Install the RCF
You install the RCF after setting up the Nexus 9332D-GX2B switch for the first time.
Verify the following installations and connections:
A console connection to the switch. The console connection is optional if you have remote access to the switch.
Switch cs1 and switch cs2 are powered up and the initial switch setup is complete (the Management IP address and SSH is setup).
The desired NX-OS version has been installed.
ISL connections between switches are connected.
Step 1: Install the RCF on the switches
Login to switch cs1 using SSH or by using a serial console.
Copy the RCF to the bootflash of switch cs1 using one of the following transfer protocols: FTP, TFTP, SFTP, or SCP.
For more information on Cisco commands, refer to the appropriate guide in the Cisco Nexus 9000 Series NX-OS Command Reference guides.
Show example
This example shows TFTP being used to copy an RCF to the bootflash on switch cs1:
cs1# copy tftp: bootflash: vrf management Enter source filename: NX9332D-GX2B-RCF-v10.0-Shared.txt Enter hostname for the tftp server: 172.22.201.50 Trying to connect to tftp server......Connection to Server Established. TFTP get operation was successful Copy complete, now saving to disk (please wait)...
Apply the RCF previously downloaded to the bootflash.
This example shows the RCF file
NX9332D-GX2B-RCF-v10.0-Shared.txtbeing installed on switch cs1:cs1# copy NX9332D-GX2B-RCF-v10.0-Shared.txt running-config echo-commands
Examine the banner output from the
show banner motdcommand. You must read and follow these instructions to ensure the proper configuration and operation of the switch.Show example
cs1# show banner motd ****************************************************************************** * NetApp Reference Configuration File (RCF) * * Switch : NX9332D-GX2B * Filename : NX9332D-GX2B-RCF-v10.0-Shared.txt * Date : 05-09-2025 * Version : v10.0 * Port Usage: * Ports 1-30: 100GbE Intra-Cluster/HA/Storage Ports, int e1/{1-30}/1-4 * Ports 31-32: Intra-Cluster ISL Ports, int e1/31-32 * * IMPORTANT NOTES * Interface port-channel999 is reserved to identify the version of this file. ****************************************************************************** -
Verify that the RCF file is the correct newer version:
show running-configWhen you check the output to verify you have the correct RCF, make sure that the following information is correct:
The RCF banner
The node and port settings
Customizations
The output varies according to your site configuration. Check the port settings and refer to the release notes for any changes specific to the RCF that you have installed.
Save basic configuration details to the
write_erase.cfgfile on the bootflash.Make sure to configure the following:
Username and password
Default gateway
Switch name
cs1# show run | i "username admin password" > bootflash:write_erase.cfgcs1# show run | section "vrf context management" >> bootflash:write_erase.cfgcs1# show run | section "interface mgmt0" >> bootflash:write_erase.cfgcs1# show run | section "switchname" >> bootflash:write_erase.cfgcs1# echo "hardware access-list tcam region ing-racl 1024" >> bootflash:write_erase.cfgcs1# echo "hardware access-list tcam region egr-racl 1024" >> bootflash:write_erase.cfgcs1# echo "hardware access-list tcam region ing-l2-qos 1536" >> bootflash:write_erase.cfgRefer to the Knowledge Base article How to clear configuration on a Cisco interconnect switch while retaining remote connectivity for further details.
Verify that the
write_erase.cfgfile is populated as expected:show file bootflash:write_erase.cfg -
Issue the
write erasecommand to erase the current saved configuration:cs1# write eraseWarning: This command will erase the startup-configuration.Do you wish to proceed anyway? (y/n) [n] y -
Copy the previously saved basic configuration into the startup configuration.
cs1# copy bootflash:write_erase.cfg startup-config -
Reboot the switch:
cs1# reloadThis command will reboot the system. (y/n)? [n] y -
Repeat steps 1 through 10 on switch cs2.
Connect the ports of all nodes in the ONTAP cluster to switches cs1 and cs2.
