FLMXXXXXXXX) Ethernet1/16/3 N9K-C9332D-GX2B e10b cs2(FDOXXXXXXXX) Ethernet1/16/3 N9K-C9332D-GX2B e11a cs1(FLMXXXXXXXX) Ethernet1/16/4 N9K-C9332D-GX2B e11b cs2(FDOXXXXXXXX) Ethernet1/16/4 N9K-C9332D-GX2B e1a cs1(FLMXXXXXXXX) Ethernet1/16/1 N9K-C9332D-GX2B e1b cs2(FDOXXXXXXXX) Ethernet1/16/1 N9K-C9332D-GX2B . . . e7a cs1(FLMXXXXXXXX) Ethernet1/16/2 N9K-C9332D-GX2B e7b cs2(FDOXXXXXXXX) Ethernet1/16/2 N9K-C9332D-GX2B node1-01/lldp e10a cs1 (c8:60:8f:xx:xx:xx) Ethernet1/16/3 - e10b cs2 (04:e3:87:xx:xx:xx) Ethernet1/16/3 - e11a cs1 (c8:60:8f:xx:xx:xx) Ethernet1/16/4 - e11b cs2 (04:e3:87:xx:xx:xx) Ethernet1/16/4 - e1a cs1 (c8:60:8f:xx:xx:xx) Ethernet1/16/1 - e1b cs2 (04:e3:87:xx:xx:xx) Ethernet1/16/1 - . . . e7a cs1 (c8:60:8f:34:78:d3) Ethernet1/16/2 - e7b cs2 (04:e3:87:19:a2:59) Ethernet1/16/2 - . . . -
Using the ONTAP CLI, check the administrative and operational status of each port:
Cluster ports
Verify that all the cluster ports are up with a healthy status:
network port show -ipspace ClusterShow example
cluster1::*> network port show -ipspace Cluster Node: node1-01 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e7a Cluster Cluster up 9000 auto/100000 healthy false e7b Cluster Cluster up 9000 auto/100000 healthy false Node: node1-02 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e7a Cluster Cluster up 9000 auto/100000 healthy false e7b Cluster Cluster up 9000 auto/100000 healthy false Node: node1-03 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e7a Cluster Cluster up 9000 auto/10000 healthy false e7b Cluster Cluster up 9000 auto/10000 healthy false Node: node1-04 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e7a Cluster Cluster up 9000 auto/10000 healthy false e7b Cluster Cluster up 9000 auto/10000 healthy false -
Verify that all the cluster interfaces (LIFs) are on the home port:
network interface show -role clusterShow example
cluster1::*> network interface show -role cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- --------------- ---------- ------------------ --------- ------- ---- Cluster node1-01_clus1 up/up 169.254.36.44/16 node1-01 e7a true node1-01_clus2 up/up 169.254.7.5/16 node1-01 e7b true node1-02_clus1 up/up 169.254.197.206/16 node1-02 e7a true node1-02_clus2 up/up 169.254.195.186/16 node1-02 e7b true node1-03_clus1 up/up 169.254.192.49/16 node1-03 e7a true node1-03_clus2 up/up 169.254.182.76/16 node1-03 e7b true node1-04_clus1 up/up 169.254.59.49/16 node1-04 e7a true node1-04_clus2 up/up 169.254.62.244/16 node1-04 e7b true 8 entries were displayed. -
Verify that the cluster displays information for both cluster switches:
system cluster-switch show -is-monitoring-enabled-operational trueShow example
cluster1::*> system cluster-switch show -is-monitoring-enabled-operational true Switch Type Address Model --------------------------- ------------------ ---------------- --------------- cs2(FDOXXXXXXXX) cluster-network 10.228.137.233 N9K-C9332D-GX2B Serial Number: FDOXXXXXXXX Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 10.4(2) Version Source: CDP/ISDP cs1(FLMXXXXXXXX) cluster-network 10.228.137.253 N9K-C9332D-GX2B Serial Number: FLMXXXXXXXX Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 10.4(2) Version Source: CDP/ISDP 2 entries were displayed.
