How to migrate to a switched NetApp cluster environment with Cisco Nexus 9336C-FX2 cluster switches
Contributors netapp-martyh
If you have an existing two-node switchless cluster environment, you can migrate to a two-node switched cluster environment using Cisco Nexus 9336C-FX2 switches to enable you to scale beyond two nodes in the cluster.
Two-node switchless configuration:
  • The two-node switchless configuration must be properly set up and functioning.
  • The nodes must be running ONTAP 9.8 and later.
  • All cluster ports must be in the up state.
  • All cluster logical interfaces (LIFs) must be in the up state and on their home ports.
Cisco Nexus 9336C-FX2 switch configuration:
  • Both switches must have management network connectivity.
  • There must be console access to the cluster switches.
  • Nexus 9336C-FX2 node-to-node switch and switch-to-switch connections must use Twinax or fiber cables.
    The Hardware Universe contains more information about cabling.
  • Inter-Switch Link (ISL) cables must be connected to ports 1/35 and 1/36 on both 9336C-FX2 switches.
  • Initial customization of both the 9336C-FX2 switches must be completed. So that the:
    • 9336C-FX2 switches are running the latest version of software
    • Reference Configuration Files (RCFs) have been applied to the switches Any site customization, such as SMTP, SNMP, and SSH must be configured on the new switches.
The examples in this procedure use the following cluster switch and node nomenclature:
  • The names of the 9336C-FX2 switches are cs1 and cs2.
  • The names of the cluster SVMs are node1 and node2.
  • The names of the LIFs are node1_clus1 and node1_clus2 on node 1, and node2_clus1 and node2_clus2 on node 2 respectively.
  • The cluster1::*> prompt indicates the name of the cluster.
  • The cluster ports used in this procedure are e0a and e0b.
    The Hardware Universe contains the latest information about the actual cluster ports for your platforms.
    1. If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message: system node autosupport invoke -node * -type all -message MAINT=xh
      where x is the duration of the maintenance window in hours.
      Note The AutoSupport message notifies technical support of this maintenance task so that automatic case creation is suppressed during the maintenance window.
    2. Change the privilege level to advanced, entering y when prompted to continue: set -privilege advanced
      The advanced prompt (*>) appears.
    3. Disable all node-facing ports (not ISL ports) on both the new cluster switches cs1 and cs2.
      You must not disable the ISL ports.
      The following example shows that node-facing ports 1 through 34 are disabled on switch cs1:
      cs1# **config**
      Enter configuration commands, one per line. End with CNTL/Z.
      cs1(config)# **interface e/1-34**
      cs1(config-if-range)# **shutdown**
    4. Verify that the ISL and the physical ports on the ISL between the two 9336C-FX2 switches cs1 and cs2 are up on ports 1/35 and 1/36: show port-channel summary
      The following example shows that the ISL ports are up on switch cs1:
      cs1# **show port-channel summary**
      Flags:  D - Down        P - Up in port-channel (members)
              I - Individual  H - Hot-standby (LACP only)
              s - Suspended   r - Module-removed
              b - BFD Session Wait
              S - Switched    R - Routed
              U - Up (port-channel)
              p - Up in delay-lacp mode (member)
              M - Not in use. Min-links not met
      Group Port-       Type     Protocol  Member Ports
            Channel
      1     Po1(SU)     Eth      LACP      Eth1/35(P)   Eth1/36(P)
      The following example shows that the ISL ports are up on switch cs2 :
      (cs2)# **show port-channel summary**
            Channel
    5. Display the list of neighboring devices: show cdp neighbors
      This command provides information about the devices that are connected to the system.
      The following example lists the neighboring devices on switch cs1:
      cs1# **show cdp neighbors**
      Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge
                        S - Switch, H - Host, I - IGMP, r - Repeater,
                        V - VoIP-Phone, D - Remotely-Managed-Device,
                        s - Supports-STP-Dispute
      Device-ID          Local Intrfce  Hldtme Capability  Platform      Port ID
      cs2                Eth1/35        175    R S I s     N9K-C9336C    Eth1/35
      cs2                Eth1/36        175    R S I s     N9K-C9336C    Eth1/36
      Total entries displayed: 2
      The following example lists the neighboring devices on switch cs2:
      cs2# **show cdp neighbors**
      cs1                Eth1/35        177    R S I s     N9K-C9336C    Eth1/35
      cs1           )    Eth1/36        177    R S I s     N9K-C9336C    Eth1/36
    6. Verify that all cluster ports are up: network port show -ipspace Cluster
      Each port should display up for Link and healthy for Health Status.
      cluster1::*> **network port show -ipspace Cluster**
      Node: node1
                                                        Speed(Mbps) Health
      Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status
      e0a       Cluster      Cluster          up   9000  auto/10000 healthy
      e0b       Cluster      Cluster          up   9000  auto/10000 healthy
      Node: node2
                                                        Speed(Mbps) Health
      4 entries were displayed.
