How to migrate from a Cisco switch to a Cisco Nexus 9336C-FX2 cluster switch
Contributors netapp-martyh
You can migrate nondisruptively older Cisco cluster switches for an ONTAP cluster to Cisco Nexus 9336C-FX2 cluster network switches.
  • The existing cluster must be properly set up and functioning.
  • All cluster ports must be in the up state to ensure nondisruptive operations.
  • The Nexus 9336C-FX2 cluster switches must be configured and operating under the proper version of NX-OS installed and reference configuration file (RCF) applied.
  • The existing cluster network configuration must have the following:
    • A redundant and fully functional NetApp cluster using both older Cisco switches.
    • Management connectivity and console access to both the older Cisco switches and the new switches.
    • All cluster LIFs in the up state with the cluster LIfs are on their home ports.
    • ISL ports enabled and cabled between the older Cisco switches and between the new switches.
The examples in this procedure use the following switch and node nomenclature:
  • The existing Cisco Nexus 5596UP cluster switches are c1 and c2.
  • The new Nexus 9336C-FX2 cluster switches are cs1 and cs2.
  • The nodes are node1 and node2.
  • The cluster LIFs are node1_clus1 and node1_clus2 on node 1, and node2_clus1 and node2_clus2 on node 2 respectively.
  • Switch c2 is replaced by switch cs2 first and then switch c1 is replaced by switch cs1.
    • A temporary ISL is built on cs1 connecting c1 to cs1.
    • Cabling between the nodes and c2 are then disconnected from c2 and reconnected to cs2.
    • Cabling between the nodes and c1 are then disconnected from c1 and reconnected to cs1.
    • The temporary ISL between c1 and cs1 is then removed.
      1. If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message: system node autosupport invoke -node * -type all -message MAINT=xh
        where x is the duration of the maintenance window in hours.
        Note The AutoSupport message notifies technical support of this maintenance task so that automatic case creation is suppressed during the maintenance window.
      2. Change the privilege level to advanced, entering y when prompted to continue: set -privilege advanced
        The advanced prompt (*>) appears.
      3. Verify that auto-revert is enabled on all cluster LIFs: network interface show -vserver Cluster -fields auto-revert
        cluster1::*> **network interface show -vserver Cluster -fields auto-revert**
                  Logical
        Vserver   Interface     Auto-revert
        Cluster
                  node1_clus1   true
                  node1_clus2   true
                  node2_clus1   true
                  node2_clus2   true
        4 entries were displayed.
      4. Determine the administrative or operational status for each cluster interface:
        Each port should display up for Link and healthy for Health Status.
        1. Display the network port attributes: network port show -ipspace Cluster
          cluster1::*> **network port show -ipspace Cluster**
          Node: node1
        Ignore
                                                            Speed(Mbps) Health   Health
          Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status   Status
          e0a       Cluster      Cluster          up   9000  auto/10000 healthy  false
          e0b       Cluster      Cluster          up   9000  auto/10000 healthy  false
          Node: node2
        Ignore
        2. Display information about the logical interfaces and their designated home nodes: network interface show -vserver Cluster
          Each LIF should display up/up for Status Admin/Oper and true for Is Home.
          cluster1::*> **network interface show -vserver Cluster**
                      Logical      Status     Network            Current       Current Is
          Vserver     Interface    Admin/Oper Address/Mask       Node          Port    Home
          Cluster
                      node1_clus1  up/up      169.254.209.69/16  node1         e0a     true
                      node1_clus2  up/up      169.254.49.125/16  node1         e0b     true
                      node2_clus1  up/up      169.254.47.194/16  node2         e0a     true
                      node2_clus2  up/up      169.254.19.183/16  node2         e0b     true
      5. The cluster ports on each node are connected to existing cluster switches in the following way (from the nodes' perspective) using the command: network device-discovery show -protocol cdp
        cluster1::*> **network device-discovery show -protocol cdp**
        Node/       Local  Discovered
        Protocol    Port   Device (LLDP: ChassisID)  Interface         Platform
        node2      /cdp
                    e0a    c1                        0/2               N5K-C5596UP
                    e0b    c2                        0/2               N5K-C5596UP
        node1      /cdp
                    e0a    c1                        0/1               N5K-C5596UP
                    e0b    c2                        0/1               N5K-C5596UP
      6. The cluster ports and switches are connected in the following way (from the switches' perspective) using the command: show cdp neighbors
        c1# **show cdp neighbors**
        Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge
                          S - Switch, H - Host, I - IGMP, r - Repeater,
                          V - VoIP-Phone, D - Remotely-Managed-Device,
                          s - Supports-STP-Dispute