HA ports
Verify that all the HA ports are up with a healthy status:
ha interconnect status show -node <node-name>Show example
cluster1::*> ha interconnect status show -node node1-01 (system ha interconnect status show) Node: node1-01 Link 0 Status: up Link 1 Status: up Is Link 0 Active: true Is Link 1 Active: true IC RDMA Connection: up Slot: 0 Debug Firmware: no Interconnect Port 0 : Port Name: e1a-17 MTU: 4096 Link Information: ACTIVE Interconnect Port 1 : Port Name: e1b-18 MTU: 4096 Link Information: ACTIVE cluster1::*> ha interconnect status show -node node1-02 (system ha interconnect status show) Node: node1-02 Link 0 Status: up Link 1 Status: up Is Link 0 Active: true Is Link 1 Active: true IC RDMA Connection: up Slot: 0 Debug Firmware: no Interconnect Port 0 : Port Name: e1a-17 MTU: 4096 Link Information: ACTIVE Interconnect Port 1 : Port Name: e1b-18 MTU: 4096 Link Information: ACTIVE . . .
Storage ports
Verify that all the storage ports are up with a healthy status:
storage port show -port-type ENETShow example
cluster1::*> storage port show -port-type ENET Speed Node Port Type Mode (Gb/s) State Status ------------------ ---- ----- ------- ------ -------- ----------- node1-01 e10a ENET - 100 enabled online e10b ENET - 100 enabled online e11a ENET - 100 enabled online e11b ENET - 100 enabled online node1-02 e10a ENET - 100 enabled online e10b ENET - 100 enabled online e11a ENET - 100 enabled online e11b ENET - 100 enabled online node1-03 e10a ENET - 100 enabled online e10b ENET - 100 enabled online e11a ENET - 100 enabled online node1-04 e10a ENET - 100 enabled online e10b ENET - 100 enabled online e11a ENET - 100 enabled online e11b ENET - 100 enabled online 16 entries were displayed.
Storage shelf ports
Verify that all the storage shelf ports are up with a healthy status:
storage shelf port showShow example
cluster1::*> storage shelf port show Shelf ID Module State Internal? ----- -- ------ ------------ --------- 1.1 0 A connected false 1 A connected false 2 A connected false 3 A connected false 4 A connected false 5 A connected false 6 A connected false 7 A connected false 8 B connected false 9 B connected false 10 B connected false 11 B connected false 12 B connected false 13 B connected false 14 B connected false 15 B connected false 16 entries were displayed. -
Verify the connection status of all the storage shelf ports:
storage shelf port show -fields remote-device,remote-port,connector-stateShow example
cluster1::*> storage shelf port show -fields remote-device,remote-port,connector-state shelf id connector-state remote-port remote-device ----- -- --------------- -------------- ----------------- 1.1 0 connected Ethernet1/17/1 CX9332D-cs1 1.1 1 connected Ethernet1/15/1 CX9364D-cs1 1.1 2 connected Ethernet1/17/2 CX9332D-cs1 1.1 3 connected Ethernet1/15/2 CX9364D-cs1 1.1 4 connected Ethernet1/17/3 CX9332D-cs1 1.1 5 connected Ethernet1/15/3 CX9364D-cs1 1.1 6 connected Ethernet1/17/4 CX9332D-cs1 1.1 7 connected Ethernet1/15/4 CX9364D-cs1 1.1 8 connected Ethernet1/19/1 CX9332D-cs1 1.1 9 connected Ethernet1/17/1 CX9364D-cs1 1.1 10 connected Ethernet1/19/2 CX9332D-cs1 1.1 11 connected Ethernet1/17/2 CX9364D-cs1 1.1 12 connected Ethernet1/19/3 CX9332D-cs1 1.1 13 connected Ethernet1/17/3 CX9364D-cs1 1.1 14 connected Ethernet1/19/4 CX9332D-cs1 1.1 15 connected Ethernet1/17/4 CX9364D-cs1 16 entries were displayed.
Using the ONTAP CLI, disable auto-revert on the cluster LIFs. The cluster LIFs fail over to the partner cluster switch and remain there as you perform this procedure on the targeted switch:
network interface modify -vserver Cluster -lif * -auto-revert false
Step 2: Install the NX-OS and EPLD image
You install and verify the NX-OS and EPLD image on the first switch (cs1), verify the health of all ports on the cluster, and then repeat these steps on the second switch (cs2).