Step 2: Verify the switch connections
Verify that the switch ports connected to the cluster ports are up:
show interface briefShow example
cs1# show interface brief | grep up . . Eth1/9/3 1 eth trunk up none 100G(D) -- Eth1/9/4 1 eth trunk up none 100G(D) -- Eth1/15/1 1 eth trunk up none 100G(D) -- Eth1/15/2 1 eth trunk up none 100G(D) -- Eth1/15/3 1 eth trunk up none 100G(D) -- Eth1/15/4 1 eth trunk up none 100G(D) -- Eth1/16/1 1 eth trunk up none 100G(D) -- Eth1/16/2 1 eth trunk up none 100G(D) -- Eth1/16/3 1 eth trunk up none 100G(D) -- Eth1/16/4 1 eth trunk up none 100G(D) -- Eth1/17/1 1 eth trunk up none 100G(D) -- Eth1/17/2 1 eth trunk up none 100G(D) -- Eth1/17/3 1 eth trunk up none 100G(D) -- Eth1/17/4 1 eth trunk up none 100G(D) -- . .
Verify that the cluster nodes are in their correct cluster VLANs using the following commands:
show vlan briefshow interface trunkShow example
cs1# show vlan brief VLAN Name Status Ports ---- -------------------------------- --------- ------------------------------- 1 default active Po1, Po999, Eth1/31, Eth1/32 Eth1/33, Eth1/34, Eth1/1/1 Eth1/1/2, Eth1/1/3, Eth1/1/4 Eth1/2/1, Eth1/2/2, Eth1/2/3 Eth1/2/4, Eth1/3/1, Eth1/3/2 Eth1/3/3, Eth1/3/4, Eth1/4/1 Eth1/4/2, Eth1/4/3, Eth1/4/4 Eth1/5/1, Eth1/5/2, Eth1/5/3 Eth1/5/4, Eth1/6/1, Eth1/6/2 Eth1/6/3, Eth1/6/4, Eth1/7/1 Eth1/7/2, Eth1/7/3, Eth1/7/4 Eth1/8/1, Eth1/8/2, Eth1/8/3 Eth1/8/4, Eth1/9/1, Eth1/9/2 Eth1/9/3, Eth1/9/4, Eth1/10/1 Eth1/10/2, Eth1/10/3, Eth1/10/4 Eth1/11/1, Eth1/11/2, Eth1/11/3 Eth1/11/4, Eth1/12/1, Eth1/12/2 Eth1/12/3, Eth1/12/4, Eth1/13/1 Eth1/13/2, Eth1/13/3, Eth1/13/4 Eth1/14/1, Eth1/14/2, Eth1/14/3 Eth1/14/4, Eth1/15/1, Eth1/15/2 Eth1/15/3, Eth1/15/4, Eth1/16/1 Eth1/16/2, Eth1/16/3, Eth1/16/4 Eth1/17/1, Eth1/17/2, Eth1/17/3 Eth1/17/4, Eth1/18/1, Eth1/18/2 Eth1/18/3, Eth1/18/4, Eth1/19/1 Eth1/19/2, Eth1/19/3, Eth1/19/4 Eth1/20/1, Eth1/20/2, Eth1/20/3 Eth1/20/4, Eth1/21/1, Eth1/21/2 Eth1/21/3, Eth1/21/4, Eth1/22/1 Eth1/22/2, Eth1/22/3, Eth1/22/4 Eth1/23/1, Eth1/23/2, Eth1/23/3 Eth1/23/4, Eth1/24/1, Eth1/24/2 Eth1/24/3, Eth1/24/4, Eth1/25/1 Eth1/25/2, Eth1/25/3, Eth1/25/4 Eth1/26/1, Eth1/26/2, Eth1/26/3 Eth1/26/4, Eth1/27/1, Eth1/27/2 Eth1/27/3, Eth1/27/4, Eth1/28/1 Eth1/28/2, Eth1/28/3, Eth1/28/4 Eth1/29/1, Eth1/29/2, Eth1/29/3 