Migrate from a Cisco switch to a Cisco Nexus 9336C-FX2 cluster switch
Contributors netapp-martyh
You must be aware of certain configuration information, port connections and cabling requirements when you are replacing some older Cisco Nexus cluster switches with Cisco Nexus 9336C-FX2 cluster switches.
  • The following cluster switches are supported:
    • Nexus 9336C-FX2
    • Nexus 92300YC
    • Nexus 5596UP
    • Nexus 5020
    • Nexus 5010
  • The cluster switches use the following ports for connections to nodes:
    • Nexus 9336C-FX2:
      • Ports 1- 3: Breakout mode (4x10G) Intra-Cluster Ports, int e1/1/1-4, e1/2/1-4, e1/3/1-4
      • Ports 4- 6: Breakout mode (4x25G) Intra-Cluster/HA Ports, int e1/4/1-4, e1/5/1-4, e1/6/1-4
      • Ports 7-34: 40/100GbE Intra-Cluster/HA Ports, int e1/7-34
    • Nexus 92300YC:
      • Ports e1/1-48 (10/25 GbE) e1/49-64 (40/100 GbE)
    • Nexus 5596UP:
      • Ports e1/1-40 (10 GbE)
    • Nexus 5020:
      • Ports e1/1-32 (10 GbE)
    • Nexus 5010 with expansion:
      • Ports e1/1-12, e2/1-6 (10 GbE)
  • The cluster switches use the following Inter-Switch Link (ISL) ports:
    • Ports int e1/35-36: Nexus 9336C-FX2
    • Ports e1/65-66 (100 GbE): Nexus 92300YC
    • Ports e1/41-48 (10 GbE): Nexus 5596UP
    • Ports e1/33-40 (10 GbE): Nexus 5020
    • Ports e1/13-20 (10 GbE): Nexus 5010
  • The Hardware Universe contains information about supported cabling for all cluster switches.
  • You have configured some of the ports on Nexus 9336C-FX2 switches to run at 10 GbE or 40 GbE.
  • You have planned, migrated, and documented 10 GbE and 40 GbE connectivity from nodes to Nexus 9336C-FX2 cluster switches.
  • The ONTAP and NX-OS versions supported in this procedure are on the Cisco Ethernet Switches page.