        Device-ID             Local Intrfce Hldtme Capability  Platform         Port ID
        node1                 Eth1/1         124   H           FAS2750          e0a
        node2                 Eth1/2         124   H           FAS2750          e0a
        c2                    Eth1/41        179   S I s       N5K-C5596UP      Eth1/41
        c2                    Eth1/42        175   S I s       N5K-C5596UP      Eth1/42
        c2                    Eth1/43        179   S I s       N5K-C5596UP      Eth1/43
        c2                    Eth1/44        175   S I s       N5K-C5596UP      Eth1/44
        c2                    Eth1/45        179   S I s       N5K-C5596UP      Eth1/45
        c2                    Eth1/46        179   S I s       N5K-C5596UP      Eth1/46
        c2                    Eth1/47        175   S I s       N5K-C5596UP      Eth1/47
        c2                    Eth1/48        179   S I s       N5K-C5596UP      Eth1/48
        Total entries displayed: 10
        c2# **show cdp neighbors**
        node1                 Eth1/1        124    H           FAS2750          e0b
        node2                 Eth1/2        124    H           FAS2750          e0b
        c1                    Eth1/41       175    S I s       N5K-C5596UP      Eth1/41
        c1                    Eth1/42       175    S I s       N5K-C5596UP      Eth1/42
        c1                    Eth1/43       175    S I s       N5K-C5596UP      Eth1/43
        c1                    Eth1/44       175    S I s       N5K-C5596UP      Eth1/44
        c1                    Eth1/45       175    S I s       N5K-C5596UP      Eth1/45
        c1                    Eth1/46       175    S I s       N5K-C5596UP      Eth1/46
        c1                    Eth1/47       176    S I s       N5K-C5596UP      Eth1/47
        c1                    Eth1/48       176    S I s       N5K-C5596UP      Eth1/48
      7. Ensure that the cluster network has full connectivity using the command: cluster ping-cluster -node node-name
        cluster1::*> **cluster ping-cluster -node node2**
        Host is node2
        Getting addresses from network interface table...
        Cluster node1_clus1 169.254.209.69 node1     e0a
        Cluster node1_clus2 169.254.49.125 node1     e0b
        Cluster node2_clus1 169.254.47.194 node2     e0a
        Cluster node2_clus2 169.254.19.183 node2     e0b
        Local = 169.254.47.194 169.254.19.183
        Remote = 169.254.209.69 169.254.49.125
        Cluster Vserver Id = 4294967293
        Ping status:
        Basic connectivity succeeds on 4 path(s)
        Basic connectivity fails on 0 path(s)
        Detected 9000 byte MTU on 4 path(s):
            Local 169.254.19.183 to Remote 169.254.209.69
            Local 169.254.19.183 to Remote 169.254.49.125
            Local 169.254.47.194 to Remote 169.254.209.69
            Local 169.254.47.194 to Remote 169.254.49.125
        Larger than PMTU communication succeeds on 4 path(s)
        RPC status:
        2 paths up, 0 paths down (tcp check)
        2 paths up, 0 paths down (udp check)
      8. Configure a temporary ISL on cs1on ports e1/41-48, between c1 and cs1.
        The following example shows how the new ISL is configured on c1 and cs1:
        cs1# **configure**
        Enter configuration commands, one per line. End with CNTL/Z.
        cs1(config)# **interface e1/41-48**
        cs1(config-if-range)# **description temporary ISL between Nexus 5596UP and Nexus 9336C**
        cs1(config-if-range)# **no lldp transmit**
        cs1(config-if-range)# **no lldp receive**
        cs1(config-if-range)# **switchport mode trunk**
        cs1(config-if-range)# **no spanning-tree bpduguard enable**
        cs1(config-if-range)# **channel-group 101 mode active**
        cs1(config-if-range)# **exit**
        cs1(config)# **interface port-channel 101**
        cs1(config-if)# **switchport mode trunk**
        cs1(config-if)# **spanning-tree port type network**
        cs1(config-if)# **exit**
        cs1(config)# **exit**
      9. Remove ISL cables from ports e1/41-48 from c2 and connect the cables to ports e1/41-48 on cs1.
      10. Verify that the ISL ports and port-channel are operational connecting c1 and cs1: show port-channel summary
        The following example shows the Cisco show port-channel summary command being used to verify the ISL ports are operational on c1 and cs1:
        c1# **show port-channel summary**
        Flags:  D - Down        P - Up in port-channel (members)
                I - Individual  H - Hot-standby (LACP only)
                s - Suspended   r - Module-removed
                b - BFD Session Wait
                S - Switched    R - Routed
                U - Up (port-channel)
                p - Up in delay-lacp mode (member)
                M - Not in use. Min-links not met
        Group Port-       Type     Protocol  Member Ports
              Channel
        1     Po1(SU)     Eth      LACP      Eth1/41(P)   Eth1/42(P)   Eth1/43(P)
                                             Eth1/44(P)   Eth1/45(P)   Eth1/46(P)
                                             Eth1/47(P)   Eth1/48(P)
        cs1# **show port-channel summary**
              Channel
        1     Po1(SU)     Eth      LACP      Eth1/35(P)   Eth1/36(P)
        101   Po101(SU)   Eth      LACP      Eth1/41(P)   Eth1/42(P)   Eth1/43(P)
      11. For node1, disconnect the cable from e1/1 on c2, and then connect the cable to e1/1 on cs2, using appropriate cabling supported by Nexus 9336C-FX2.
