Cisco Nexus 3132Q-V cabling worksheet
Contributors netapp-martyh
If you want to document the supported platforms, you must complete the blank cabling worksheet by using the completed sample cabling worksheet as a guide. Each switch can be configured as a single 40GbE port or 4 x 10GbE ports.
Sample cabling worksheet
The sample port definition on each pair of switches is as follows:
Cluster switch A Cluster switch B
Switch port
Node and port usage
Switch port
Node and port usage
1
4x10G/40G node
1
4x10G/40G node
2
4x10G/40G node
2
4x10G/40G node
3
4x10G/40G node
3
4x10G/40G node
4
4x10G/40G node
4
4x10G/40G node
5
4x10G/40G node
5
4x10G/40G node
6
4x10G/40G node
6
4x10G/40G node
7
4x10G/40G node
7
4x10G/40G node
8
4x10G/40G node
8
4x10G/40G node
9
4x10G/40G node
9
4x10G/40G node
10
4x10G/40G node
10
4x10G/40G node
11
4x10G/40G node
11
4x10G/40G node
12
4x10G/40G node
12
4x10G/40G node
13
4x10G/40G node
13
4x10G/40G node
14
4x10G/40G node
14
4x10G/40G node
15
4x10G/40G node
15
4x10G/40G node
16
4x10G/40G node
16
4x10G/40G node
17
4x10G/40G node
17
4x10G/40G node
18
4x10G/40G node
18
4x10G/40G node
19
40G node 19
19
40G node 19
20
40G node 20
20
40G node 20
21
40G node 21
21
40G node 21
22
40G node 22
22
40G node 22
23
40G node 23
23
40G node 23
24
40G node 24
24
40G node 24
25 through 30
Reserved
25 through 30
Reserved
31
40G ISL to switch B port 31
31
40G ISL to switch A port 31
32
40G ISL to switch B port 32
32
40G ISL to switch A port 32
Blank cabling worksheet
You can use the blank cabling worksheet to document the platforms that are supported as nodes in a cluster. The Supported Cluster Connections section of the Hardware Universe defines the cluster ports used by the platform.
Switch port
Node/port usage
Switch port
Node/port usage
1
1
2
2
3
3
4
4
5
5
6
6
7
7
8
8
9
9
10
10
11
11
12
12
13
13
14
14
15
15
16
16
17
17
18
18
19
19
20
20
21
21
22
22
23
23
24
24
25 through 30
Reserved
25 through 30
Reserved
31
31
32
32
