Install the Reference Configuration File (RCF)
Contributors netapp-martyh
You can install the RCF after setting up the Nexus 9336C-FX2 switch for the first time. You can also use this procedure to upgrade your RCF version.
The examples in this procedure use the following switch and node nomenclature:
  • The names of the two Cisco switches are cs1 and cs2.
  • The node names arecluster1-01, cluster1-02, cluster1-03, and cluster1-04.
  • The cluster LIF names are cluster1-01_clus1, cluster1-01_clus2, cluster1-02_clus1, cluster1-02_clus2 , cluster1-03_clus1, cluster1-03_clus2, cluster1-04_clus1, and cluster1-04_clus2.
  • The cluster1::*> prompt indicates the name of the cluster.
Note The procedure requires the use of both ONTAP commands and Cisco Nexus 9000 Series Switches commands; ONTAP commands are used unless otherwise indicated.
  1. Display the cluster ports on each node that are connected to the cluster switches: network device-discovery show
    cluster1::*> **network device-discovery show**
    Node/       Local  Discovered
    Protocol    Port   Device (LLDP: ChassisID)  Interface         Platform
    cluster1-01/cdp
                e0a    cs1                       Ethernet1/7       N9K-C9336C
                e0d    cs2                       Ethernet1/7       N9K-C9336C
    cluster1-02/cdp
                e0a    cs1                       Ethernet1/8       N9K-C9336C
                e0d    cs2                       Ethernet1/8       N9K-C9336C
    cluster1-03/cdp
                e0a    cs1                       Ethernet1/1/1     N9K-C9336C
                e0b    cs2                       Ethernet1/1/1     N9K-C9336C
    cluster1-04/cdp
                e0a    cs1                       Ethernet1/1/2     N9K-C9336C
                e0b    cs2                       Ethernet1/1/2     N9K-C9336C
    cluster1::*>
  2. Check the administrative and operational status of each cluster port.
    1. Verify that all the cluster ports are up with a healthy status: network port show –role cluster
      cluster1::*>** network port show -role cluster**
      Node: cluster1-01
        Ignore
                                                        Speed(Mbps) Health   Health
      Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status   Status
      e0a       Cluster      Cluster          up   9000  auto/100000 healthy false
      e0d       Cluster      Cluster          up   9000  auto/100000 healthy false
      Node: cluster1-02
        Ignore
      8 entries were displayed.
      Node: cluster1-03
         Ignore
      e0a       Cluster      Cluster          up   9000  auto/10000 healthy  false
      e0b       Cluster      Cluster          up   9000  auto/10000 healthy  false
      Node: cluster1-04
        Ignore
      cluster1::*>
    2. Verify that all the cluster interfaces (LIFs) are on the home port: network interface show -role cluster
      cluster1::*> **network interface show -role cluster**
                  Logical            Status     Network           Current      Current Is
      Vserver     Interface          Admin/Oper Address/Mask      Node         Port    Home
      Cluster
                  cluster1-01_clus1  up/up     169.254.3.4/23     cluster1-01  e0a     true
                  cluster1-01_clus2  up/up     169.254.3.5/23     cluster1-01  e0d     true
                  cluster1-02_clus1  up/up     169.254.3.8/23     cluster1-02  e0a     true
                  cluster1-02_clus2  up/up     169.254.3.9/23     cluster1-02  e0d     true
                  cluster1-03_clus1  up/up     169.254.1.3/23     cluster1-03  e0a     true
                  cluster1-03_clus2  up/up     169.254.1.1/23     cluster1-03  e0b     true
                  cluster1-04_clus1  up/up     169.254.1.6/23     cluster1-04  e0a     true
                  cluster1-04_clus2  up/up     169.254.1.7/23     cluster1-04  e0b     true
      cluster1::*>
    3. Verify that the cluster displays information for both cluster switches: system cluster-switch show -is-monitoring-enabled-operational true
      cluster1::*> **system cluster-switch show -is-monitoring-enabled-operational true**
      Switch                      Type               Address          Model
      cs1                         cluster-network    10.233.205.90    N9K-C9336C
           Serial Number: FOCXXXXXXGD
            Is Monitored: true
                  Reason: None
        Software Version: Cisco Nexus Operating System (NX-OS) Software, Version
                          9.3(5)
          Version Source: CDP
      cs2                         cluster-network    10.233.205.91    N9K-C9336C
           Serial Number: FOCXXXXXXGS
            Is Monitored: true
                  Reason: None
                          9.3(5)
