Install NX-OS software and RCFs on Cisco Nexus 9336C-FX2 cluster switches
Contributors netapp-martyh
The Cisco NX-OS software and reference configuration files (RCFs) must be installed on Cisco Nexus 9336C-FX2 cluster switches.
The following conditions must exist before you install the NX-OS software and Reference Configurations Files (RCFs) on the cluster switch:
  • The cluster must be fully functioning (there should be no errors in the logs or similar issues).
  • You must have checked or set your desired boot configuration in the RCF to reflect the desired boot images if you are installing only NX-OS and keeping your current RCF version.
  • If you need to change the boot configuration to reflect the current boot images, you must do so before reapplying the RCF so that the correct version is instantiated on future reboots.
  • You must have a console connection to the switch, required when installing the RCF.
  • You must have consulted the switch compatibility table on the Cisco Ethernet switch page for the supported ONTAP, NX-OS, and RCF versions.
  • There can be command dependencies between the command syntax in the RCF and that found in versions of NX-OS.
  • You must have referred to the appropriate software and upgrade guides available on the Cisco web site for complete documentation on the Cisco switch upgrade and downgrade procedures on Cisco Nexus 9000 Series Switches.
  • You must have the current RCF.
Caution Before installing a new switch software version and RCFs, you must erase the switch settings and perform basic configuration. You must be connected to the switch using the serial console. This task resets the configuration of the management network.
The examples in this procedure use two nodes. These nodes use two 10GbE cluster interconnect ports e0a and e0b.
See the Hardware Universe to verify the correct cluster ports on your platforms.
Note The command outputs might vary depending on different releases of ONTAP.
The examples in this procedure use the following switch and node nomenclature:
  • The names of the two Cisco switches are cs1 and cs2.
  • The node names are cluster1-01 and cluster1-02.
  • The cluster LIF names are cluster1-01_clus1 and cluster1-01_clus2 for cluster1-01 and cluster1-02_clus1 and cluster1-02_clus2 for cluster1-02.
  • The cluster1::*> prompt indicates the name of the cluster.
Note The procedure requires the use of both ONTAP commands and Cisco Nexus 9000 Series Switches commands; ONTAP commands are used unless otherwise indicated.
  1. If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message: system node autosupport invoke -node * -type all -message MAINT=x h
    where x is the duration of the maintenance window in hours.
    Note The AutoSupport message notifies technical support of this maintenance task so that automatic case creation is suppressed during the maintenance window.
  2. Change the privilege level to advanced, entering y when prompted to continue:
    set -privilege advanced
    The advanced prompt (*>) appears.
  3. Display how many cluster interconnect interfaces are configured in each node for each cluster interconnect switch: network device-discovery show -protocol cdp
    cluster1::*> **network device-discovery show -protocol cdp**
    Node/       Local  Discovered
    Protocol    Port   Device (LLDP: ChassisID)  Interface         Platform
    cluster1-02/cdp
                e0a    cs1                       Eth1/2            N9K-C9336C
                e0b    cs2                       Eth1/2            N9K-C9336C
    cluster1-01/cdp
                e0a    cs1                       Eth1/1            N9K-C9336C
                e0b    cs2                       Eth1/1            N9K-C9336C
    4 entries were displayed.