Install the NX-OS and EPLD image. The steps can vary based on your current NX-OS version and the target NX-OS version.
Choose the tab that applies to your situation:
Upgrade from 10.4(2)F to 10.6(3)F or later
Upgrade from 10.6(3)F to a later version
You use the switch CLI to enter the commands for the following steps.
Copy the combined NX-OS and EPLD image to the first switch.
copy <protocol>: bootflash: vrf managementExample
cs1# copy sftp: bootflash: vrf management Enter source filename: /code/nxos.10.6.3.F.bin Enter hostname for the sftp server: 172.19.2.1 Enter username: user1 Outbound-ReKey for 172.19.2.1:22 Inbound-ReKey for 172.19.2.1:22 user1@172.19.2.1's password: sftp> progress Progress meter enabled sftp> get /code/nxos.10.6.3.F.bin /bootflash/nxos.10.6.3.F.bin /code/nxos.10.6.3.F.bin 100% 1261MB 9.3MB/s 02:15 sftp> exit Copy complete, now saving to disk (please wait)... Copy complete.
Verify the running version of the NX-OS:
show versionExample
cs1# show version ... Software BIOS: version 08.38 NXOS: version 10.4.2(F) BIOS compile time: 05/29/2020 NXOS image file is: bootflash:///nxos.10.6.3.F.bin NXOS compile time: 4/28/2020 21:00:00 [04/29/2020 02:28:31] Hardware cisco Nexus9000 C9336C-FX2 Chassis Intel(R) Xeon(R) CPU E5-2403 v2 @ 1.80GHz with 8154432 kB of memory. Processor Board ID FOC20291J6K Device name: cs1 bootflash: 53298520 kB Kernel uptime is 0 day(s), 0 hour(s), 3 minute(s), 42 second(s) Last reset at 157524 usecs after Mon Nov 2 18:32:06 2020 Reason: Reset Requested by CLI command reload System version: 9.3(4) Service: plugin Core Plugin, Ethernet Plugin Active Package(s): cs1#
Install the NX-OS and EPLD images.
The EPLD image is not automatically updated when you upgrade to NX-OS 10.6(3)F and later. After your upgrade completes and the switch reboots, you must run the same upgrade
install allcommand again.-
The second upgrade pass verifies, but skips the NX-OS upgrade; only the EPLD image is updated.
When you have already upgraded to NX-OS 10.6(3)F and later, both images are updated at the same time.
Installing the image file causes it to be loaded every time the switch reboots.
The following step shows the first install pass to upgrade from NX-OS 10.4(5)(M) to 10.5(3)(F).
install all nxos bootflash:<nxos_image.bin>Example
cs2# install all nxos bootflash:nxos.10.6.3.F.bin <---- 1st pass updates NX-OS only Installer will perform compatibility check first. Please wait. Installer is forced disruptive Verifying image bootflash:/nxos.10.6.3.F.bin for boot variable "nxos". [] 100% -- SUCCESS Verifying image type. [] 100% -- SUCCESS Preparing "nxos" version info using image bootflash:/nxos.10.6.3.F.bin. [] 100% -- SUCCESS Preparing "bios" version info using image bootflash:/nxos.10.6.3.F.bin. [] 100% -- SUCCESS Performing module support checks. [] 100% -- SUCCESS Notifying services about system upgrade. [] 100% -- SUCCESS Compatibility check is done: Module Bootable Impact Install-type Reason ------ -------- --------------- ------------ --------- 1 yes Disruptive Reset Default upgrade is not hitless Images will be upgraded according to following table: Module Image Running-Version(pri:alt) New-Version Upg-Required ------- --------- ---------------------------------------- -------------------- ------------ 1 nxos 10.4(2)(M) 10.6(3)(F) yes 1 bios v05.47(04/28/2022):v05.47(04/28/2022) v05.53(01/22/2025) yes Switch will be reloaded for disruptive upgrade. Do you want to continue with the installation (y/n)? [n] y Install is in progress, please wait. Performing runtime checks. [] 100% -- SUCCESS Setting boot variables. [] 100% -- SUCCESS Performing configuration copy. [] 100% -- SUCCESS Module 1: Refreshing compact flash and upgrading bios/loader/bootrom. Warning: please do not remove or power off the module at this time. [] 100% -- SUCCESS [] 100% -- SUCCESS Finishing the upgrade, switch will reboot in 10 seconds.
