Install and maintain
Upgrade your RCF version
Contributors netapp-yvonneo
You upgrade your RCF version when you have an existing version of the RCF file installed on your operational switches.
Before you begin
Make sure you have the following:
  • A current backup of the switch configuration.
  • A fully functioning cluster (no errors in the logs or similar issues).
  • The current RCF.
  • If you are updating your RCF version, you need a boot configuration in the RCF that reflects the desired boot images.
    If you need to change the boot configuration to reflect the current boot images, you must do so before reapplying the RCF so that the correct version is instantiated on future reboots.
Note No operational inter-switch link (ISL) is needed during this procedure. This is by design because RCF version changes can affect ISL connectivity temporarily. To ensure non-disruptive cluster operations, the following procedure migrates all of the cluster LIFs to the operational partner switch while performing the steps on the target switch.
Caution Before installing a new switch software version and RCFs, you must erase the switch settings and perform basic configuration. You must be connected to the switch using the serial console or have preserved basic configuration information prior to erasing the switch settings.
Step 1: Prepare for the upgrade
  1. If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message:
    system node autosupport invoke -node * -type all -message MAINT=xh
    where x is the duration of the maintenance window in hours.
  2. Change the privilege level to advanced, entering y when prompted to continue:
    set -privilege advanced
    The advanced prompt (*>) appears.