          Version Source: CDP
      cluster1::*>
  3. Disable auto-revert on the cluster LIFs.
    cluster1::*> **network interface modify -vserver Cluster -lif \* -auto-revert false
  4. On cluster switch cs2, shut down the ports connected to the cluster ports of the nodes.
    cs2(config)# **interface eth1/1/1-2,eth1/7-8**
    cs2(config-if-range)# **shutdown**
  5. Verify that the cluster LIFs have migrated to the ports hosted on cluster switch cs1. This might take a few seconds.network interface show -role cluster
    Cluster
                cluster1-01_clus2 up/up      169.254.3.5/23     cluster1-01   e0a     false
                cluster1-02_clus2 up/up      169.254.3.9/23     cluster1-02   e0a     false
                cluster1-03_clus2 up/up      169.254.1.1/23     cluster1-03   e0a     false
                cluster1-04_clus2 up/up      169.254.1.7/23     cluster1-04   e0a     false
    cluster1::*>
  6. Verify that the cluster is healthy: cluster show
    cluster1::*> **cluster show**
    Node                 Health  Eligibility   Epsilon
    cluster1-01          true    true          false
    cluster1-02          true    true          false
    cluster1-03          true    true          true
    cluster1-04          true    true          false
    4 entries were displayed.
    cluster1::*>
  7. Clean the configuration on switch cs2 and perform a basic setup.
Caution When updating or applying a new RCF, you must erase the switch settings and perform basic configuration. You must be connected to the switch using the serial console to erase switch settings.
  1. Clean the configuration. This step requires a console connection to the switch.
    cs2# **write erase
    **Warning: This command will erase the startup-configuration.
    Do you wish to proceed anyway? (y/n)  [n] **y**
    cs2# **reload**
    This command will reboot the system. (y/n)?  [n] **y**
    cs2#
  2. Perform a basic setup of the switch.
    1. Copy the RCF to the bootflash of switch cs2 using one of the following transfer protocols: FTP, TFTP, SFTP, or SCP. For more information on Cisco commands, see the appropriate guide in the Cisco Nexus 9000 Series NX-OS Command Reference guides.
      This example shows TFTP being used to copy an RCF to the bootflash on switch cs2:
      cs2# **copy tftp: bootflash: vrf management**
      Enter source filename: Nexus_9336C_RCF_v1.6-Cluster-HA-Breakout.txt
      Enter hostname for the tftp server: 172.22.201.50
      Trying to connect to tftp server......Connection to Server Established.
      TFTP get operation was successful
      Copy complete, now saving to disk (please wait)...
    2. Apply the RCF previously downloaded to the bootflash.
      This example shows the RCF file Nexus_9336C_RCF_v1.6-Cluster-HA-Breakout.txt being installed on switch cs2:
      cs2# **copy Nexus_9336C_RCF_v1.6-Cluster-HA-Breakout.txt running-config echo-commands**
    3. Examine the banner output from the show banner motd command. You must read and follow these instructions to ensure the proper configuration and operation of the switch.