    7. Verify that all cluster LIFs are up and operational: network interface show -vserver Cluster
      Each cluster LIF should display true for Is Home and have a Status Admin/Oper of up/up
      cluster1::*> **network interface show -vserver Cluster**
                  Logical    Status     Network            Current       Current Is
      Vserver     Interface  Admin/Oper Address/Mask       Node          Port    Home
      Cluster
                  node1_clus1  up/up    169.254.209.69/16  node1         e0a     true
                  node1_clus2  up/up    169.254.49.125/16  node1         e0b     true
                  node2_clus1  up/up    169.254.47.194/16  node2         e0a     true
                  node2_clus2  up/up    169.254.19.183/16  node2         e0b     true
    8. Verify that auto-revert is enabled on all cluster LIFs: network interface show -vserver Cluster -fields auto-revert
      cluster1::*> **network interface show -vserver Cluster -fields auto-revert**
                Logical
      Vserver   Interface     Auto-revert
      Cluster
                node1_clus1   true
                node1_clus2   true
                node2_clus1   true
                node2_clus2   true
    9. Disconnect the cable from cluster port e0a on node1, and then connect e0a to port 1 on cluster switch cs1, using the appropriate cabling supported by the 9336C-FX2 switches.
    10. Disconnect the cable from cluster port e0a on node2, and then connect e0a to port 2 on cluster switch cs1, using the appropriate cabling supported by the 9336C-FX2 switches.
    11. Enable all node-facing ports on cluster switch cs1.
      The following example shows that ports 1/1 through 1/34 are enabled on switch cs1:
      cs1# **config**
      cs1(config)# **interface e1/1-34**
      cs1(config-if-range)# **no shutdown**
    12. Verify that all cluster LIFs are up, operational, and display as true for Is Home: network interface show -vserver Cluster
      The following example shows that all of the LIFs are up on node1 and node2 and that Is Home results are true:
      Cluster
    13. Display information about the status of the nodes in the cluster: cluster show
      The following example displays information about the health and eligibility of the nodes in the cluster:
      cluster1::*> **cluster show**
      Node                 Health  Eligibility   Epsilon
      node1                true    true          false
      node2                true    true          false
      2 entries were displayed.
    14. Disconnect the cable from cluster port e0b on node1, and then connect e0b to port 1 on cluster switch cs2, using the appropriate cabling supported by the 9336C-FX2 switches.
    15. Disconnect the cable from cluster port e0b on node2, and then connect e0b to port 2 on cluster switch cs2, using the appropriate cabling supported by the 9336C-FX2 switches.
    16. Enable all node-facing ports on cluster switch cs2.
      The following example shows that ports 1/1 through 1/34 are enabled on switch cs2:
      cs2# **config**
      cs2(config)# **interface e1/1-34**
      cs2(config-if-range)# **no shutdown**
    17. Verify that all cluster ports are up: network port show -ipspace Cluster
      The following example shows that all of the cluster ports are up on node1 and node2:
      Node: node1
        Ignore
                                                        Speed(Mbps) Health   Health
      Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status   Status
      e0a       Cluster      Cluster          up   9000  auto/10000 healthy  false
      e0b       Cluster      Cluster          up   9000  auto/10000 healthy  false
      Node: node2
        Ignore
    18. Verify that all interfaces display true for Is Home: network interface show -vserver Cluster
      Note This might take several minutes to complete.