  3. Display the ports on each node that are connected to the switches:
    network device-discovery show
    Show example
    cluster1::*> network device-discovery show
    Node/       Local  Discovered
    Protocol    Port   Device (LLDP: ChassisID)  Interface         Platform
    node1-01/cdp
                e10a   cs1(FLMXXXXXXXX)          Ethernet1/16/3    N9K-C9332D-GX2B
                e10b   cs2(FDOXXXXXXXX)          Ethernet1/16/3    N9K-C9332D-GX2B
                e11a   cs1(FLMXXXXXXXX)          Ethernet1/16/4    N9K-C9332D-GX2B
                e11b   cs2(FDOXXXXXXXX)          Ethernet1/16/4    N9K-C9332D-GX2B
                e1a    cs1(FLMXXXXXXXX)          Ethernet1/16/1    N9K-C9332D-GX2B
                e1b    cs2(FDOXXXXXXXX)          Ethernet1/16/1    N9K-C9332D-GX2B
                e7a    cs1(FLMXXXXXXXX)          Ethernet1/16/2    N9K-C9332D-GX2B
                e7b    cs2(FDOXXXXXXXX)          Ethernet1/16/2    N9K-C9332D-GX2B
    node1-01/lldp
                e10a   cs1 (c8:60:8f:xx:xx:xx)   Ethernet1/16/3    -
                e10b   cs2 (04:e3:87:xx:xx:xx)   Ethernet1/16/3    -
                e11a   cs1 (c8:60:8f:xx:xx:xx)   Ethernet1/16/4    -
                e11b   cs2 (04:e3:87:xx:xx:xx)   Ethernet1/16/4    -
                e1a    cs1 (c8:60:8f:xx:xx:xx)   Ethernet1/16/1    -
                e1b    cs2 (04:e3:87:xx:xx:xx)   Ethernet1/16/1    -
                e7a    cs1 (c8:60:8f:xx:xx:xx)   Ethernet1/16/2    -
                e7b    cs2 (04:e3:87:xx:xx:xx)   Ethernet1/16/2    -
  4. Check the administrative and operational status of each port.
    1. Cluster ports
      1. Verify that all the cluster ports are up with a healthy status:
        network port show -ipspace Cluster
        Show example
        cluster1::*> network port show -ipspace Cluster
        Node: node1-01
        Ignore
                                                          Speed(Mbps) Health   Health
        Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status   Status
        e7a       Cluster      Cluster          up   9000  auto/100000 healthy false
        e7b       Cluster      Cluster          up   9000  auto/100000 healthy false
        Node: node1-02
        Ignore
        Node: node1-03
        Ignore
        e7a       Cluster      Cluster          up   9000  auto/10000 healthy  false
        e7b       Cluster      Cluster          up   9000  auto/10000 healthy  false
        Node: node1-04
        Ignore
      2. Verify that all the cluster interfaces (LIFs) are on the home port:
        network interface show -role cluster
        Show example
        cluster1::*> network interface show -role cluster
                    Logical            Status     Network           Current      Current Is
        Vserver     Interface          Admin/Oper Address/Mask      Node         Port    Home
        Cluster
                    node1-01_clus1     up/up      169.254.3.4/23     node1-01    e7a     true
                    node1-01_clus2     up/up      169.254.3.5/23     node1-01    e7b     true
                    node1-02_clus1     up/up      169.254.3.8/23     node1-02    e7a     true
                    node1-02_clus2     up/up      169.254.3.9/23     node1-02    e7b     true
                    node1-03_clus1     up/up      169.254.1.3/23     node1-03    e7a     true
                    node1-03_clus2     up/up      169.254.1.1/23     node1-03    e7b     true
                    node1-04_clus1     up/up      169.254.1.6/23     node1-04    e7a     true
                    node1-04_clus2     up/up      169.254.1.7/23     node1-04    e7b     true
        8 entries were displayed.
      3. Verify that the cluster displays information for both switches:
        system cluster-switch show -is-monitoring-enabled-operational true
        Show example
        cluster1::*> system cluster-switch show -is-monitoring-enabled-operational true
        Switch                      Type               Address          Model
        cs2(FDOXXXXXXXX)            cluster-network    10.228.137.233   N9K-C9332D-GX2B
             Serial Number: FDOXXXXXXXX
              Is Monitored: true
                    Reason: None
          Software Version: Cisco Nexus Operating System (NX-OS) Software, Version
                            10.4(2)
            Version Source: CDP/ISDP
        cs2(FLMXXXXXXXX)            cluster-network    10.228.137.234   N9K-C9332D-GX2B
             Serial Number: FLMXXXXXXXX
              Is Monitored: true
                    Reason: None
                            10.4(2)
        2 entries were displayed.
    2. HA ports
      1. Verify that all the HA ports are up with a healthy status:
        ha interconnect status show -node <node-name>
        Show example
        cluster1::*> ha interconnect status show -node node1-01
          (system ha interconnect status show)
                               Node: node1-01
                      Link 0 Status: up
                      Link 1 Status: up
                   Is Link 0 Active: true
                   Is Link 1 Active: true
                 IC RDMA Connection: up
                               Slot: 0
                     Debug Firmware: no
        Interconnect Port 0 :
                          Port Name: e1a-17
                                MTU: 4096
                   Link Information: ACTIVE
        Interconnect Port 1 :
                          Port Name: e1b-18
                                MTU: 4096
                               Node: node1-01
                      Link 0 Status: up
                      Link 1 Status: up
                               Slot: 0
                     Debug Firmware: no
                          Port Name: e1a-17
                                MTU: 4096
                          Port Name: e1b-18
                                MTU: 4096
    3. Storage ports
      1. Verify that all the storage ports are up with a healthy status:
        storage port show -port-type ENET
        Show example
        cluster1::*> storage port show -port-type ENET
                                              Speed
        Node               Port Type  Mode    (Gb/s) State    Status
        node1-01
                           e10a ENET  -          100 enabled  online
                           e10b ENET  -          100 enabled  online
                           e11a ENET  -          100 enabled  online
                           e11b ENET  -          100 enabled  online
        node1-02
        node1-03
        node1-04
        16 entries were displayed.
    4. Storage shelf ports
      1. Verify that all the storage shelf ports are up with a healthy status:
        storage shelf port show
        Show example
        cluster1::*> storage shelf port show
        Shelf ID Module State        Internal?