Using the switch CLI, verify the new version of NX-OS after the switch reboots:
The following step shows the second installation pass to update the EPLD image.
cs2# install all nxos bootflash:nxos.10.6.3.F.bin <---- 2nd pass updates EPLD image only Installer will perform compatibility check first. Please wait. Installer is forced disruptive Verifying image bootflash:/nxos.10.6.3.F.bin for boot variable "nxos". [] 100% -- SUCCESS Verifying EPLD/FPGA image //bootflash/nxos.10.6.3.F.bin. [] 100% -- SUCCESS Verifying image type. [] 100% -- SUCCESS Preparing "nxos" version info using image bootflash:/nxos.10.6.3.F.bin. [] 100% -- SUCCESS Preparing "bios" version info using image bootflash:/nxos.10.6.3.F.bin. [] 100% -- SUCCESS Performing module support checks. [] 100% -- SUCCESS Notifying services about system upgrade. [] 100% -- SUCCESS Compatibility check is done: Module bootable Impact Install-type Reason ------ -------- -------------- ------------ ------ 1 yes disruptive reset default upgrade is not hitless 27 yes disruptive none default upgrade is not hitless Images will be upgraded according to following table: Module Image Running-Version(pri:alt) New-Version Upg-Required -------- --------------------- ------------------------------------- ----------------- ------------ 27 nxos 10.6(3)(F) 10.6(3)(F) no 27 bios v05.53(01/22/2025):v05.47(04/28/2022) v05.53(01/22/2025) no FPGA microcode will be upgraded according to following table: Module Type EPLD Running-Version Flashed-Version* New-Version Upg-Required ------ ---- ----------------- --------------- ---------------- ----------- ------------ 27 SUP MI FPGA 0x5 0x5 0x5 No 27 SUP IO FPGA 0x17 0x17 0x18 Yes If Running-Version and Flashed-Version are different it implies that the system has not yet been reloaded for the new version to take effect. EPLD Upgrade may result in multiple modules going offline. Switch will be reloaded for disruptive upgrade. Do you want to continue with the installation (y/n)? [n] y Install is in progress, please wait. Setting boot variables. [] 100% -- SUCCESS Performing configuration copy. [] 100% -- SUCCESS Performing configuration copy. [] 100% -- SUCCESS Module 1: Refreshing compact flash and upgrading bios/loader/bootrom. Warning: please do not remove or power off the module at this time. Module 1: Refreshing compact flash and upgrading bios/loader/bootrom. Warning: please do not remove or power off the module at this time. [] 100% -- SUCCESS Module 27: Refreshing compact flash and upgrading bios/loader/bootrom. Warning: please do not remove or power off the module at this time. Module 27: Refreshing compact flash and upgrading bios/loader/bootrom. Warning: please do not remove or power off the module at this time. [] 100% -- SUCCESS EPLD/FPGA upgrade can take up to 4 mins. Performing EPLD/FPGA upgrade. [] 100% -- SUCCESS Install has been successful.
After the switch reboot, log in again and verify that the new version of EPLD loaded successfully.
show version module 1 epldExample
cs2# show version module 1 epld EPLD Device Version --------------------------------------- MI FPGA 0x7 IO FPGA 0x19 MI FPGA2 0x2 GEM FPGA 0x2 GEM FPGA 0x2 GEM FPGA 0x2 GEM FPGA 0x2
The example uses sftp and NX-OS version 10.6(4)M.
cs1# copy sftp: bootflash: vrf management Enter source filename: /code/nxos64-cs.10.6.4.M.bin Enter hostname for the sftp server: 172.19.2.1 Enter username: user1 Outbound-ReKey for 172.19.2.1:22 Inbound-ReKey for 172.19.2.1:22 user1@172.19.2.1's password: sftp> progress Progress meter enabled sftp> get /code/nxos64-cs.10.6.4.M.bin /bootflash/nxos64-cs.10.6.4.M.bin /code/nxos64-cs.10.6.4.M.bin 100% 1261MB 9.3MB/s 02:15 sftp> exit Copy complete, now saving to disk (please wait)... Copy complete.