      The following example shows that all LIFs are up on node1 and node2 and that Is Home results are true:
      Cluster
    19. Verify that both nodes each have one connection to each switch: show cdp neighbors
      The following example shows the appropriate results for both switches:
      (cs1)# **show cdp neighbors**
      node1              Eth1/1         133    H           FAS2980       e0a
      node2              Eth1/2         133    H           FAS2980       e0a
      Total entries displayed: 4
      (cs2)# **show cdp neighbors**
      node1              Eth1/1         133    H           FAS2980       e0b
      node2              Eth1/2         133    H           FAS2980       e0b
      cs1                Eth1/35        175    R S I s     N9K-C9336C    Eth1/35
      cs1                Eth1/36        175    R S I s     N9K-C9336C    Eth1/36
    20. Display information about the discovered network devices in your cluster: network device-discovery show -protocol cdp
      cluster1::*> **network device-discovery show -protocol cdp**
      Node/       Local  Discovered
      Protocol    Port   Device (LLDP: ChassisID)  Interface         Platform
      node2      /cdp
                  e0a    cs1                       0/2               N9K-C9336C
                  e0b    cs2                       0/2               N9K-C9336C
      node1      /cdp
                  e0a    cs1                       0/1               N9K-C9336C
                  e0b    cs2                       0/1               N9K-C9336C
    21. Verify that the settings are disabled: network options switchless-cluster show
      Note It might take several minutes for the command to complete. Wait for the '3 minute lifetime to expire' announcement.
      The false output in the following example shows that the configuration settings are disabled:
      cluster1::*> **network options switchless-cluster show**
      Enable Switchless Cluster: false
    22. Verify the status of the node members in the cluster: cluster show
      The following example shows information about the health and eligibility of the nodes in the cluster:
    23. Ensure that the cluster network has full connectivity: cluster ping-cluster -node node-name
      cluster1::*> **cluster ping-cluster -node node2**
      Host is node2
      Getting addresses from network interface table...
      Cluster node1_clus1 169.254.209.69 node1 e0a
      Cluster node1_clus2 169.254.49.125 node1 e0b
      Cluster node2_clus1 169.254.47.194 node2 e0a
      Cluster node2_clus2 169.254.19.183 node2 e0b
      Local = 169.254.47.194 169.254.19.183
      Remote = 169.254.209.69 169.254.49.125
      Cluster Vserver Id = 4294967293
      Ping status:
      Basic connectivity succeeds on 4 path(s)
      Basic connectivity fails on 0 path(s)
      Detected 9000 byte MTU on 4 path(s):
      Local 169.254.47.194 to Remote 169.254.209.69
      Local 169.254.47.194 to Remote 169.254.49.125
      Local 169.254.19.183 to Remote 169.254.209.69
      Local 169.254.19.183 to Remote 169.254.49.125
      Larger than PMTU communication succeeds on 4 path(s)
      RPC status:
      2 paths up, 0 paths down (tcp check)
      2 paths up, 0 paths down (udp check)
    24. Change the privilege level back to admin: set -privilege admin
    25. For ONTAP 9.8 and later, enable the Ethernet switch health monitor log collection feature for collecting switch-related log files, using the commands: system switch ethernet log setup-password``system switch ethernet log enable-collection
      cluster1::*> **system switch ethernet log setup-password**
      Enter the switch name: <return>
      The switch name entered is not recognized.
      Choose from the following list:
      cs1
      cs2
      Enter the switch name: **cs1**
      RSA key fingerprint is e5:8b:c6:dc:e2:18:18:09:36:63:d9:63:dd:03:d9:cc
      Do you want to continue? {y|n}::[n] **y**
      Enter the password: <enter switch password>
      Enter the password again: <enter switch password>
      Enter the switch name: **cs2**
      RSA key fingerprint is 57:49:86:a1:b9:80:6a:61:9a:86:8e:3c:e3:b7:1f:b1
      Do you want to continue? {y|n}:: [n] **y**
      cluster1::*> **system  switch ethernet log enable-collection**
      Do you want to enable cluster log collection for all nodes in the cluster?
      {y|n}: [n] **y**
      Enabling cluster switch log collection.
      cluster1::*>
      Note If any of these commands return an error, contact NetApp support.
    26. For ONTAP releases 9.5P16, 9.6P12, and 9.7P10 and later patch releases, enable the Ethernet switch health monitor log collection feature for collecting switch-related log files, using the commands: system cluster-switch log setup-password``system cluster-switch log enable-collection
      cluster1::*> **system cluster-switch log setup-password**
      cs1
      cs2
      cluster1::*> **system cluster-switch log enable-collection**
      {y|n}: [n] **y**
      cluster1::*>
    27. If you suppressed automatic case creation, reenable it by invoking an AutoSupport message: system node autosupport invoke -node * -type all -message MAINT=END