        1.1
               0 A      connected    false
               1 A      connected    false
               2 A      connected    false
               3 A      connected    false
               4 A      connected    false
               5 A      connected    false
               6 A      connected    false
               7 A      connected    false
               8 B      connected    false
               9 B      connected    false
              10 B      connected    false
              11 B      connected    false
              12 B      connected    false
              13 B      connected    false
              14 B      connected    false
              15 B      connected    false
      2. Verify that all the storage shelf ports are up with a healthy status:
        storage shelf port show -fields remote-device,remote-port,connector-state
        Show example
        cluster1::*> storage shelf port show -fields remote-device,remote-port,connector-state
        shelf id connector-state remote-port    remote-device
        1.1   0  connected       Ethernet1/17/1 CX9332D-cs1
        1.1   1  connected       Ethernet1/15/1 CX9364D-cs1
        1.1   2  connected       Ethernet1/17/2 CX9332D-cs1
        1.1   3  connected       Ethernet1/15/2 CX9364D-cs1
        1.1   4  connected       Ethernet1/17/3 CX9332D-cs1
        1.1   5  connected       Ethernet1/15/3 CX9364D-cs1
        1.1   6  connected       Ethernet1/17/4 CX9332D-cs1
        1.1   7  connected       Ethernet1/15/4 CX9364D-cs1
        1.1   8  connected       Ethernet1/19/1 CX9332D-cs1
        1.1   9  connected       Ethernet1/17/1 CX9364D-cs1
        1.1   10 connected       Ethernet1/19/2 CX9332D-cs1
        1.1   11 connected       Ethernet1/17/2 CX9364D-cs1
        1.1   12 connected       Ethernet1/19/3 CX9332D-cs1
        1.1   13 connected       Ethernet1/17/3 CX9364D-cs1
        1.1   14 connected       Ethernet1/19/4 CX9332D-cs1
        1.1   15 connected       Ethernet1/17/4 CX9364D-cs1
  5. Disable auto-revert on the cluster LIFs.
    network interface modify -vserver Cluster -lif * -auto-revert false
Step 2: Configure ports
  1. On switch cs1, shut down the ports connected to all the ports of the nodes.
    cs1# config
    cs1(config)# interface e1/1/1-4,e1/2/1-4,e1/3/1-4,e1/4/1-4,e1/5/1-4,e1/6/1-4,e1/7/1-4,e1/8/1-4
    cs1(config-if-range)# shutdown
    cs1(config)# interface e1/9/1-4,e1/10/1-4,e1/11/1-4,e1/12/1-4,e1/13/1-4,e1/14/1-4,e1/15/1-4,e1/16/1-4
    cs1(config)# interface e1/17/1-4,e1/18/1-4,e1/19/1-4,e1/20/1-4,e1/21/1-4,e1/22/1-44,e1/23/1-4
    cs1(config)# interface e1/24/1-,e1/25/1-4,e1/26/1-4,e1/27/1-4,e1/28/1-4,e1/29/1-4,e1/30/1-44
    cs1(config-if-range)# exit
    cs1(config)# exit
    Caution Make sure to shutdown all connected ports to avoid any network connection issues. Refer to the Knowledge Base article Node out of quorum when migrating cluster LIF during switch OS upgrade for further details.
  2. Verify that the cluster LIFs have failed over to the ports hosted on switch cs1. This might take a few seconds.
    Show example
    Cluster
                node1-01_clus1  up/up      169.254.36.44/16   node1-01    e7a     true
                node1-01_clus2  up/up      169.254.7.5/16     node1-01    e7b     true
                node1-02_clus1  up/up      169.254.197.206/16 node1-02    e7a     true
                node1-02_clus2  up/up      169.254.195.186/16 node1-02    e7b     true
                node1-03_clus1  up/up      169.254.192.49/16  node1-03    e7a     true
                node1-03_clus2  up/up      169.254.182.76/16  node1-03    e7b     true
                node1-04_clus1  up/up      169.254.59.49/16   node1-04    e7a     true
                node1-04_clus2  up/up      169.254.62.244/16  node1-04    e7b     true
  3. Verify that the cluster is healthy:
    cluster show
    Show example
    cluster1::*> cluster show
    Node              Health  Eligibility   Epsilon
    node1-01          true    true          false
    node1-02          true    true          false
    node1-03          true    true          true
    node1-04          true    true          false
    4 entries were displayed.
  4. If you have not already done so, save a copy of the current switch configuration by copying the output of the following command to a text file:
    show running-config
    1. Record any custom additions between the current running-config and the RCF file in use (such as an SNMP configuration for your organization).