Verify the running version of NX-OS:
show versionExample
cs1# show version ... Software BIOS: version 01.14 NXOS: version 10.6.4.M [Feature Release] Host NXOS: version 10.6.4.M BIOS compile time: 11/25/2026 NXOS image file is: bootflash:///nxos.10.6.4.M.bin NXOS compile time: 02/27/2026 12:00:00 [03/14/2026 05:25:50] NXOS boot mode: LXC Hardware cisco Nexus9000 C9332C-GX2B Chassis Intel(R) Xeon(R) CPU D-1633N @ 2.50GHz with 32802156 kB of memory. Processor Board ID FLMXXXXXXXX Device name: cs1 bootflash: 115802886 kB Kernel uptime is 5 day(s), 2 hour(s), 13 minute(s), 21 second(s) Last reset at 3580 usecs after Thu Mar 5 15:55:08 2026 Reason: Reset Requested by CLI command reload System version: 10.6(3)F Service: plugin Core Plugin, Ethernet Plugin Active Package(s): cs1#
Installing the image file causes it to be loaded every time the switch is rebooted.
install all nxos bootflash:nxos.<version number>.binExample
The example uses NX-OS version 10.6(4)M.
cs1# install all nxos bootflash:/nxos64-cs.10.6.4.M.bin Installer will perform compatibility check first. Please wait. Installer is forced disruptive Verifying image bootflash:/nxos64-cs.10.6.4.M.bin for boot variable "nxos". [] 100% -- SUCCESS Verifying image type. [] 100% -- SUCCESS Preparing "nxos" version info using image bootflash:/nxos64-cs.10.6.4.M.bin. [] 100% -- SUCCESS Preparing "bios" version info using image bootflash:/nxos64-cs.10.6.4.M.bin. [] 100% -- SUCCESS Performing module support checks. [] 100% -- SUCCESS Notifying services about system upgrade. [] 100% -- SUCCESS Compatibility check is done: Module Bootable Impact Install-type Reason ------ -------- --------------- ------------ --------- 1 yes Disruptive Reset Default upgrade is not hitless Images will be upgraded according to following table: Module Image Running-Version(pri:alt) New-Version Upg-Required ------- --------- ----------------------------------- ------------------- ------------ 1 nxos 10.4(2)(F) 10.6(4)(M) Yes 1 bios <current_version> <new_version> No Switch will be reloaded for disruptive upgrade. Do you want to continue with the installation (y/n)? [n] y Install is in progress, please wait. Performing runtime checks. [] 100% -- SUCCESS Setting boot variables. [] 100% -- SUCCESS Performing configuration copy. [] 100% -- SUCCESS Module 1: Refreshing compact flash and upgrading bios/loader/bootrom. Warning: please do not remove or power off the module at this time. [] 100% -- SUCCESS Finishing the upgrade, switch will reboot in 10 seconds.
Verify the new version of NX-OS after the switch has rebooted:
show versionExample
cs1# show version Cisco Nexus Operating System (NX-OS) Software TAC support: http://www.cisco.com/tac Copyright (C) 2002-2025, Cisco and/or its affiliates. All rights reserved. The copyrights to certain works contained in this software are owned by other third parties and used and distributed under their own licenses, such as open source. This software is provided "as is," and unless otherwise stated, there is no warranty, express or implied, including but not limited to warranties of merchantability and fitness for a particular purpose. Certain components of this software are licensed under the GNU General Public License (GPL) version 2.0 or GNU General Public License (GPL) version 3.0 or the GNU Lesser General Public License (LGPL) Version 2.1 or Lesser General Public License (LGPL) Version 2.0. A copy of each such license is available at http://www.opensource.org/licenses/gpl-2.0.php and http://opensource.org/licenses/gpl-3.0.html and http://www.opensource.org/licenses/lgpl-2.1.php and http://www.gnu.org/licenses/old-licenses/library.txt. Software BIOS: version 01.14 NXOS: version 10.6(4)(M) [Feature Release] Host NXOS: version 10.6(4)(M) BIOS compile time: 11/25/2024 NXOS image file is: bootflash:///nxos64-cs.10.6.4.M.bin NXOS compile time: 05/30/2026 12:00:00 [06/14/2026 05:25:50] NXOS boot mode: LXC Hardware cisco Nexus9000 C9336C-FX2 Chassis Intel(R) Xeon(R) CPU D-1633N @ 2.50GHz with 32802156 kB of memory. Processor Board ID FLMXXXXXXXX Device name: cs2 bootflash: 115802886 kB Kernel uptime is 5 day(s), 2 hour(s), 13 minute(s), 21 second(s) Last reset at 3580 usecs after Thu Jun 5 15:55:08 2026 Reason: Reset Requested by CLI command reload System version: 10.5(4)(M) Service: plugin Core Plugin, Ethernet Plugin Active Package(s):
Verify that the new version of EPLD loaded successfully:
show install epld statusExample
The example uses EPLD version 10.6(4)M.
