Replace FRUs in the Cisco Nexus 9332D-GX2B switch
Replace faulty field replaceable units (FRUs) on Cisco Nexus 9332D-GX2B switches to restore switch functionality without replacing the entire switch.
About this task
The Cisco Nexus 9332D-GX2B switch has the following FRUs:
Fan module (6 total)
Power supply module (2 total)
OSFP/QSFP transceiver modules (32 fixed 400GbE ports)
Steps
Go to the Cisco site for the Cisco Nexus 9332D-GX2B NX-OS Mode Switch Hardware Installation Guide.
Navigate to the Replacing components section to see the FRU procedures.
Follow the applicable procedure to replace your faulty FRU.
What's next?
After you've completed the applicable FRU procedure on the Cisco site, you can resume normal operations.