    2. For NX-OS 10.2 and later, use the show diff running-config command to compare with the saved RCF file in the bootflash. Otherwise, use a third part diff/compare tool.
  5. Save basic configuration details to the write_erase.cfg file on the bootflash.
    Note
    Make sure to configure the following:
    • Username and password
    • Management IP address
    • Default gateway
    • Switch name
    cs1# show run | i "username admin password" > bootflash:write_erase.cfg
    cs1# show run | section "vrf context management" >> bootflash:write_erase.cfg
    cs1# show run | section "interface mgmt0" >> bootflash:write_erase.cfg
    cs1# show run | section "switchname" >> bootflash:write_erase.cfg
    cs1# echo "hardware access-list tcam region ing-racl 1024" >> bootflash:write_erase.cfg
    cs1# echo "hardware access-list tcam region egr-racl 1024" >> bootflash:write_erase.cfg
    cs1# echo "hardware access-list tcam region ing-l2-qos 1536" >> bootflash:write_erase.cfg
  6. Verify that the write_erase.cfg file is populated as expected:
    show file bootflash:write_erase.cfg
  7. Issue the write erase command to erase the current saved configuration:
    cs1# write erase
    Warning: This command will erase the startup-configuration.
    Do you wish to proceed anyway? (y/n) [n] y
  8. Copy the previously saved basic configuration into the startup configuration.
    cs1# copy bootflash:write_erase.cfg startup-config
  9. Reboot the switch:
    cs1# reload
    This command will reboot the system. (y/n)? [n] y
  10. After the management IP address is reachable again, log in to the switch through SSH.
    You may need to update host file entries related to the SSH keys.
  11. Copy the RCF to the bootflash of switch cs1 using one of the following transfer protocols: FTP, TFTP, SFTP, or SCP.
    For more information on Cisco commands, refer to the appropriate guide in the Cisco Nexus 9000 Series NX-OS Command Reference guides.
    Show example
    This example shows TFTP being used to copy an RCF to the bootflash on switch cs1:
    cs1# copy tftp: bootflash: vrf management
    Enter source filename: NX9332D-GX2B-RCF-v10.0-Shared.txt
    Enter hostname for the tftp server: 172.22.201.50
    Trying to connect to tftp server......Connection to Server Established.
    TFTP get operation was successful
    Copy complete, now saving to disk (please wait)...
  12. Apply the RCF previously downloaded to the bootflash.
    This example shows the RCF file NX9332D-GX2B-RCF-v10.0-Shared.txt being installed on switch cs1:
    cs1# copy NX9332D-GX2B-RCF-v10.0-Shared.txt running-config echo-commands
    Caution
    Make sure to thoroughly read the Installation notes, Important Notes, and banner sections of your RCF. You must read and follow these instructions to ensure the proper configuration and operation of the switch.
  13. Verify that the RCF file is the correct newer version:
    show running-config
    When you check the output to verify you have the correct RCF, make sure that the following information is correct:
    • The RCF banner
    • The node and port settings
    • Customizations
      The output varies according to your site configuration. Check the port settings and refer to the release notes for any changes specific to the RCF that you have installed.
  14. Reapply any previous customizations to the switch configuration.
  15. After you verify the RCF versions, custom additions, and switch settings are correct, copy the running-config file to the startup-config file.
    cs1# copy running-config startup-config
    [] 100% Copy complete
  16. Reboot switch cs1. You can ignore the “cluster switch health monitor” alerts and “cluster ports down” events reported on the nodes while the switch reboots.