cs1# show install epld status 1) Module 2 upgraded on Mon May 4 09:17:08 2026 (631239 us) EPLD Install Image: EPLD image file 10.6.4.M. built on Fri Apr 24 19:49:50 2026 Status: EPLD Upgrade was Successful EPLD Curr Ver Old Ver ------------------------------------------------------- MI FPGA 0x10014 0x1000b IO FPGA 0x10033 0x10006 2) Module 27 upgraded on Wed Apr 1 15:03:13 2026 (193093 us) EPLD Install Image: EPLD image file 10.5.4.M. built on Mon Mar 16 03:28:47 2026 Status: EPLD Upgrade was Successful EPLD Curr Ver Old Ver ------------------------------------------------------- IO FPGA 0x1002d 0x10020 3) Module 28 upgraded on Wed Apr 1 14:59:53 2026 (843907 us) EPLD Install Image: EPLD image file 10.6.4.M. built on Mon Mar 16 03:28:47 2026 Status: EPLD Upgrade was Successful EPLD Curr Ver Old Ver ------------------------------------------------------- IO FPGA 0x1002d 0x10020 4) Module 27 upgraded on Fri Mar 27 21:55:55 2026 (132290 us) EPLD Install Image: EPLD image file 10.6.4.M. built on Fri Dec 12 11:15:18 2026 Status: EPLD Upgrade was Successful EPLD Curr Ver Old Ver ------------------------------------------------------- FM-19 FPGA 0x10006 0x10000 FM-20 FPGA 0x10006 0x10000 FM-21 FPGA 0x10006 0x10000 FM-22 FPGA 0x10006 0x10000 FM-23 FPGA 0x10006 0x10000 FM-24 FPGA 0x10006 0x10000 FM-25 FPGA 0x10006 0x10000 FM-26 FPGA 0x10006 0x10000 5) Module 27 upgraded on Fri Mar 27 21:50:16 2026 ( 4899 us) EPLD Install Image: EPLD image file 10.6.4.M. built on Fri Dec 12 11:15:18 2026 Status: EPLD Upgrade was Successful EPLD Curr Ver Old Ver ------------------------------------------------------- FM-19 FPGA 0x10006 0x10000 FM-20 FPGA 0x10006 0x10000 FM-21 FPGA 0x10006 0x10000 FM-22 FPGA 0x10006 0x10000 FM-23 FPGA 0x10006 0x10000 FM-24 FPGA 0x10006 0x10000 FM-25 FPGA 0x10006 0x10000 FM-26 FPGA 0x10006 0x10000 6) Module 27 upgraded on Fri Mar 27 21:44:36 2026 (775397 us) EPLD Install Image: EPLD image file 10.6.4.M. built on Fri Dec 12 11:15:18 2026 Status: EPLD Upgrade was Successful EPLD Curr Ver Old Ver ------------------------------------------------------- FM-19 FPGA 0x10006 0x10000 FM-20 FPGA 0x10006 0x10000 FM-21 FPGA 0x10006 0x10000 FM-22 FPGA 0x10006 0x10000 FM-23 FPGA 0x10006 0x10000 FM-24 FPGA 0x10006 0x10000 FM-25 FPGA 0x10006 0x10000 FM-26 