Eth1/29/4, Eth1/30/1, Eth1/30/2 Eth1/30/3, Eth1/30/4 17 VLAN0017 active Eth1/1/1, Eth1/1/2, Eth1/1/3 Eth1/1/4, Eth1/2/1, Eth1/2/2 Eth1/2/3, Eth1/2/4, Eth1/3/1 Eth1/3/2, Eth1/3/3, Eth1/3/4 Eth1/4/1, Eth1/4/2, Eth1/4/3 Eth1/4/4, Eth1/5/1, Eth1/5/2 Eth1/5/3, Eth1/5/4, Eth1/6/1 Eth1/6/2, Eth1/6/3, Eth1/6/4 Eth1/7/1, Eth1/7/2, Eth1/7/3 Eth1/7/4, Eth1/8/1, Eth1/8/2 Eth1/8/3, Eth1/8/4, Eth1/9/1 Eth1/9/2, Eth1/9/3, Eth1/9/4 Eth1/10/1, Eth1/10/2, Eth1/10/3 Eth1/10/4, Eth1/11/1, Eth1/11/2 Eth1/11/3, Eth1/11/4, Eth1/12/1 Eth1/12/2, Eth1/12/3, Eth1/12/4 Eth1/13/1, Eth1/13/2, Eth1/13/3 Eth1/13/4, Eth1/14/1, Eth1/14/2 Eth1/14/3, Eth1/14/4, Eth1/15/1 Eth1/15/2, Eth1/15/3, Eth1/15/4 Eth1/16/1, Eth1/16/2, Eth1/16/3 Eth1/16/4, Eth1/17/1, Eth1/17/2 Eth1/17/3, Eth1/17/4, Eth1/18/1 Eth1/18/2, Eth1/18/3, Eth1/18/4 Eth1/19/1, Eth1/19/2, Eth1/19/3 Eth1/19/4, Eth1/20/1, Eth1/20/2 Eth1/20/3, Eth1/20/4, Eth1/21/1 Eth1/21/2, Eth1/21/3, Eth1/21/4 Eth1/22/1, Eth1/22/2, Eth1/22/3 Eth1/22/4, Eth1/23/1, Eth1/23/2 Eth1/23/3, Eth1/23/4, Eth1/24/1 Eth1/24/2, Eth1/24/3, Eth1/24/4 Eth1/25/1, Eth1/25/2, Eth1/25/3 Eth1/25/4, Eth1/26/1, Eth1/26/2 Eth1/26/3, Eth1/26/4, Eth1/27/1 Eth1/27/2, Eth1/27/3, Eth1/27/4 Eth1/28/1, Eth1/28/2, Eth1/28/3 Eth1/28/4, Eth1/29/1, Eth1/29/2 Eth1/29/3, Eth1/29/4, Eth1/30/1 Eth1/30/2, Eth1/30/3, Eth1/30/4 18 VLAN0018 active Eth1/1/1, Eth1/1/2, Eth1/1/3 Eth1/1/4, Eth1/2/1, Eth1/2/2 Eth1/2/3, Eth1/2/4, Eth1/3/1 Eth1/3/2, Eth1/3/3, Eth1/3/4 Eth1/4/1, Eth1/4/2, Eth1/4/3 Eth1/4/4, Eth1/5/1, Eth1/5/2 Eth1/5/3, Eth1/5/4, Eth1/6/1 Eth1/6/2, Eth1/6/3, Eth1/6/4 Eth1/7/1, Eth1/7/2, Eth1/7/3 Eth1/7/4, Eth1/8/1, Eth1/8/2 Eth1/8/3, Eth1/8/4, Eth1/9/1 Eth1/9/2, Eth1/9/3, Eth1/9/4 Eth1/10/1, Eth1/10/2, Eth1/10/3 Eth1/10/4, Eth1/11/1, Eth1/11/2 Eth1/11/3, Eth1/11/4, Eth1/12/1 Eth1/12/2, Eth1/12/3, Eth1/12/4 Eth1/13/1, Eth1/13/2, Eth1/13/3 Eth1/13/4, Eth1/14/1, Eth1/14/2 Eth1/14/3, Eth1/14/4, Eth1/15/1 Eth1/15/2, Eth1/15/3, Eth1/15/4 Eth1/16/1, Eth1/16/2, Eth1/16/3 Eth1/16/4, Eth1/17/1, Eth1/17/2 Eth1/17/3, Eth1/17/4, Eth1/18/1 Eth1/18/2, Eth1/18/3, Eth1/18/4 Eth1/19/1, Eth1/19/2, Eth1/19/3 Eth1/19/4, Eth1/20/1, Eth1/20/2 Eth1/20/3, Eth1/20/4, Eth1/21/1 Eth1/21/2, Eth1/21/3, Eth1/21/4 Eth1/22/1, Eth1/22/2, Eth1/22/3 Eth1/22/4, Eth1/23/1, Eth1/23/2 Eth1/23/3, Eth1/23/4, Eth1/24/1 