    cs1# reload
  17. Verify the health of all the ports on the cluster.
    1. Cluster ports
      1. Verify that cluster ports are up and healthy across all nodes in the cluster:
        network port show -ipspace cluster
        Show example
        Node: node1
        Ignore
        Node: node1-02
        Ignore
        Node: node1-03
        Ignore
        Node: node1-04
        Ignore
      2. Verify the switch health from the cluster.
        network device-discovery show -protocol cdp
        Show example
        cluster1::*> network device-discovery show -protocol cdp
        node1-01/cdp
              Is Monitored: true
                    Reason: None
                            10.4(2)
        cs1(FLMXXXXXXXX)            cluster-network    10.228.137.234   N9K-C9332D-GX2B
              Is Monitored: true
                    Reason: None
                            10.4(2)
    2. HA ports
        Show example
                               Node: node1-01
                      Link 0 Status: up
                      Link 1 Status: up
                               Slot: 0
                     Debug Firmware: no
                          Port Name: e1a-17
                                MTU: 4096
                          Port Name: e1b-18
                                MTU: 4096
        cluster1::*> ha interconnect status show -node node1-02
                               Node: node1-02
                      Link 0 Status: up
                      Link 1 Status: up
                               Slot: 0
                     Debug Firmware: no
                          Port Name: e1a-17
                                MTU: 4096
                          Port Name: e1b-18
                                MTU: 4096
    3. Storage ports
        Show example
                                              Speed
        node1-01
        node1-02
        node1-03
        node1-04
        Show example
        1.1
               0 A      connected    false
               1 A      connected    false
               2 A      connected    false
               3 A      connected    false
               4 A      connected    false
               5 A      connected    false
               6 A      connected    false
               7 A      connected    false
               8 B      connected    false
               9 B      connected    false
      2. Verify the connection status of all the storage shelf ports:
        Show example
  18. Verify that the cluster is healthy:
    cluster show
    Show example
  19. Repeat steps 4 to 18 on switch cs2.
  20. Enable auto-revert on the cluster LIFs.
    network interface modify -vserver Cluster -lif * -auto-revert true
Step 3: Verify the cluster network configuration and cluster health
  1. Verify that the switch ports connected to the cluster ports are up.
    show interface brief
    Show example
    cs1# show interface brief | grep up
    Eth1/9/3        1       eth  trunk  up      none                     100G(D) --
    Eth1/9/4        1       eth  trunk  up      none                     100G(D) --
    Eth1/15/1       1       eth  trunk  up      none                     100G(D) --
    Eth1/15/2       1       eth  trunk  up      none                     100G(D) --
    Eth1/15/3       1       eth  trunk  up      none                     100G(D) --
    Eth1/15/4       1       eth  trunk  up      none                     100G(D) --
    Eth1/16/1       1       eth  trunk  up      none                     100G(D) --
    Eth1/16/2       1       eth  trunk  up      none                     100G(D) --
    Eth1/16/3       1       eth  trunk  up      none                     100G(D) --
    Eth1/16/4       1       eth  trunk  up      none                     100G(D) --
    Eth1/17/1       1       eth  trunk  up      none                     100G(D) --
    Eth1/17/2       1       eth  trunk  up      none                     100G(D) --
    Eth1/17/3       1       eth  trunk  up      none                     100G(D) --
    Eth1/17/4       1       eth  trunk  up      none                     100G(D) --
  2. Verify that the expected nodes are still connected:
    show cdp neighbors
    Show example
    cs1# show cdp neighbors
    Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge
                      S - Switch, H - Host, I - IGMP, r - Repeater,
                      V - VoIP-Phone, D - Remotely-Managed-Device,
                      s - Supports-STP-Dispute
    Device-ID          Local Intrfce  Hldtme Capability  Platform         Port ID
    cs2(FDOXXXXXXXX)    Eth1/31        179    R S I s   N9K-C9364D-GX2A   Eth1/63
    cs2(FDOXXXXXXXX)    Eth1/32        179    R S I s   N9K-C9364D-GX2A   Eth1/64