FPGA 0x10006 0x10000 7) Module 27 upgraded on Fri Mar 27 21:38:58 2026 (330582 us) EPLD Install Image: EPLD image file 10.6.4.M. built on Fri Dec 12 11:15:18 2026 Status: EPLD Upgrade was Successful EPLD Curr Ver Old Ver ------------------------------------------------------- FM-19 FPGA 0x10006 0x10000 FM-20 FPGA 0x10006 0x10000 FM-21 FPGA 0x10006 0x10000 FM-22 FPGA 0x10006 0x10000 FM-23 FPGA 0x10006 0x10000 FM-24 FPGA 0x10006 0x10000 FM-25 FPGA 0x10006 0x10000 FM-26 FPGA 0x10006 0x10000 8) Module 27 upgraded on Fri Mar 27 21:33:19 2026 (112679 us) EPLD Install Image: EPLD image file 10.6.4.M. built on Fri Dec 12 11:15:18 2025 Status: EPLD Upgrade was Successful EPLD Curr Ver Old Ver ------------------------------------------------------- FM-19 FPGA 0x10006 0x10000 FM-20 FPGA 0x10006 0x10000 FM-21 FPGA 0x10006 0x10000 FM-22 FPGA 0x10006 0x10000 FM-23 FPGA 0x10006 0x10000 FM-24 FPGA 0x10006 0x10000 FM-25 FPGA 0x10006 0x10000 FM-26 FPGA 0x10006 0x10000 9) Module 27 upgraded on Fri Mar 27 21:27:41 2026 (957182 us) EPLD Install Image: EPLD image file 10.6.4.M. built on Fri Dec 12 11:15:18 2025 Status: EPLD Upgrade was Successful EPLD Curr Ver Old Ver ------------------------------------------------------- FM-19 FPGA 0x10006 0x10000 FM-20 FPGA 0x10006 0x10000 FM-21 FPGA 0x10006 0x10000 FM-22 FPGA 0x10006 0x10000 FM-23 FPGA 0x10006 0x10000 FM-24 FPGA 0x10006 0x10000 FM-25 FPGA 0x10006 0x10000 FM-26 FPGA 0x10006 0x10000 10) Module 27 upgraded on Fri Mar 27 21:22:03 2026 ( 90303 us) EPLD Install Image: EPLD image file 10.6.4.M. built on Fri Dec 12 11:15:18 2025 Status: EPLD Upgrade was Successful EPLD Curr Ver Old Ver ------------------------------------------------------- FM-19 FPGA 0x10006 0x10000 FM-20 FPGA 0x10006 0x10000 FM-21 FPGA 0x10006 0x10000 FM-22 FPGA 0x10006 0x10000 FM-23 FPGA 0x10006 0x10000 FM-24 FPGA 0x10006 0x10000 FM-25 FPGA 0x10006 0x10000 FM-26 FPGA 0x10006 0x10000 11) Module 1 upgraded on Fri Mar 27 21:16:24 2026 (240369 us) EPLD Install Image: EPLD image file 10.6.4.M. built on Fri Dec 12 11:15:18 2025 Status: EPLD Upgrade was Successful EPLD Curr Ver Old Ver ------------------------------------------------------- MI FPGA 0x10014 0x1000b IO FPGA 0x10033 0x10006
Using the ONTAP CLI, verify the health of all the ports on the cluster.