      cs2# **show banner motd**
      * NetApp Reference Configuration File (RCF)
      * Switch   : Nexus N9K-C9336C-FX2
      * Filename : Nexus_9336C_RCF_v1.6-Cluster-HA-Breakout.txt
      * Date     : 10-23-2020
      * Version  : v1.6
      * Port Usage:
      * Ports  1- 3: Breakout mode (4x10G) Intra-Cluster Ports, int e1/1/1-4, e1/2/1-4
      , e1/3/1-4
      * Ports  4- 6: Breakout mode (4x25G) Intra-Cluster/HA Ports, int e1/4/1-4, e1/5/
      1-4, e1/6/1-4
      * Ports  7-34: 40/100GbE Intra-Cluster/HA Ports, int e1/7-34
      * Ports 35-36: Intra-Cluster ISL Ports, int e1/35-36
      * Dynamic breakout commands:
      * 10G: interface breakout module 1 port <range> map 10g-4x
      * 25G: interface breakout module 1 port <range> map 25g-4x
      * Undo breakout commands and return interfaces to 40/100G configuration in confi
      g mode:
      * no interface breakout module 1 port <range> map 10g-4x
      * no interface breakout module 1 port <range> map 25g-4x
      * interface Ethernet <interfaces taken out of breakout mode>
      * inherit port-profile 40-100G
      * priority-flow-control mode auto
      * service-policy input HA
      * exit
    4. Verify that the RCF file is the correct newer version: show running-config
      When you check the output to verify you have the correct RCF, make sure that the following information is correct:
      • The RCF banner
      • The node and port settings
      • Customizations The output varies according to your site configuration. Check the port settings and refer to the release notes for any changes specific to the RCF that you have installed.
    5. After you verify the RCF versions and switch settings are correct, copy the running-config file to the startup-config file.
      cs2# **copy running-config startup-config \[\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\#\] 100% Copy complete**
    6. Reboot switch cs2. You can ignore the “cluster ports down” events reported on the nodes while the switch reboots.
      cs2# **reload**
    7. Apply the same RCF and save the running configuration for a second time.
      cs2# **copy running-config startup-config** [########################################] 100% Copy complete
    8. Verify the health of cluster ports on the cluster.
  3. Verify that e0d ports are up and healthy across all nodes in the cluster: network port show -role cluster
    cluster1::*> **network port show -role cluster**
    Node: cluster1-01
        Ignore
    Node: cluster1-02
        Ignore
    Node: cluster1-03
        Ignore
    Node: cluster1-04
        Ignore
  4. Verify the switch health from the cluster (this might not show switch cs2, since LIFs are not homed on e0d).
    cluster1::*> **network device-discovery show -protocol cdp**
    cluster1-01/cdp
    cluster01-2/cdp
    cluster01-3/cdp
    cluster1-04/cdp
    cs1                         cluster-network    10.233.205.90    NX9-C9336C
          Is Monitored: true
                Reason: None
                        9.3(5)
        Version Source: CDP
    cs2                         cluster-network    10.233.205.91    NX9-C9336C
          Is Monitored: true
                Reason: None
                        9.3(5)
        Version Source: CDP
    2 entries were displayed.
    Note You might observe the following output on the cs1 switch console depending on the RCF version previously loaded on the switch:
    2020 Nov 17 16:07:18 cs1 %$ VDC-1 %$ %STP-2-UNBLOCK_CONSIST_PORT: Unblocking port port-channel1 on VLAN0092. Port consistency restored.
    2020 Nov 17 16:07:23 cs1 %$ VDC-1 %$ %STP-2-BLOCK_PVID_PEER: Blocking port-channel1 on VLAN0001. Inconsistent peer vlan.
    2020 Nov 17 16:07:23 cs1 %$ VDC-1 %$ %STP-2-BLOCK_PVID_LOCAL: Blocking port-channel1 on VLAN0092. Inconsistent local vlan.
    1. On cluster switch cs1, shut down the ports connected to the cluster ports of the nodes.
      The following example uses the interface example output from step 1:
      cs1(config)# **interface eth1/1/1-2,eth1/7-8**
      cs1(config-if-range)# **shutdown**
    2. Verify that the cluster LIFs have migrated to the ports hosted on switch cs2. This might take a few seconds. network interface show -role cluster
      Cluster
                  cluster1-01_clus1  up/up      169.254.3.4/23     cluster1-01         e0d     false
                  cluster1-02_clus1  up/up      169.254.3.8/23     cluster1-02         e0d     false
                  cluster1-03_clus1  up/up      169.254.1.3/23     cluster1-03         e0b     false
                  cluster1-04_clus1  up/up      169.254.1.6/23     cluster1-04         e0b     false
      cluster1::*>
    3. Verify that the cluster is healthy: cluster show
      cluster1::*>
    4. Repeat Steps 7 to 14 on switch cs1.
    5. Enable auto-revert on the cluster LIFs.
      cluster1::*> **network interface modify -vserver Cluster -lif \* -auto-revert True**
    6. Reboot switch cs1.You do this to trigger the cluster LIFs to revert to their home ports. You can ignore the “cluster ports down” events reported on the nodes while the switch reboots.