    node1-01            Eth1/4/1       123    H         AFX-1K            e1a
    node1-01            Eth1/4/2       123    H         AFX-1K            e7a
    node1-01            Eth1/4/3       123    H         AFX-1K            e10a
    node1-01            Eth1/4/4       123    H         AFX-1K            e11a
    node1-02            Eth1/9/1       138    H         AFX-1K            e1a
    node1-02            Eth1/9/2       138    H         AFX-1K            e7a
    node1-02            Eth1/9/3       138    H         AFX-1K            e10a
    node1-02            Eth1/9/4       138    H         AFX-1K            e11a
    node1-03            Eth1/15/1      138    H         AFX-1K            e1a
    node1-03            Eth1/15/2      138    H         AFX-1K            e7a
    node1-03            Eth1/15/3      138    H         AFX-1K            e10a
    node1-03            Eth1/15/4      138    H         AFX-1K            e11a
    node1-04            Eth1/16/1      173    H         AFX-1K            e1a
    node1-04            Eth1/16/2      173    H         AFX-1K            e7a
    node1-04            Eth1/16/3      173    H         AFX-1K            e10a
    node1-04            Eth1/16/4      173    H         AFX-1K            e11a
    Total entries displayed: 18
  3. Verify that the cluster nodes are in their correct cluster VLANs using the following commands:
    show vlan brief
    show interface trunk
    Show example
    cs1# show vlan brief
    VLAN Name                             Status    Ports
    1    default                          active    Po1, Po999, Eth1/31, Eth1/32
                                                    Eth1/33, Eth1/34, Eth1/1/1
                                                    Eth1/1/2, Eth1/1/3, Eth1/1/4
                                                    Eth1/2/1, Eth1/2/2, Eth1/2/3
                                                    Eth1/2/4, Eth1/3/1, Eth1/3/2
                                                    Eth1/3/3, Eth1/3/4, Eth1/4/1
                                                    Eth1/4/2, Eth1/4/3, Eth1/4/4
                                                    Eth1/5/1, Eth1/5/2, Eth1/5/3
                                                    Eth1/5/4, Eth1/6/1, Eth1/6/2
                                                    Eth1/6/3, Eth1/6/4, Eth1/7/1
                                                    Eth1/7/2, Eth1/7/3, Eth1/7/4
                                                    Eth1/8/1, Eth1/8/2, Eth1/8/3
                                                    Eth1/8/4, Eth1/9/1, Eth1/9/2
                                                    Eth1/9/3, Eth1/9/4, Eth1/10/1
                                                    Eth1/10/2, Eth1/10/3, Eth1/10/4
                                                    Eth1/11/1, Eth1/11/2, Eth1/11/3
                                                    Eth1/11/4, Eth1/12/1, Eth1/12/2
                                                    Eth1/12/3, Eth1/12/4, Eth1/13/1
                                                    Eth1/13/2, Eth1/13/3, Eth1/13/4
                                                    Eth1/14/1, Eth1/14/2, Eth1/14/3
                                                    Eth1/14/4, Eth1/15/1, Eth1/15/2
                                                    Eth1/15/3, Eth1/15/4, Eth1/16/1
                                                    Eth1/16/2, Eth1/16/3, Eth1/16/4
                                                    Eth1/17/1, Eth1/17/2, Eth1/17/3
                                                    Eth1/17/4, Eth1/18/1, Eth1/18/2
                                                    Eth1/18/3, Eth1/18/4, Eth1/19/1
                                                    Eth1/19/2, Eth1/19/3, Eth1/19/4
                                                    Eth1/20/1, Eth1/20/2, Eth1/20/3
                                                    Eth1/20/4, Eth1/21/1, Eth1/21/2
                                                    Eth1/21/3, Eth1/21/4, Eth1/22/1
                                                    Eth1/22/2, Eth1/22/3, Eth1/22/4
                                                    Eth1/23/1, Eth1/23/2, Eth1/23/3
                                                    Eth1/23/4, Eth1/24/1, Eth1/24/2
                                                    Eth1/24/3, Eth1/24/4, Eth1/25/1
                                                    Eth1/25/2, Eth1/25/3, Eth1/25/4
                                                    Eth1/26/1, Eth1/26/2, Eth1/26/3
                                                    Eth1/26/4, Eth1/27/1, Eth1/27/2