  4. Check the administrative or operational status of each cluster interface.
    1. Display the network port attributes:network port show –ipspace Cluster
      cluster1::*> **network port show -ipspace Cluster**
      Node: cluster1-02
                                                        Speed(Mbps) Health
      Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status
      e0a       Cluster      Cluster          up   9000  auto/10000 healthy
      e0b       Cluster      Cluster          up   9000  auto/10000 healthy
      Node: cluster1-01
                                                        Speed(Mbps) Health
    2. Display information about the LIFs: network interface show -vserver Cluster
      cluster1::*> **network interface show -vserver Cluster**
                  Logical            Status     Network            Current       Current Is
      Vserver     Interface          Admin/Oper Address/Mask       Node          Port    Home
      Cluster
                  cluster1-01_clus1  up/up      169.254.209.69/16  cluster1-01   e0a     true
                  cluster1-01_clus2  up/up      169.254.49.125/16  cluster1-01   e0b     true
                  cluster1-02_clus1  up/up      169.254.47.194/16  cluster1-02   e0a     true
                  cluster1-02_clus2  up/up      169.254.19.183/16  cluster1-02   e0b     true
  5. Ping the remote cluster LIFs: cluster ping-cluster -node node-name
    cluster1::*> **cluster ping-cluster -node cluster1-02**
    Host is cluster1-02
    Getting addresses from network interface table...
    Cluster cluster1-01_clus1 169.254.209.69 cluster1-01     e0a
    Cluster cluster1-01_clus2 169.254.49.125 cluster1-01     e0b
    Cluster cluster1-02_clus1 169.254.47.194 cluster1-02     e0a
    Cluster cluster1-02_clus2 169.254.19.183 cluster1-02     e0b
    Local = 169.254.47.194 169.254.19.183
    Remote = 169.254.209.69 169.254.49.125
    Cluster Vserver Id = 4294967293
    Ping status:
    Basic connectivity succeeds on 4 path(s)
    Basic connectivity fails on 0 path(s)
    Detected 9000 byte MTU on 4 path(s):
        Local 169.254.19.183 to Remote 169.254.209.69
        Local 169.254.19.183 to Remote 169.254.49.125
        Local 169.254.47.194 to Remote 169.254.209.69
        Local 169.254.47.194 to Remote 169.254.49.125
    Larger than PMTU communication succeeds on 4 path(s)
    RPC status:
    2 paths up, 0 paths down (tcp check)
    2 paths up, 0 paths down (udp check)
  6. Verify that the auto-revert command is enabled on all cluster LIFs: network interface show -vserver Cluster -fields auto-revert
    cluster1::*> **network interface show -vserver Cluster -fields auto-revert**
              Logical
    Vserver   Interface           Auto-revert
    Cluster
              cluster1-01_clus1   true
              cluster1-01_clus2   true
              cluster1-02_clus1   true
              cluster1-02_clus2   true
  7. For ONTAP 9.8 and later, enable the Ethernet switch health monitor log collection feature for collecting switch-related log files, using the commands: system switch ethernet log setup-password``system switch ethernet log enable-collection
    cluster1::*> **system switch ethernet log setup-password**
    Enter the switch name: <return>
    The switch name entered is not recognized.
    Choose from the following list:
    cs1
    cs2
    Enter the switch name: **cs1**
    RSA key fingerprint is e5:8b:c6:dc:e2:18:18:09:36:63:d9:63:dd:03:d9:cc
    Do you want to continue? {y|n}::[n] **y**
    Enter the password: <enter switch password>
    Enter the password again: <enter switch password>
    Enter the switch name: **cs2**
    RSA key fingerprint is 57:49:86:a1:b9:80:6a:61:9a:86:8e:3c:e3:b7:1f:b1
    Do you want to continue? {y|n}:: [n] **y**
    cluster1::*> **system  switch ethernet log enable-collection**
    Do you want to enable cluster log collection for all nodes in the cluster?
    {y|n}: [n] **y**
    Enabling cluster switch log collection.
    cluster1::*>
    Note If any of these commands return an error, contact NetApp support.
  8. For ONTAP releases 9.5P16, 9.6P12, and 9.7P10 and later patch releases, enable the Ethernet switch health monitor log collection feature for collecting switch-related log files, using the commands: system cluster-switch log setup-password``system cluster-switch log enable-collection
    cluster1::*> **system cluster-switch log setup-password**
    cs1
    cs2
    cluster1::*> **system cluster-switch log enable-collection**
    {y|n}: [n] **y**
    cluster1::*>