      12. For node2, disconnect the cable from e1/2 on c2, and then connect the cable to e1/2 on cs2, using appropriate cabling supported by Nexus 9336C-FX2.
      13. The cluster ports on each node are now connected to cluster switches in the following way, from the nodes' perspective: network device-discovery show -protocol cdp
        node2      /cdp
                    e0b    cs2                       0/2               N9K-C9336C
        node1      /cdp
                    e0b    cs2                       0/1               N9K-C9336C
      14. For node1, disconnect the cable from e1/1 on c1, and then connect the cable to e1/1 on cs1, using appropriate cabling supported by Nexus 9336C-FX2.
      15. For node2, disconnect the cable from e1/2 on c1, and then connect the cable to e1/2 on cs1, using appropriate cabling supported by Nexus 9336C-FX2.
      16. The cluster ports on each node are now connected to cluster switches in the following way, from the nodes' perspective: network device-discovery show -protocol cdp
        node2      /cdp
                    e0a    cs1                       0/2               N9K-C9336C
        node1      /cdp
                    e0a    cs1                       0/1               N9K-C9336C
      17. Delete the temporary ISL between cs1 and c1.
        cs1(config)# **no interface port-channel 10**1
        cs1(config-if-range)# **lldp transmit**
        cs1(config-if-range)# **lldp receive**
        cs1(config-if-range)# **no switchport mode trunk**
        cs1(config-if-range)# **no channel-group**
        cs1(config-if-range)# **description 10GbE Node Port**
        cs1(config-if-range)# **spanning-tree bpduguard enable**
      18. Verify the final configuration of the cluster: network port show -ipspace Cluster
        Node: node1
        Ignore
        Node: node2
        Ignore
        Cluster
        node2      /cdp
        node1      /cdp
        cs1# **show cdp neighbors**
        cs2                Eth1/35        179    R S I s     N9K-C9336C    Eth1/35
        cs2                Eth1/36        179    R S I s     N9K-C9336C    Eth1/36
        cs2# **show cdp neighbors**
        cs1                Eth1/35        179    R S I s     N9K-C9336C    Eth1/35
        cs1                Eth1/36        179    R S I s     N9K-C9336C    Eth1/36
        Total entries displayed: 4
      19. Ensure that the cluster network has full connectivity: cluster ping-cluster -node node-name
        cluster1::*> **set -priv advanced**
        Warning: These advanced commands are potentially dangerous; use them only when
                 directed to do so by NetApp personnel.
        Do you want to continue? {y|n}: **y**
        Host is node2
        Ping status:
        RPC status:
        cluster1::*> **set -privilege admin**
        cluster1::*>
      20. For ONTAP 9.8 and later, enable the Ethernet switch health monitor log collection feature for collecting switch-related log files, using the commands: system switch ethernet log setup-password``system switch ethernet log enable-collection
        cluster1::*> **system switch ethernet log setup-password**
        Enter the switch name: <return>
        The switch name entered is not recognized.
        Choose from the following list:
        cs1
        cs2
        Enter the switch name: **cs1**
        RSA key fingerprint is e5:8b:c6:dc:e2:18:18:09:36:63:d9:63:dd:03:d9:cc
        Do you want to continue? {y|n}::[n] **y**
        Enter the password: <enter switch password>
        Enter the password again: <enter switch password>
        Enter the switch name: **cs2**
        RSA key fingerprint is 57:49:86:a1:b9:80:6a:61:9a:86:8e:3c:e3:b7:1f:b1
        Do you want to continue? {y|n}:: [n] **y**
        cluster1::*> **system  switch ethernet log enable-collection**
        Do you want to enable cluster log collection for all nodes in the cluster?
        {y|n}: [n] **y**
        Enabling cluster switch log collection.
        cluster1::*>
        Note If any of these commands return an error, contact NetApp support.
      21. For ONTAP releases 9.5P16, 9.6P12, and 9.7P10 and later patch releases, enable the Ethernet switch health monitor log collection feature for collecting switch-related log files, using the commands: system cluster-switch log setup-password``system cluster-switch log enable-collection
        cluster1::*> **system cluster-switch log setup-password**
        cs1
        cs2
        cluster1::*> **system cluster-switch log enable-collection**
        {y|n}: [n] **y**
        cluster1::*>
      22. If you suppressed automatic case creation, reenable it by invoking an AutoSupport message: system node autosupport invoke -node * -type all -message MAINT=END