      cs1# **reload**
    7. Verify that the switch ports connected to the cluster ports are up.
      cs1# **show interface brief \| grep up**
      Eth1/1/1      1       eth  access up      none                    10G(D) --
      Eth1/1/2      1       eth  access up      none                    10G(D) --
      Eth1/7        1       eth  trunk  up      none                   100G(D) --
      Eth1/8        1       eth  trunk  up      none                   100G(D) --
    8. Verify that the ISL between cs1 and cs2 is functional:show port-channel summary
      cs1# **show port-channel summary**
      Flags:  D - Down        P - Up in port-channel (members)
              I - Individual  H - Hot-standby (LACP only)
              s - Suspended   r - Module-removed
              b - BFD Session Wait
              S - Switched    R - Routed
              U - Up (port-channel)
              p - Up in delay-lacp mode (member)
              M - Not in use. Min-links not met
      Group Port-       Type     Protocol  Member Ports      Channel
      1     Po1(SU)     Eth      LACP      Eth1/35(P)        Eth1/36(P)
      cs1#
    9. Verify that the cluster LIFs have reverted to their home port: network interface show -role cluster
      Cluster
                  cluster1-01_clus1  up/up      169.254.3.4/23     cluster1-01         e0d     true
                  cluster1-02_clus1  up/up      169.254.3.8/23     cluster1-02         e0d     true
                  cluster1-03_clus1  up/up      169.254.1.3/23     cluster1-03         e0b     true
                  cluster1-04_clus1  up/up      169.254.1.6/23     cluster1-04         e0b     true
      cluster1::*>
    10. Verify that the cluster is healthy: cluster show
      cluster1::*>
    11. Ping the remote cluster interfaces to verify connectivity: cluster ping-cluster -node local
      cluster1::*> cluster ping-cluster -node local
      Host is cluster1-03
      Getting addresses from network interface table...
      Cluster cluster1-03_clus1 169.254.1.3 cluster1-03 e0a
      Cluster cluster1-03_clus2 169.254.1.1 cluster1-03 e0b
      Cluster cluster1-04_clus1 169.254.1.6 cluster1-04 e0a
      Cluster cluster1-04_clus2 169.254.1.7 cluster1-04 e0b
      Cluster cluster1-01_clus1 169.254.3.4 cluster1-01 e0a
      Cluster cluster1-01_clus2 169.254.3.5 cluster1-01 e0d
      Cluster cluster1-02_clus1 169.254.3.8 cluster1-02 e0a
      Cluster cluster1-02_clus2 169.254.3.9 cluster1-02 e0d
      Local = 169.254.1.3 169.254.1.1
      Remote = 169.254.1.6 169.254.1.7 169.254.3.4 169.254.3.5 169.254.3.8 169.254.3.9
      Cluster Vserver Id = 4294967293
      Ping status:
      Basic connectivity succeeds on 12 path(s)
      Basic connectivity fails on 0 path(s)
      Detected 9000 byte MTU on 12 path(s):
          Local 169.254.1.3 to Remote 169.254.1.6
          Local 169.254.1.3 to Remote 169.254.1.7
          Local 169.254.1.3 to Remote 169.254.3.4
          Local 169.254.1.3 to Remote 169.254.3.5
          Local 169.254.1.3 to Remote 169.254.3.8
          Local 169.254.1.3 to Remote 169.254.3.9
          Local 169.254.1.1 to Remote 169.254.1.6
          Local 169.254.1.1 to Remote 169.254.1.7
          Local 169.254.1.1 to Remote 169.254.3.4
          Local 169.254.1.1 to Remote 169.254.3.5
          Local 169.254.1.1 to Remote 169.254.3.8
          Local 169.254.1.1 to Remote 169.254.3.9
      Larger than PMTU communication succeeds on 12 path(s)
      RPC status:
      6 paths up, 0 paths down (tcp check)
      6 paths up, 0 paths down (udp check)