                                                    Eth1/27/3, Eth1/27/4, Eth1/28/1
                                                    Eth1/28/2, Eth1/28/3, Eth1/28/4
                                                    Eth1/29/1, Eth1/29/2, Eth1/29/3
                                                    Eth1/29/4, Eth1/30/1, Eth1/30/2
                                                    Eth1/30/3, Eth1/30/4
    17   VLAN0017                         active    Eth1/1/1, Eth1/1/2, Eth1/1/3
                                                    Eth1/1/4, Eth1/2/1, Eth1/2/2
                                                    Eth1/2/3, Eth1/2/4, Eth1/3/1
                                                    Eth1/3/2, Eth1/3/3, Eth1/3/4
                                                    Eth1/4/1, Eth1/4/2, Eth1/4/3
                                                    Eth1/4/4, Eth1/5/1, Eth1/5/2
                                                    Eth1/5/3, Eth1/5/4, Eth1/6/1
                                                    Eth1/6/2, Eth1/6/3, Eth1/6/4
                                                    Eth1/7/1, Eth1/7/2, Eth1/7/3
                                                    Eth1/7/4, Eth1/8/1, Eth1/8/2
                                                    Eth1/8/3, Eth1/8/4, Eth1/9/1
                                                    Eth1/9/2, Eth1/9/3, Eth1/9/4
                                                    Eth1/10/1, Eth1/10/2, Eth1/10/3
                                                    Eth1/10/4, Eth1/11/1, Eth1/11/2
                                                    Eth1/11/3, Eth1/11/4, Eth1/12/1
                                                    Eth1/12/2, Eth1/12/3, Eth1/12/4
                                                    Eth1/13/1, Eth1/13/2, Eth1/13/3
                                                    Eth1/13/4, Eth1/14/1, Eth1/14/2
                                                    Eth1/14/3, Eth1/14/4, Eth1/15/1
                                                    Eth1/15/2, Eth1/15/3, Eth1/15/4
                                                    Eth1/16/1, Eth1/16/2, Eth1/16/3
                                                    Eth1/16/4, Eth1/17/1, Eth1/17/2
                                                    Eth1/17/3, Eth1/17/4, Eth1/18/1
                                                    Eth1/18/2, Eth1/18/3, Eth1/18/4
                                                    Eth1/19/1, Eth1/19/2, Eth1/19/3
                                                    Eth1/19/4, Eth1/20/1, Eth1/20/2
                                                    Eth1/20/3, Eth1/20/4, Eth1/21/1
                                                    Eth1/21/2, Eth1/21/3, Eth1/21/4
                                                    Eth1/22/1, Eth1/22/2, Eth1/22/3
                                                    Eth1/22/4, Eth1/23/1, Eth1/23/2
                                                    Eth1/23/3, Eth1/23/4, Eth1/24/1
                                                    Eth1/24/2, Eth1/24/3, Eth1/24/4
                                                    Eth1/25/1, Eth1/25/2, Eth1/25/3
                                                    Eth1/25/4, Eth1/26/1, Eth1/26/2
                                                    Eth1/26/3, Eth1/26/4, Eth1/27/1
                                                    Eth1/27/2, Eth1/27/3, Eth1/27/4
                                                    Eth1/28/1, Eth1/28/2, Eth1/28/3
                                                    Eth1/28/4, Eth1/29/1, Eth1/29/2
                                                    Eth1/29/3, Eth1/29/4, Eth1/30/1
                                                    Eth1/30/2, Eth1/30/3, Eth1/30/4
    18   VLAN0018                         active    Eth1/1/1, Eth1/1/2, Eth1/1/3
    30   VLAN0030                         active    Eth1/1/1, Eth1/1/2, Eth1/1/3
    40   VLAN0040                         active    Eth1/1/1, Eth1/1/2, Eth1/1/3
    cs1# show interface trunk
    Port          Native  Status        Port
                  Vlan                  Channel
    Eth1/1/1      1       trunking      --
    Eth1/1/2      1       trunking      --
    Eth1/1/3      1       trunking      --
    Eth1/1/4      1       trunking      --
    Eth1/2/1      1       trunking      --
    Eth1/2/2      1       trunking      --
    Eth1/2/3      1       trunking      --
    Eth1/2/4      1       trunking      --
    Eth1/30/1     none
    Eth1/30/2     none
    Eth1/30/3     none
    Eth1/30/4     none
    Eth1/31       none
    Eth1/32       none
    Po1           1
    Note For specific port and VLAN usage details, refer to the banner and important notes section in your RCF.