Eth1/24/2, Eth1/24/3, Eth1/24/4 Eth1/25/1, Eth1/25/2, Eth1/25/3 Eth1/25/4, Eth1/26/1, Eth1/26/2 Eth1/26/3, Eth1/26/4, Eth1/27/1 Eth1/27/2, Eth1/27/3, Eth1/27/4 Eth1/28/1, Eth1/28/2, Eth1/28/3 Eth1/28/4, Eth1/29/1, Eth1/29/2 Eth1/29/3, Eth1/29/4, Eth1/30/1 Eth1/30/2, Eth1/30/3, Eth1/30/4 30 VLAN0030 active Eth1/1/1, Eth1/1/2, Eth1/1/3 Eth1/1/4, Eth1/2/1, Eth1/2/2 Eth1/2/3, Eth1/2/4, Eth1/3/1 Eth1/3/2, Eth1/3/3, Eth1/3/4 Eth1/4/1, Eth1/4/2, Eth1/4/3 Eth1/4/4, Eth1/5/1, Eth1/5/2 Eth1/5/3, Eth1/5/4, Eth1/6/1 Eth1/6/2, Eth1/6/3, Eth1/6/4 Eth1/7/1, Eth1/7/2, Eth1/7/3 Eth1/7/4, Eth1/8/1, Eth1/8/2 Eth1/8/3, Eth1/8/4, Eth1/9/1 Eth1/9/2, Eth1/9/3, Eth1/9/4 Eth1/10/1, Eth1/10/2, Eth1/10/3 Eth1/10/4, Eth1/11/1, Eth1/11/2 Eth1/11/3, Eth1/11/4, Eth1/12/1 Eth1/12/2, Eth1/12/3, Eth1/12/4 Eth1/13/1, Eth1/13/2, Eth1/13/3 Eth1/13/4, Eth1/14/1, Eth1/14/2 Eth1/14/3, Eth1/14/4, Eth1/15/1 Eth1/15/2, Eth1/15/3, Eth1/15/4 Eth1/16/1, Eth1/16/2, Eth1/16/3 Eth1/16/4, Eth1/17/1, Eth1/17/2 Eth1/17/3, Eth1/17/4, Eth1/18/1 Eth1/18/2, Eth1/18/3, Eth1/18/4 Eth1/19/1, Eth1/19/2, Eth1/19/3 Eth1/19/4, Eth1/20/1, Eth1/20/2 Eth1/20/3, Eth1/20/4, Eth1/21/1 Eth1/21/2, Eth1/21/3, Eth1/21/4 Eth1/22/1, Eth1/22/2, Eth1/22/3 Eth1/22/4, Eth1/23/1, Eth1/23/2 Eth1/23/3, Eth1/23/4, Eth1/24/1 Eth1/24/2, Eth1/24/3, Eth1/24/4 Eth1/25/1, Eth1/25/2, Eth1/25/3 Eth1/25/4, Eth1/26/1, Eth1/26/2 Eth1/26/3, Eth1/26/4, Eth1/27/1 Eth1/27/2, Eth1/27/3, Eth1/27/4 Eth1/28/1, Eth1/28/2, Eth1/28/3 Eth1/28/4, Eth1/29/1, Eth1/29/2 Eth1/29/3, Eth1/29/4, Eth1/30/1 Eth1/30/2, Eth1/30/3, Eth1/30/4 40 VLAN0040 active Eth1/1/1, Eth1/1/2, Eth1/1/3 Eth1/1/4, Eth1/2/1, Eth1/2/2 Eth1/2/3, Eth1/2/4, Eth1/3/1 Eth1/3/2, Eth1/3/3, Eth1/3/4 Eth1/4/1, Eth1/4/2, Eth1/4/3 Eth1/4/4, Eth1/5/1, Eth1/5/2 Eth1/5/3, Eth1/5/4, Eth1/6/1 Eth1/6/2, Eth1/6/3, Eth1/6/4 Eth1/7/1, Eth1/7/2, Eth1/7/3 Eth1/7/4, Eth1/8/1, Eth1/8/2 Eth1/8/3, Eth1/8/4, Eth1/9/1 Eth1/9/2, Eth1/9/3, Eth1/9/4 Eth1/10/1, Eth1/10/2, Eth1/10/3 Eth1/10/4, Eth1/11/1, Eth1/11/2 Eth1/11/3, Eth1/11/4, Eth1/12/1 Eth1/12/2, Eth1/12/3, Eth1/12/4 Eth1/13/1, Eth1/13/2, Eth1/13/3 Eth1/13/4, Eth1/14/1, Eth1/14/2 Eth1/14/3, Eth1/14/4, Eth1/15/1 Eth1/15/2, Eth1/15/3, Eth1/15/4 Eth1/16/1, Eth1/16/2, Eth1/16/3 Eth1/16/4, Eth1/17/1, Eth1/17/2 Eth1/17/3, Eth1/17/4, Eth1/18/1 Eth1/18/2, Eth1/18/3, Eth1/18/4 