Cluster ports
Verify that cluster ports are up and healthy across all nodes in the cluster:
cluster1::*> network port show -ipspace Cluster Node: node1-01 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e7a Cluster Cluster up 9000 auto/10000 healthy false e7b Cluster Cluster up 9000 auto/10000 healthy false Node: node1-02 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e7a Cluster Cluster up 9000 auto/10000 healthy false e7b Cluster Cluster up 9000 auto/10000 healthy false Node: node1-03 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e7a Cluster Cluster up 9000 auto/100000 healthy false e7b Cluster Cluster up 9000 auto/100000 healthy false Node: node1-04 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e7a Cluster Cluster up 9000 auto/100000 healthy false e7b Cluster Cluster up 9000 auto/100000 healthy false -
Verify the switch health from the cluster:
network device-discovery show -protocol cdpsystem cluster-switch show -is-monitoring-enabled-operational trueShow example
cluster1::*> network device-discovery show -protocol cdp node1-02/cdp e10a cs1(FLMXXXXXXXX) Ethernet1/16/3 N9K-C9332D-GX2B e10b cs2(FDOXXXXXXXX) Ethernet1/16/3 N9K-C9332D-GX2B e11a cs1(FLMXXXXXXXX) Ethernet1/16/4 N9K-C9332D-GX2B e11b cs2(FDOXXXXXXXX) Ethernet1/16/4 N9K-C9332D-GX2B e1a cs1(FLMXXXXXXXX) Ethernet1/16/1 N9K-C9332D-GX2B e1b cs2(FDOXXXXXXXX) Ethernet1/16/1 N9K-C9332D-GX2B . . . e7a cs1(FLM284504N6) Ethernet1/16/2 N9K-C9332D-GX2B e7b cs2(FDO2846056X) Ethernet1/16/2 N9K-C9332D-GX2B node1-01/cdp e10a cs1(FLMXXXXXXXX) Ethernet1/16/3 N9K-C9332D-GX2B e10b cs2(FDOXXXXXXXX) Ethernet1/16/3 N9K-C9332D-GX2B e11a cs1(FLMXXXXXXXX) Ethernet1/16/4 N9K-C9332D-GX2B e11b cs2(FDOXXXXXXXX) Ethernet1/16/4 N9K-C9332D-GX2B e1a cs1(FLMXXXXXXXX) Ethernet1/16/1 N9K-C9332D-GX2B e1b cs2(FDOXXXXXXXX) Ethernet1/16/1 N9K-C9332D-GX2B . . . e7a cs1(FLMXXXXXXXX) Ethernet1/16/2 N9K-C9332D-GX2B e7b cs2(FDOXXXXXXXX) Ethernet1/16/2 N9K-C9332D-GX2B . . . cluster1::*> system cluster-switch show -is-monitoring-enabled-operational true Switch Type Address Model --------------------------- ------------------ ---------------- --------------- cs2(FDOXXXXXXXX) cluster-network 10.228.137.233 N9K-C9332D-GX2B Serial Number: FDOXXXXXXXX Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 10.4(2) Version Source: CDP/ISDP cs1(FLMXXXXXXXX) cluster-network 10.228.137.253 N9K-C9332D-GX2B Serial Number: FLMXXXXXXXX Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 10.4(2) Version Source: CDP/ISDP
HA ports
Storage ports
Storage shelf ports
Using the ONTAP CLI, verify that the cluster is healthy:
cluster showShow example
cluster1::*> cluster show Node Health Eligibility Epsilon -------------------- ------- ------------ ------------ node1-01 true true false node1-02 true true false node1-03 true true false node1-04 true true true 4 entries were displayed.
Repeat these steps to install NX-OS and EPLD images on switch cs2.
Step 3: Complete the NX-OS upgrade
Using the ONTAP CLI, complete the NX-OS upgrade by re-enabling auto-revert on the cluster LIFs and verifying the cluster LIFs reverted to their home ports.
Re-enable auto-revert on the cluster LIFs.
network interface modify -vserver Cluster -lif * -auto-revert true -
Verify that the cluster LIFs have reverted to their home port:
cluster1::*> network interface show -role cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- --------------- ---------- ------------------ ----------- ------- ---- Cluster node1-01_clus1 up/up 169.254.36.44/16 node1-01 e7a true node1-01_clus2 up/up 169.254.7.5/16 node1-01 e7b true node1-02_clus1 up/up 169.254.197.206/16 node1-02 e7a true node1-02_clus2 up/up 169.254.195.186/16 node1-02 e7b true node1-03_clus1 up/up 169.254.192.49/16 node1-03 e7a true node1-03_clus2 up/up 169.254.182.76/16 node1-03 e7b true node1-04_clus1 up/up 169.254.59.49/16 node1-04 e7a true node1-04_clus2 up/up 169.254.62.244/16 node1-04 e7b trueIf any cluster LIFs have not returned to their home ports, revert them manually from the local node:
network interface revert -vserver Cluster -lif <lif-name>
After you've upgraded the NX-OS on your switches, you upgrade the RCF starting with the Install or upgrade the RCF overview.