  4. Verify that the ISL between cs1 and cs2 is functional:
    show port-channel summary
    Show example
    cs1# show port-channel summary
    Flags:  D - Down        P - Up in port-channel (members)
            I - Individual  H - Hot-standby (LACP only)
            s - Suspended   r - Module-removed
            b - BFD Session Wait
            S - Switched    R - Routed
            U - Up (port-channel)
            p - Up in delay-lacp mode (member)
            M - Not in use. Min-links not met
    Group Port-       Type     Protocol  Member Ports
          Channel
    1     Po1(SU)     Eth      LACP      Eth1/31(P)   Eth1/32(P)
    999   Po999(SD)   Eth      NONE      --
    cs1#
  5. Verify that the cluster LIFs have reverted to their home port:
    Show example
    Cluster
    If any cluster LIFs have not returned to their home ports, revert them manually from the local node:
    network interface revert -vserver vserver_name -lif <lif-name>
  6. Verify that the cluster is healthy:
    cluster show
    Show example
  7. Verify the connectivity of the remote cluster interfaces:
    1. You can use the network interface check cluster-connectivity show command to display the details of an accessibility check for cluster connectivity:
      Show example
      cluster1::*> network interface check cluster-connectivity show
                                        Source           Destination     Packet
      Node   Date                       LIF              LIF             Loss
      node1-01
             6/4/2025 03:13:33 -04:00   node1-01_clus2  node1-02_clus1   none
             6/4/2025 03:13:34 -04:00   node1-01_clus2  node1-02_clus1   none
      node1-02
             6/4/2025 03:13:33 -04:00   node1-02_clus2  node1-01_clus1   none
             6/4/2025 03:13:34 -04:00   node1-02_clus2  node1-01_clus2   none
    2. Alternatively, you can use the cluster ping-cluster -node <node-name> command to check the connectivity:
      Show example
      cluster1::*> cluster ping-cluster -node local
      Host is node1-04
      Getting addresses from network interface table...
      Cluster node1-01_clus1 169.254.36.44 node1-01 e7a
      Cluster node1-01_clus2 169.254.7.5   node1-01 e7b
      Cluster node1-02_clus1 169.254.197.206 node1-02 e7a
      Cluster node1-02_clus2 169.254.195.186 node1-02 e7b
      Cluster node1-03_clus1 169.254.192.49 node1-03 e7a
      Cluster node1-03_clus2 169.254.182.76 node1-03 e7b
      Cluster node1-04_clus1 169.254.59.49 node1-04 e7a
      Cluster node1-04_clus2 169.254.62.244 node1-04 e7b
      Local = 169.254.59.49 169.254.62.244
      Remote = 169.254.36.44 169.254.7.5 169.254.197.206 169.254.195.186 169.254.192.49 169.254.182.76
      Cluster Vserver Id = 4294967293
      Ping status:
      Basic connectivity succeeds on 12 path(s)
      Basic connectivity fails on 0 path(s)
      Detected 9000 byte MTU on 12 path(s):
          Local 169.254.59.49 to Remote 169.254.182.76
          Local 169.254.59.49 to Remote 169.254.192.49
          Local 169.254.59.49 to Remote 169.254.195.186
          Local 169.254.59.49 to Remote 169.254.197.206
          Local 169.254.59.49 to Remote 169.254.36.44
          Local 169.254.59.49 to Remote 169.254.7.5
          Local 169.254.62.244 to Remote 169.254.182.76
          Local 169.254.62.244 to Remote 169.254.192.49
          Local 169.254.62.244 to Remote 169.254.195.186
          Local 169.254.62.244 to Remote 169.254.197.206
          Local 169.254.62.244 to Remote 169.254.36.44
          Local 169.254.62.244 to Remote 169.254.7.5
      Larger than PMTU communication succeeds on 12 path(s)
      RPC status:
      6 paths up, 0 paths down (tcp check)
      6 paths up, 0 paths down (udp check)
What's next?
After you've upgraded your RCF, you verify the SSH configuration.