Eth1/19/1, Eth1/19/2, Eth1/19/3 Eth1/19/4, Eth1/20/1, Eth1/20/2 Eth1/20/3, Eth1/20/4, Eth1/21/1 Eth1/21/2, Eth1/21/3, Eth1/21/4 Eth1/22/1, Eth1/22/2, Eth1/22/3 Eth1/22/4, Eth1/23/1, Eth1/23/2 Eth1/23/3, Eth1/23/4, Eth1/24/1 Eth1/24/2, Eth1/24/3, Eth1/24/4 Eth1/25/1, Eth1/25/2, Eth1/25/3 Eth1/25/4, Eth1/26/1, Eth1/26/2 Eth1/26/3, Eth1/26/4, Eth1/27/1 Eth1/27/2, Eth1/27/3, Eth1/27/4 Eth1/28/1, Eth1/28/2, Eth1/28/3 Eth1/28/4, Eth1/29/1, Eth1/29/2 Eth1/29/3, Eth1/29/4, Eth1/30/1 Eth1/30/2, Eth1/30/3, Eth1/30/4 cs1# show interface trunk -------------------------------------------------------------------------------- Port Native Status Port Vlan Channel -------------------------------------------------------------------------------- Eth1/1/1 1 trunking -- Eth1/1/2 1 trunking -- Eth1/1/3 1 trunking -- Eth1/1/4 1 trunking -- Eth1/2/1 1 trunking -- Eth1/2/2 1 trunking -- Eth1/2/3 1 trunking -- Eth1/2/4 1 trunking -- . . . Eth1/30/1 none Eth1/30/2 none Eth1/30/3 none Eth1/30/4 none Eth1/31 none Eth1/32 none Po1 1For specific port and VLAN usage details, refer to the banner and important notes section in your RCF. -
Verify that the ISL between cs1 and cs2 is functional:
show port-channel summaryShow example
cs1# show port-channel summary Flags: D - Down P - Up in port-channel (members) I - Individual H - Hot-standby (LACP only) s - Suspended r - Module-removed b - BFD Session Wait S - Switched R - Routed U - Up (port-channel) p - Up in delay-lacp mode (member) M - Not in use. Min-links not met -------------------------------------------------------------------------------- Group Port- Type Protocol Member Ports Channel -------------------------------------------------------------------------------- 1 Po1(SU) Eth LACP Eth1/31(P) Eth1/32(P) 999 Po999(SD) Eth NONE -- cs1#
Step 3: Set up your ONTAP cluster
NetApp recommends that you use System Manager to set up new clusters.
System Manager provides a simple and easy workflow for cluster set up and configuration including assigning a node management IP address, initializing the cluster, creating a local tier, configuring protocols and provisioning initial storage.
Go to Configure ONTAP on a new cluster with System Manager for setup instructions.
After you've installed the RCF, you verify the SSH configuration.
